    read csv-data and put it in an array
    313 Posts 3 Posters 462.3k Views 4 Watching
    • PerlchampP Offline
      Perlchamp
      you were too fast !!
      to your information:
      table needs a header (thead, tr, th) and a footer (tfoot, tr, td), and, of
      course a boda (tbody, tr, td), my cose, where a put html-tags in the table and text without variable works fine.
      but later, if i should dissapointed, i will try this.
        sdetweil @Perlchamp
        @Perlchamp >where a put html-tags in the table
        its exactly the same as writing the html
        they don’t NEED a thead/tfoot, these are optional
        you could create a big text string of the html < table>… < /table>
        and then assign that text string to the wrapper div innerHTML.
        same result…
          @sdetweil when I had a big pile of html objects to create I wrote a little routine to hide the 4 lines per object
          createEl(type, id, class, parent){
             var el = document.createElement(type)
             el.id=id
             if(class)
               el.classname=class
             parent.addChild(el)
             return el
          then to use
              var table= this.createEl('table', "birthday-tbody", null , wrapper)
                      etc
                      etc
            Perlchamp
            in the moment you’re too fast for me …
            this code is from the test-module:
                getDom: function() {
            	if ((moment() > this.midnight) || (!this.loaded)) {
            	    var month = moment().month();
            	    var year = moment().year();
            	    var monthName = moment().format("MMMM");
            	    var monthLength = moment().daysInMonth();
            	    // tabelle erstellen
            	    var wrapper = document.createElement("table");
            	    wrapper.className = 'table';
            	    wrapper.id = 'birthday-table';
            	    // tabellenkopf erstellen
            	    var tHeader = document.createElement("thead");
            	    tHeader.className = "thead";
            	    tHeader.id = "birthday-thead";
            	    var headerTR = document.createElement("tr");
            	    headerTR.className = "tr-head";
            	    headerTR.id = "birthday-tr-head";
            	    var headerTH = document.createElement("th");
            	    headerTH.colSpan = "2";
            	    headerTH.scope = "col";
            	    headerTH.className = "th-head";
            	    headerTH.id = "birthday-th-head";
            	    headerTH.innerHTML = this.translate(this.config.title);
            	    headerTR.appendChild(headerTH);
            	    tHeader.appendChild(headerTR);
            	    wrapper.appendChild(tHeader);
            	    // Create TFOOT section -- currently used for debugging only
            	    var tFooter = document.createElement('tfoot');
            	    tFooter.className = "tfoot";
            	    tFooter.id = "birthday-tfoot";
            	    var footerTR = document.createElement("tr");
            	    footerTR.className = "tr-foot";
            	    footerTR.id = "birthday-tr-foot";
            	    var footerTD = document.createElement("td");
            	    footerTD.colSpan ="2";
            	    footerTD.className = "td-foot";
            	    footerTD.id = "birthday-td-foot";
            	    if (this.config.debugging) {
            		footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
            	    else {
            		footerTD.innerHTML = "";
            	    footerTR.appendChild(footerTD);
            	    tFooter.appendChild(footerTR);
            	    wrapper.appendChild(tFooter);
            	    // Create TBODY section with day names
            	    var eintraege = 3;
            	    for (var i=1; i<=eintraege; i++) {
            		var tBody = document.createElement("tBody");
            		tBody.className = "tbody";
            		tBody.id = "birthday-tbody";
            		var bodyTR = document.createElement("tr");
            		bodyTR.className = "tr-body";
            		bodyTR.id = "birthday-tr-body";
            		var bodyTDimage = document.createElement("td");
            		bodyTDimage.className = "td-image";
            		bodyTDimage.id = "birthday-td-image";
            		bodyTDimage.innerHTML = "23";
            		var bodyTD = document.createElement("td");
            		bodyTD.className = "td-body";
            		bodyTD.id = "birthday-td-body";
            		bodyTD.innerHTML = "Bettina Zimmermann&nbsp;&nbsp;<span class=\"age-span\">46</span></br>Frank Dubiel&nbsp;&nbsp;<span class=\"age-span\">54</span></br>Jürgen Gruse&nbsp;&nbsp;<span class=\"age-span\">52</span>";
            		var bodyAgeSpan = document.createElement("span");
            		bodyAgeSpan.className = "age-span";
            		bodyAgeSpan.id = "birthday-age-span";
            		bodyAgeSpan.innerHTML = "&nbsp;&nbsp;46";
            		bodyTD.appendChild(bodyAgeSpan);
            		bodyTR.appendChild(bodyTDimage);
            		bodyTR.appendChild(bodyTD);
            		tBody.appendChild(bodyTR);
            		wrapper.appendChild(tBody);
            	    this.loaded = true;
            	    return wrapper;
            and looks like :
              sdetweil @Perlchamp
              @Perlchamp ok, so you WANT a title, header and footer…
              still no different than an actual table in all html
              by using document.creatElement and appendChild() there are no close tags to create
              a td is a closed thing you add text to a td…
              with my little helper routine, you write exactly what you would have written in html
              and can indent/outdent to match for readability
                @Perlchamp maybe a nunjuks template , but its the same work to create the template the generate the content
                the template has to have all the same stuff you are doing, including the loop part
                  Perlchamp
                  This post is deleted!
                    sdetweil @Perlchamp
                    @Perlchamp said in read csv-data and put it in an array:
                    sorry sam, but my code is displayed wrong ! what in hell …
                    the tbody section:
                    any < must have a space after it to display on the forum… no way to escape them yet…
                    no real work from site admin on problem
                      Perlchamp
                          // Override dom generator.
                      	    else {
                      	    var eintraege = 3;
                      	    for (var i=1; i< =eintraege; i++) {
                      		bodyTD.innerHTML = "Bettina Zimmermann&nbsp;&nbsp;< span class=\"age-span\"> 46 < /span > < /br > Frank Dubiel&nbsp;&nbsp; < span class=\"age-span\" > 54 < /span > < /br >Jürgen Gruse&nbsp;&nbsp; < span class=\"age-span\" > 52 < /span > ";
                      	    this.loaded = true;
                      	    return wrapper;
                      this code looks like the image i did send before
                        Perlchamp
                        @sdetweil said in read csv-data and put it in an array:
                        i will shurely take this, if my current html should work. now it’s too much “risk” for me, to change it.
                        • 20
                        • 21
                        • 22
                        • 23
                        • 24
                        • 31
                        • 32
                        • 22 / 32
