    Question for custom css
    8 Posts 4 Posters 2.6k Views 4 Watching
      dsmigl
      New to Magic Mirror. I had a friend help build a web page (family dashboard) prior that had a 7 day forecast, a month view of google calendar, and weather radar. After learning more about the capabilities of Magic Mirror, I wanted to add several additional modules. I am currently running a small 19" monitor rotated and mounted to the side of my kitchen cabinet. My question before heavily getting involved with MM is around the regions. I’m looking more into a heavily modified format using CSS grid or something similar. Attached image is my proposed layout. Curious if this can be accomplished? And if so, is there any specific guidance on tying in the modules to those specific grid locations?!MM Template.jpg
      S lavolp3L 2 Replies Last reply Reply Quote 0
        sdetweil @dsmigl
        @dsmigl see the MM index.html for the designed layout… each area is a stack, 1st in config is top, next is lower, etc…
        most modules are written to honor the layout
          dsmigl @sdetweil
          @sdetweil Thanks Sam! knowing this can be accomplished I will proceed with learning all the ins and outs of MagicMirror. Just at first glance, the capabilities appear close to endless and the community is always there to help.
            sdetweil @dsmigl
            @dsmigl i don’t know IF it can be … looks pretty hard from the MM design perspective
              dsmigl @sdetweil
              @sdetweil understood, will get in and mess with it and see how close, if any, I can get it.
                bhepler Module Developer
                Anything is possible, with enough work. That’s the fun of being a developer. You are god on your machine, up to and including rewriting the operating system - the very laws of nature, if you will - to create things as you see fit.
                Granted, it’s not always easy and it may not be worth the effort. But it is possible.
                That said, you can probably modify the original Magic Mirror code to add new regions. You’ll need to modify the index.html and main.ccs files at the very least. You probably will need to modify the main script to add the new region names to the routines that load the modules.
                And you’ll want to fork the Magic Mirror repository and work from your fork. Otherwise, you’ll lose everything with the next upgrade.
                • lavolp3L Offline
                  lavolp3 Module Developer @dsmigl
                  @dsmigl Someone here on the forum rewrote the css part into a grid style. It is a very good idea which I have put on my todo list as well.
                  https://forum.magicmirror.builders/topic/10498/magic-mirror-redesign-wip-d/2?_=1588662144678
                  Apart from that, most of what you are showing COULD be done using the current format. But I guess changing to a grid display would be easier.
                  How to troubleshoot modules
                  MMM-soccer v2, MMM-AVStock
                    dsmigl @lavolp3
                    @lavolp3 Thanks! I loaded up a new MM build today and started messing with the configs using this one as a reference and so far I am liking the results. Similar to what I was originally aiming for. Much appreciated for pointing this out!
