    read csv-data and put it in an array
    313 Posts 3 Posters 484.3k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp yep… and you could use divs(as row) and spans(as column) for the table, instead of table/tr/td
      https://html-cleaner.com/features/replace-html-table-tags-with-divs/
        sdetweil @Perlchamp
        @Perlchamp cool thing about the routine, if u decide to use div/span under instead is to fix the routine,
        no mainline code has to change
        • PerlchampP Offline
          Perlchamp
          i don’t think so. therefor i’m a little bit toooooooo retro ;-)
            sdetweil @Perlchamp
            @Perlchamp each to their own!..
              Perlchamp
              if i do this :
              //bodyTDimage.className = "td-image";
              it looks like:
              and i ask me, WHY css is not working only for this cell !!
                sdetweil @Perlchamp
                @Perlchamp td has a class, you are overriding it…
                you want that class on the text in the td, not the td itself…
                table, th, tr, all have classes… you can ADD a class instead of SET a class
                += adds to
                  Perlchamp
                  but the other cell (name plus age) works, WHY ?
                    sdetweil @Perlchamp
                    @Perlchamp not a css class wizard
                      Perlchamp
                      no i don’t override the general td-class, cause i use:
                      .modulname .classname
                      font: 16px;
                        sdetweil @Perlchamp
                        @Perlchamp but you SET the ONLY classname to be yours… classame=
                        wipes out what was there
                        you do not append yours to the list of classNames already assigned className +=
                        • 21
                        • 22
                        • 23
                        • 24
                        • 25
                        • 31
                        • 32
                        • 23 / 32
