    read csv-data and put it in an array
    313 Posts 3 Posters 540.1k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp put a stop on the statement self.updateDom()
      hit refresh, the code should stop there, then mouse over the this.active_birthdays a few lines up,
      the debugger will surface the values
      • PerlchampP Offline
        Perlchamp
        displays the last row of the data-string, though the data from first to last are looped. for me it seems correct there …
          sdetweil @Perlchamp
          @Perlchamp ok, put a stop on the 1st line of getDom()
          it will be called before you get data, then your notification will be called
          and then getdom() again… and u can watch it go thru the code
            Perlchamp
            yes it does … i changed innerText to innerHTML but nothing.
              sdetweil @Perlchamp
              @Perlchamp ok, inner HTML is when u are inserting html… my code inserts text…
              did u have a position: in config definition for module?
              			module: "SampleModule",
              			disabled: false,
              			position: 'middle',
              				days_forward:4,
                Perlchamp
                yes, top, but i will post it, moment:
                			module: 'perlchamp',
                			position: 'top',
                			header: "Geburtstage",
                				language: "de"
                  sdetweil @Perlchamp
                  @Perlchamp i changed mine to top and all ok, did u walk thru the code in getdom? (hit next over and over)
                  put a stop on return wrapper and look at that object…
                  i have multiple names on the same date in my csv file
                  and also allowed look ahead a few days… so had entries for today and tuesday 5/5
                    Perlchamp
                    i clicked on the linenumber and the blue sign went to the last line, though i couldn’t hit line for line …
                      sdetweil @Perlchamp
                      @Perlchamp next to the blue arrow (to the right) is a half circle with arrow at the end and dot under… that is the “Next” instruction button
                        Perlchamp
                        return wrapper. all entries undefined, aha.
                          sdetweil @Perlchamp
                          @Perlchamp on entry, check that the this.active_birthdays is still good
                            Perlchamp
                            i cannot place the blue sign on line 118 (cklicking on that number => run to last line …)
                              sdetweil @Perlchamp
                              @Perlchamp
                              see the circle net to the blue arrow
                              i don’t know where your 118 line is…
                              but go down or up
                                Perlchamp
                                it loops from first entry to last. if the last entry is displayed, it loops once and than going to self.updateDom … for me the correct way …
                                  sdetweil @Perlchamp
                                  @Perlchamp in the getDom()
                                  does it do the innerText statement? then the addChild()
                                  to get any text on the screen, it has to do every statement at least once
                                    Perlchamp
                                    how said:
                                    if i click on the linenumber of getDom: the blue arrow run to the last line. i can’t stop it or something else … it runs thru
                                      sdetweil @Perlchamp
                                      @Perlchamp i don’t understand
                                      in code view, scroll down to getDom, next line, click the number to the left, turns blue
                                      hit refresh
                                        Perlchamp
                                        all values “undefined”
                                          sdetweil @Perlchamp
                                          @Perlchamp this.active_brithdays undefined?
                                          did u fix the names in the notification handler?
                                          		if(notification === "have data"){
                                          			var self = this
                                          			Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
                                          			var now = moment();
                                          			for(var birthday of payload) {
                                          				// get 1st 5 chars of birthdate, thru month
                                          				// we will use this as the key in the hash
                                          				var birth_date = birthday.birth.substring(0,5);
                                          				// get the birthday as a moment in this year, for comparing
                                          				var birth_date_moment = moment(birth_date + now.year(),"DD.MMYYYY");
                                          				// u can add days to a moment object and then compare
                                          				//     if the birthdate is before that date (and after now)
                                          				//     so within the next xx days
                                          				// if the date is the same or later, don't use time of day
                                          				if(birth_date_moment.startOf('day').isSame(now.startOf('day'))) {
                                          					// birthday is in this month
                                          					// check the hash if we've seen anything for today yet
                                          					// if we haven't see this date yet
                                          					if(this.active_birthdays[birth_date] == undefined){
                                          						//  create the holder for its info (array of
                                          						//		names) in the hash
                                          						this.active_birthdays[birth_date] = [];
                                          					// save the persons name on the list
                                          					this.active_birthdays[birth_date].push(birthday.name);
                                          			// tell MM to call and get our content
                                          			self.updateDom();
                                            Perlchamp
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 15
                                            • 16
                                            • 7 / 16
