Custom CSS
8 Posts 3 Posters 1.3k Views 3 Watching
    rxlDavid
    I tried to do my one CSS and move the Modules in custom positions:
    I edited my css to the following:
    .MMM-Mail{
      left : 100 px,
      top: 500 px
    But this doesn’t work, it changes nothing…
    M 1 Reply Last reply Apr 30, 2020, 2:32 PM Reply Quote 0
      Mykle1 Project Sponsor Module Developer @rxlDavid
      @rxlDavid
      Use these. Adjust to your liking:
      .MMM-Mail {
        margin-right: 0px;
        margin-left: 0px;
        margin-top: 0px;
        margin-bottom: 0px;
      S 1 Reply Last reply Apr 30, 2020, 2:36 PM Reply Quote 1
        sdetweil @Mykle1
        @Mykle1 qwouldn’t both those also need
        position: absolute
        as the default is
        position:relative?
        M R 2 Replies Last reply Apr 30, 2020, 2:38 PM Reply Quote 0
          I don’t know. I’m still guessing at this stuff. :-)
          S 1 Reply Last reply Apr 30, 2020, 2:46 PM Reply Quote 0
            rxlDavid @sdetweil
            @sdetweil where do I need to change that?
            S 1 Reply Last reply Apr 30, 2020, 2:51 PM Reply Quote 0
              sdetweil @Mykle1
              @Mykle1 magicMirror has a bunch of regions, containers of content, with defined positions.
              the browser doesn’t KNOW anything about MM design, its just html and css. just like a normal page
              so if u add content in a ‘position’, MM inserts the modules content (returned from getDom()) into the specific physical region… you would EXPECT the content to be positioned there… so relative to the container.
              if the user said top_right, and for whatever reason, the module developer wanted it to be top_left, by the time the module startup gets called, its too late, MM will put whatever content into the config.js ‘position’ container
              now, you have to tell the browser, no, not THERE… but HERE… position me where I tell you, in absolute coordinates… if u don’t SAY absolute, the your adjustments (x/y, width/height) are relative to the container the content is in
              this will lead to some crazy results…
              module x is in the uppoer right, but you firced YOUR module to the upper right, and well, you will get what you get… some overlay, some intermixed…
              M 1 Reply Last reply Apr 30, 2020, 2:48 PM Reply Quote 0
                Thanks for the info. The entry I posted has always worked for me. Go figure.
                  sdetweil @rxlDavid
                  @rxlDavid your proposed css class
                  .MMM-Mail{
                    position:absolute;
                    left : 100px;
                    top: 500px;
                  u also had syntax errors, spaces between number and px,
                  each standalone item ends with ; not comma ,
                  u can open the developers window, f12 or ctrl-shift-i on the keyboard) (and can open a browser on the page from your desktop and do the debug there), ’
                  select the elements tab, and navigate thru the position area to find you module content, and click on an element and the dev window will show you the css class hierarchy (bottom at top of page). etc…
                  u can fix the css file, and then refresh the page to examine the differences… repeat til you get what you want
