    read csv-data and put it in an array
    313 Posts 3 Posters 540.1k Views 4 Watching
    • PerlchampP Offline
      Perlchamp
      ok, thanks
        sdetweil @Perlchamp
        @Perlchamp and if something not spelled right (this image also shows the module tree navigation on the left)
        when its used !
          Perlchamp
          so, sam, everything is fixed :-)
          but now i don’t know how to handle the receiving data. i only need a little entry … don’t know how to handle this object-element. actually nothing is displayed except the header i configured …
            sdetweil @Perlchamp
            @Perlchamp cool, now you’ve collected the data… you should be able to see the results on the exit from the notification handler…
            now to tell MM to come get the stuff to display…
            thats the self.updateDom() call
            hey MM, get my stuff
            then MM will call getDom()
            I have implemented the module too
            getDom: function() {
            		for(var birthday of Object.keys(this.active_birthdays)){
            				for(var name of this.active_birthdays[birthday]){
            					var m=document.createElement('div')
            					m.innerText=birthday + ' '+ name
            					wrapper.appendChild(m)
            		// pass the created content back to MM to add to DOM.
            		return wrapper;
              @Perlchamp one thing to watch out for, getDom() will be called immediately, long before you have any data,
              but you MUST return something… so an empty div works… (this is where that 'Loading…" message would be presented
                Perlchamp
                black screen, again. this is my perlchamp.js:
                Module.register("perlchamp", {
                	defaults: {
                		language: "de",
                		dimmEntries: true   // true: dims entries and the associated
                							//       symbol when the date has expired.
                							// false: delete entries and the associated
                	init: function(){
                		Log.log(this.name + " is in init!");
                	start: function(){
                		Log.log("Starting module: " + this.name);
                		// Set locale
                		moment.locale(config.language);
                	loaded: function(callback) {
                		Log.log(this.name + " is loaded!");
                		callback();
                	// return list of other functional scripts to use, if any (like require in node_helper)
                	getScripts: function() {
                		return	["moment.js"];
                	// return list of stylesheet files to use if any
                	getStyles: function() {
                		return 	[this.data.path + "/css/perlchamp.css"];
                	// return list of translation files to use, if any
                	getTranslations: function() {
                		return {
                			// sample of list of files to specify here, if no files, do not use this routine, , or return empty list
                			// en: "translations/en.json",  (folders and filenames in your module folder)
                			// de: "translations/de.json"
                	// only called if the module header was configured in module config in config.js
                	getHeader: function() {
                		return this.data.header;
                	// messages received from other modules and the system (NOT from your node helper)
                	// payload is a notification dependent data structure
                	notificationReceived: function(notification, payload, sender) {
                		// once everybody is loaded up
                		if(notification==="ALL_MODULES_STARTED"){
                			// send our config to our node_helper
                			this.sendSocketNotification("CONFIG",this.config);
                		if (sender) {
                			Log.log(this.name + " received a module notification: " + notification + " from sender: " + sender.name);
                		} else {
                			Log.log(this.name + " received a system notification: " + notification);
                	// messages received from from your node helper (NOT other modules or the system)
                	// payload is a notification dependent data structure, up to you to design between module and node_helper
                		Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
                		if(notification === "message_from_helper"){
                			this.config.message = payload;
                			// tell mirror runtime that our data has changed,
                			// we will be called back at GetDom() to provide the updated content
                			this.updateDom(1000);
                		if(notification === "have data"){
                			var now = moment();
                			var active_birthdays = {};
                			for(var birthday of payload) {
                				// get 1st 5 chars of birthdate, thru month
                				// we will use this as the key in the hash
                				var birth_date = birthday.birth.subString(0,4);
                				// get the birthday as a moment in this year, for comparing
                				var birth_date_moment = moment(birth_date + now.getYear(),"DD.MMYYYY");
                				// u can add days to a moment object and then compare
                				//     if the birthdate is before that date (and after now)
                				//     so within the next xx days
                				// if the date is the same or later, don't use time of day
                				if(birth_date.startOf('day').isSame(now.startOf('day'))) {
                					// birthday is in this month
                					// check the hash if we've seen anything for today yet
                					// if we haven't see this date yet
                					if(active_birthdays[birth_date] == undefined){
                						//  create the holder for its info (array of
                						//		names) in the hash
                						active_birthdays[birth_date] = [];
                					// save the persons name on the list
                					active_birthdays[birth_date].push(birthday.name);
                			// tell MM to call and get our content
                			self.updateDom();
                			// filters the birthdaylist and output only the birthdays
                			// of the current month, sorted (ascending) by days in
                			// the following format:
                			// [{ day: "10", name: ["firstname lastname",...] }]
                			// set variables
                			var today_month = moment().format("MM");
                			var today_day_month = moment().format("DD.MM");
                			var result = Object.entries(jsonObj
                			.filter(({birth}) => birth.split('.')[1] === today_month)
                			.reduce((a, {birth, name}) => {
                				const day = +birth.split('.')[0];
                				a[day] = [...(a[day] || []), name];
                				return a
                			).map(([day, name]) => ({day, name})).sort((a, b) => +a.day - b.day);
                			birthdaysArray = result;
                			// for debugging only
                			//console.log("filtered and sorted: ", birthdaysArray);
                	// system notification your module is being hidden
                	// typically you would stop doing UI updates (getDom/updateDom) if the module is hidden
                	suspend: function(){
                	// system notification your module is being unhidden/shown
                	// typically you would resume doing UI updates (getDom/updateDom) if the module is shown
                	resume: function(){
                	// this is the major worker of the module, it provides the displayable content for this module
                				var m = document.createElement('div');
                				m.innerText = birthday + ' '+ name;
                				wrapper.appendChild(m);
                		return wrapper;
                this the node_helper.js:
                var NodeHelper = require("node_helper");
                var moment = require("moment");
                // add require of other javascripot components here
                // var xxx = require('yyy'); here
                const csv = require("csvtojson");
                var birthdaysArray = [];
                	init(){
                		console.log("init module helper perlchamp");
                	start() {
                		var self = this;
                		console.log("Starting module helper: " + this.name);
                		// convert the csv-file into a JSON-String
                		const csvFilePath = this.path + '/data/birthdays.csv';
                		csv()
                		.fromFile(csvFilePath)
                		.then((jsonObj)=>{
                			birthdaysArray = JSON.stringify(jsonObj);
                			//console.log("birthdaysArray: ", birthdaysArray);
                			// send data to [modulname].js
                			self.sendSocketNotification("have data", jsonObj);
                	stop(){
                		console.log("Stopping module helper: " + this.name);
                	// handle messages from our module// each notification indicates a different messages
                	// payload is a data structure that is different per message.. up to you to design this
                	socketNotificationReceived(notification, payload) {
                		// if config message from module
                		if (notification === "CONFIG") {
                			// save payload config info
                			this.config = payload;
                			// wait 15 seconds, send a message back to module
                			setTimeout(()=> { this.sendSocketNotification("message_from_helper"," this is a test_message")}, 15000);
                		else if(notification === "????2") {
                these are the terminal outputs:
                dirk@raspberrypi:~/MagicMirror/modules/perlchamp $ npm start
                > magicmirror@2.11.0 start /home/dirk/MagicMirror
                [2020-05-02 02:52:02.407] [LOG]    Starting MagicMirror: v2.11.0
                [2020-05-02 02:52:02.414] [LOG]    Loading config ...
                [2020-05-02 02:52:02.418] [LOG]    Loading module helpers ...
                [2020-05-02 02:52:02.424] [LOG]    Initializing new module helper ...
                [2020-05-02 02:52:02.425] [LOG]    Module helper loaded: MMM-Logging
                [2020-05-02 02:52:02.579] [LOG]    init module helper perlchamp
                [2020-05-02 02:52:02.580] [LOG]    Module helper loaded: perlchamp
                [2020-05-02 02:52:02.580] [LOG]    All module helpers loaded.
                [2020-05-02 02:52:02.711] [LOG]    Starting server on port 8080 ...
                [2020-05-02 02:52:02.718] [INFO]   You're using a full whitelist configuration to allow for all IPs
                [2020-05-02 02:52:02.726] [LOG]    Server started ...
                [2020-05-02 02:52:02.727] [LOG]    Connecting socket for: MMM-Logging
                [2020-05-02 02:52:02.727] [LOG]    Module helper started for MMM-Logging
                [2020-05-02 02:52:02.728] [LOG]    Connecting socket for: perlchamp
                [2020-05-02 02:52:02.728] [LOG]    Starting module helper: perlchamp
                [2020-05-02 02:52:02.732] [LOG]    Sockets connected & modules started ...
                [2020-05-02 02:52:02.829] [LOG]    Launching application.
                [2020-05-02 02:52:04.803] [LOG]    Starting module: perlchamp (/home/dirk/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                [2020-05-02 02:52:04.805] [LOG]    All modules started! (/home/dirk/MagicMirror/modules/MMM-Logging/node_helper.js:37 Class.socketNotificationReceived)
                [2020-05-02 02:52:04.806] [LOG]     payload: undefined (/home/dirk/MagicMirror/modules/MMM-Logging/node_helper.js:31 Class.socketNotificationReceived)
                [2020-05-02 02:52:04.807] [LOG]    perlchamp received a system notification: ALL_MODULES_STARTED (/home/dirk/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                [2020-05-02 02:52:04.810] [ERROR]  {} (/home/dirk/MagicMirror/modules/MMM-Logging/node_helper.js:43 Class.socketNotificationReceived)
                [2020-05-02 02:52:04.811] [LOG]    Browser Error: {} (/home/dirk/MagicMirror/modules/MMM-Logging/node_helper.js:46 Class.socketNotificationReceived)
                [2020-05-02 02:52:07.185] [LOG]    Shutting down server... (/home/dirk/MagicMirror/js/electron.js:105 App.<anonymous>)
                [2020-05-02 02:52:07.188] [LOG]    Stopping module helper: MMM-Logging (/home/dirk/MagicMirror/js/node_helper.js:33 Class.stop)
                [2020-05-02 02:52:07.190] [LOG]    Stopping module helper: perlchamp (/home/dirk/MagicMirror/modules/perlchamp/node_helper.js:39 Class.stop)
                i didn’t never seen the notification “have data” …
                  Perlchamp
                  this is the getDom-section where the data finally should be placed (perlchamp is for testing) :
                  	if ((moment() > this.midnight) || (!this.loaded)) {
                  	    var month = moment().month();
                  	    var year = moment().year();
                  	    var monthName = moment().format("MMMM");
                  	    var monthLength = moment().daysInMonth();
                  	    // tabelle erstellen
                  	    var wrapper = document.createElement("table");
                  	    wrapper.className = 'table';
                  	    wrapper.id = 'birthday-table';
                  	    // tabellenkopf erstellen
                  	    var tHeader = document.createElement("thead");
                  	    tHeader.className = "thead";
                  	    tHeader.id = "birthday-thead";
                  	    var headerTR = document.createElement("tr");
                  	    headerTR.className = "tr-head";
                  	    headerTR.id = "birthday-tr-head";
                  	    var headerTH = document.createElement("th");
                  	    headerTH.colSpan = "2";
                  	    headerTH.scope = "col";
                  	    headerTH.className = "th-head";
                  	    headerTH.id = "birthday-th-head";
                  	    headerTH.innerHTML = this.translate(this.config.title);
                  	    headerTR.appendChild(headerTH);
                  	    tHeader.appendChild(headerTR);
                  	    wrapper.appendChild(tHeader);
                  	    // Create TFOOT section -- currently used for debugging only
                  	    var tFooter = document.createElement('tfoot');
                  	    tFooter.className = "tfoot";
                  	    tFooter.id = "birthday-tfoot";
                  	    var footerTR = document.createElement("tr");
                  	    footerTR.className = "tr-foot";
                  	    footerTR.id = "birthday-tr-foot";
                  	    var footerTD = document.createElement("td");
                  	    footerTD.colSpan ="2";
                  	    footerTD.className = "td-foot";
                  	    footerTD.id = "birthday-td-foot";
                  	    if (this.config.debugging) {
                  		footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
                  	    else {
                  		footerTD.innerHTML = "";
                  	    footerTR.appendChild(footerTD);
                  	    tFooter.appendChild(footerTR);
                  	    wrapper.appendChild(tFooter);
                  	    // Create TBODY section with day names
                  	    var eintraege = 3;
                  	    for (var i=1; i<=eintraege; i++) {
                  		var tBody = document.createElement("tBody");
                  		tBody.className = "tbody";
                  		tBody.id = "birthday-tbody";
                  		var bodyTR = document.createElement("tr");
                  		bodyTR.className = "tr-body";
                  		bodyTR.id = "birthday-tr-body";
                  		var bodyTDimage = document.createElement("td");
                  		bodyTDimage.className = "td-image";
                  		bodyTDimage.id = "birthday-td-image";
                  		bodyTDimage.innerHTML = "23";
                  		var bodyTD = document.createElement("td");
                  		bodyTD.className = "td-body";
                  		bodyTD.id = "birthday-td-body";
                  		bodyTD.innerHTML = "Bettina Zimmermann&nbsp;&nbsp;<span class=\"age-span\">46</span></br>Frank Dubiel&nbsp;&nbsp;<span class=\"age-span\">54</span></br>Jürgen Gruse&nbsp;&nbsp;<span class=\"age-span\">52</span>";
                  		var bodyAgeSpan = document.createElement("span");
                  		bodyAgeSpan.className = "age-span";
                  		bodyAgeSpan.id = "birthday-age-span";
                  		bodyAgeSpan.innerHTML = "&nbsp;&nbsp;46";
                  		bodyTD.appendChild(bodyAgeSpan);
                  		bodyTR.appendChild(bodyTDimage);
                  		bodyTR.appendChild(bodyTD);
                  		tBody.appendChild(bodyTR);
                  		wrapper.appendChild(tBody);
                  	    this.loaded = true;
                  	    return wrapper;
                  the data here are text, ifilles in, no variables …
                    sdetweil @Perlchamp
                    @Perlchamp ok, couple problems… in teh notification handler we write to active_birthdays,
                    but it is a variable local to this routine… so, when this routine ends, it goes awau
                    need to move its definition to the top
                    	defaults: {
                    		language: "de",
                        active_birthdays : {},
                    then add ‘this.’ in front of it in the notification handler
                    (and remove the var activebirthdays)
                    now it is an instance variable (one per browser)
                    also, I spelled substring wrong (I had it subString, its substring )
                    gotta run to store, back in a little bit
                      Perlchamp
                      ok, be carefully. keep corona away. use mouth and nose protection and wear disposable gloves !
                      thanks, but doesn’t work. it seems, that i’m too stupid for this ?
                      modified perlchamp.js:
                      	defaults: {
                      		language: "de",
                      	active_birthdays: {
                      	init: function(){
                      	start: function(){
                      		// Set locale
                      		callback();
                      		if (sender) {
                      		} else {
                      			var now = moment();
                      				var birth_date = birthday.birth.substring(0,4);
                      					if(this.active_birthdays[birth_date] == undefined){
                      						this.active_birthdays[birth_date] = [];
                      					this.active_birthdays[birth_date].push(birthday.name);
                      			self.updateDom();
                      	resume: function(){
                      		return wrapper;
                      in node_helper.js was nothing to be changed. maybe I put a few semicolons where none have to go?
                        sdetweil
                        sorry, forgot one thing i saw in node helper,… need to move everything in the start function to the socketNotification section… at start time the module is not up yet, so the message goes nowhere
                        	var self = this
                        			var self = this;
                        			const csvFilePath = this.path + '/birthdays.csv';
                        			csv()
                        			.then((jsonObj)=>{
                        				console.log("birthdaysArray: ", JSON.stringify(birthdaysArray));
                        also, by moving it here, all you have to do is fix the code, save and then refresh the page… don’t have to restart MM
                        start is now empty
                        	start() {
                          Perlchamp
                          ok, nothing changed and i don’t see any messages of “HAVEDATA” (changed it in both files to big letter without space). i only see the header “Geburtstage” … :-(
                          node_helper.js:
                          	init(){
                          	start() {
                          	stop(){
                          		var self = this;
                          		csv()
                          		.then((jsonObj)=>{
                          			self.sendSocketNotification("HAVEDATA", jsonObj);
                          			setTimeout(()=> {this.sendSocketNotification("message_from_helper"," this is a test_message")}, 15000);
                          maye change this part, cause i never need this variable birthdaysArray:
                          .then((jsonObj)=>{
                          perlchamp.js:
                          	defaults: {
                          		language: "de",
                          	active_birthdays: {
                          	init: function(){
                          	start: function(){
                          		// Set locale
                          		callback();
                          		if (sender) {
                          		} else {
                          		if(notification === "HAVEDATE"){
                          			var now = moment();
                          			self.updateDom();
                          	resume: function(){
                          		return wrapper;
                          please have an eye on the getDom-sektion.
                            sdetweil
                            no… it will do the thig every time a notifcation comes in, only want it when the module sends down a message (say it is alive)
                            in node_help you are sending this “HAVEDATA”
                            and in module you are looking for this if(notification === “HAVEDATE”){
                            add a var self = this to start of socketNotificationReceived() and getDom()
                              sdetweil @Perlchamp
                              @Perlchamp said in read csv-data and put it in an array:
                              if(birth_date.startOf(‘day’)
                              also should be
                              if(birth_date_moment.startOf('day')
                              comparing moments, not strings! oops
                                Perlchamp
                                only the header i see, BUT now i see the terminal-message “HAVEDATA” but an error, too:
                                  sdetweil @Perlchamp
                                  @Perlchamp open the developers window, ctrl-shift-i on the mirror screen,
                                  select console tab,
                                  put perl in the filter field
                                  select the sources tab, navigate the left nav tree,. to modules/perlchamp/perlcmap.js
                                  find the socketnotificationreceived
                                  click the number in the left column, hit f5 (refresh) on keyboard
                                  code should stop at the line you clicked
                                  in the right pane, top there is a blue arrow (resume executing) and a top half of a globe, stop on next )instruction)
                                    Perlchamp
                                    before looking in dev: i saw the following:
                                    change to DD.MM.YYYY (point between MM and YYYY) ?
                                      sdetweil @Perlchamp
                                      @Perlchamp no, cause we extract dd.mm from the info provided in file…
                                      oh, the substring should be 0,5, not 0,4
                                      var birth_date = birthday.birth.substring(0,5);
                                        Perlchamp
                                        error => now.getYear() is not a function
                                          sdetweil @Perlchamp
                                          @Perlchamp yeh, sorry, rememeber just off the top of my head…
                                          date uses that …
                                          moment its just year()
                                          var birth_date_moment = moment(birth_date + now.year(),“DD.MMYYYY”);
                                            Perlchamp
                                            nothing changed. but now i see the HAVEDATA notification again. could it be, that the Dom-update (from notification) not really goes ?
                                            i mean i saw in the dev, that the birthday-data are right. it was the first entry of this data-string (or jsonObj) …
                                            only the header i can see …
                                            • 6
                                            • 7
                                            • 8
                                            • 15
                                            • 16
                                            • 6 / 16
