    read csv-data and put it in an array
    313 Posts 3 Posters 494.6k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp cool… do you want ages aligned?
      • PerlchampP Offline
        Perlchamp
        yes, of course, sir …
          sdetweil @Perlchamp
          @Perlchamp need to specify width of td
          By default, a browser will adjust table columns to fit the contents of the table. However, if you want to control the width of each column, you can do so by adjusting the width of each or of a single row.
          if you had th, then you could see the length of the names as they go by, and then adjust the th width before sending the content to MM…
            Perlchamp
            width:27px; is placed in css
            but this:
            //bodyTDimage.id = "birthday-td-image";
            works. i really have to write html-text in the module-file ?
              sdetweil @Perlchamp
              @Perlchamp eh? commenting out a line?
              have a th is the same as what you have document.createElement(“th”)
                Perlchamp
                wrong line, moment:
                //bodyTDimage.className = "td-image";
                this works, but unformatted, of course
                i don’t like things like:
                innerHTLM = tags, tags, tags …
                  sdetweil @Perlchamp
                  @Perlchamp eh? where is that?
                    Perlchamp
                    getDom:
                        getDom: function() {
                    	var self = this;
                    	// tell MM to call and get our content
                    	Log.log(JSON.stringify(this.active_birthdays))
                    	if ((moment() > this.midnight) || (!this.loaded)) {
                    	    var month = moment().month();
                    	    var year = moment().year();
                    	    var monthName = moment().format("MMMM");
                    	    var monthLength = moment().daysInMonth();
                    	    // create table
                    	    var wrapper = document.createElement("table");
                    	    wrapper.className = 'table';
                    	    wrapper.id = 'birthday-table';
                    	    // create header
                    	    var tHeader = document.createElement("thead");
                    	    tHeader.className = "thead";
                    	    tHeader.id = "birthday-thead";
                    	    var headerTR = document.createElement("tr");
                    	    headerTR.className = "tr-head";
                    	    headerTR.id = "birthday-tr-head";
                    	    var headerTH = document.createElement("th");
                    	    headerTH.colSpan = "2";
                    	    headerTH.scope = "col";
                    	    headerTH.className = "th-head";
                    	    headerTH.id = "birthday-th-head";
                    	    headerTH.innerHTML = " ";
                    	    headerTR.appendChild(headerTH);
                    	    tHeader.appendChild(headerTR);
                    	    wrapper.appendChild(tHeader);
                    	    // Create TFOOT section -- currently used for debugging only
                    	    var tFooter = document.createElement('tfoot');
                    	    tFooter.className = "tfoot";
                    	    tFooter.id = "birthday-tfoot";
                    	    var footerTR = document.createElement("tr");
                    	    footerTR.className = "tr-foot";
                    	    footerTR.id = "birthday-tr-foot";
                    	    var footerTD = document.createElement("td");
                    	    footerTD.colSpan ="2";
                    	    footerTD.className = "td-foot";
                    	    footerTD.id = "birthday-td-foot";
                    	    if (this.config.debugging) {
                    		footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
                    	    else {
                    		footerTD.innerHTML = "&nbsp;";
                    	    footerTR.appendChild(footerTD);
                    	    tFooter.appendChild(footerTR);
                    	    wrapper.appendChild(tFooter);
                    	    // create TBODY section with day names
                    	    var tBody = document.createElement("tBody");
                    	    tBody.className = "tbody";
                    	    tBody.id = "birthday-tbody";
                    	    for(var birthday of Object.keys(this.active_birthdays)) {
                    		for(var person of this.active_birthdays[birthday]) {
                    		    //var m = document.createElement('div');
                    		    // create looped row section
                    		    var bodyTR = document.createElement("tr");
                    		    bodyTR.className = "tr-body";
                    		    bodyTR.id = "birthday-tr-body";
                    		    var bodyTDimage = document.createElement("td");
                    		    if (birthday.charAt(0) === "0") {
                    			birthday = birthday.replace("0","");
                    			birthday = birthday.substring(0,1);
                    		    bodyTDimage.innerText = birthday.substring(0,2);
                    		    var bodyTD = document.createElement("td");
                    		    bodyTD.className = "td-body";
                    		    bodyTD.id = "birthday-td-body";
                    		    bodyTD.innerHTML = person.name + "&nbsp;&nbsp;&nbsp;<span class=\"age-span\">" + person.age + "</span>";
                    		    //m.innerText = birthday + ' ' + person.name + ' age=' + person.age;
                    		    //wrapper.appendChild(m);
                    		    bodyTR.appendChild(bodyTDimage);
                    		    bodyTR.appendChild(bodyTD);
                    		    tBody.appendChild(bodyTR);
                    		    wrapper.appendChild(tBody);
                    	    // pass the created content back to MM to add to DOM.
                    	    return wrapper;
                    	this.loaded = true;
                    //		var bodyAgeSpan = document.createElement("span");
                    //		bodyAgeSpan.className = "age-span";
                    //		bodyAgeSpan.id = "birthday-age-span";
                    //		bodyAgeSpan.innerHTML = "&nbsp;&nbsp;46";
                    //		bodyTD.appendChild(bodyAgeSpan);
                      sdetweil @Perlchamp
                      @Perlchamp fiddling with it here… technically you are supposed to have a text element as a child of the td
                      < table>
                         < tr>
                            < td> value < /td>
                      var n = document.createTextNode(value);
                        @Perlchamp
                        			   // bodyTR.className = "tr-body";
                        			   // bodyTDimage.className = "td-image";
                        			   // bodyTDimage.innerHTML = birthday;
                        			    bodyTDimage.appendChild(document.createTextNode(birthday));
                        			   // bodyTD.className = "td-body";
                        			   // bodyTD.innerTEXT = person.name ;
                        				bodyTD.appendChild(document.createTextNode(person.name));
                        				var ageTD = document.createElement("td");
                        			    ageTD.id = "birthday-td-age";
                        			    //ageTD.innerTEXT = person.age ;
                        			    ageTD.appendChild(document.createTextNode(person.age));
                        			    bodyTR.appendChild(ageTD);
                        and set the class for the text element
                        • 19
                        • 20
                        • 21
                        • 22
                        • 23
                        • 31
                        • 32
                        • 21 / 32
