    MMM-RAIN-MAP (new: version 2.x)
    193 Posts 39 Posters 321.3k Views 42 Watching
    • H
      hogedir @Jalibu
      @Jalibu Is it possible to add a second source possible to be selected in the module ? the goal could be to show CLOUDS via SATELLITE RADAR too. Using IFRAME is not a solution. I prefer to use a unique MAP with rain + clouds included.
      because lots of people needs to know if some clouds will be showed
      Could be very very a master class module with that option.
      here an example of sat clouds : http://en.sat24.com/en
      Here the code you could use to integrate that data in the module : http://en.sat24.com/en/freeimages
      RAINVIEWER DATA is not accurate at all like said MajorC(Project Sponsor). It doesn’t represent the reality.
      Check
      JalibuJ 1 Reply Last reply
      • JalibuJ
        Jalibu Module Developer @hogedir
        @hogedir I understand the need and desire. However, neither the weather data/layers from Weerplaza.nl, nor those from sat24.com are in any way compatible with the previous module. It is technically not so easy to put their layers just “over” the map ;-)
        If someone finds a solution and takes care of the programming, then I would be happy to put this extension into the module.
        However, I don’t have the time to take care of it myself.
        • W
          whimsicality
          Is there a basic resource on how to generate maps? I am struggling with this basic concept. I’ve been to open street maps but I don’t see any way to generate a file like you did in the example.
            sdetweil @whimsicality
            @whimsicality the api provides the drawing of the maps
            W 1 Reply Last reply
            • W
              whimsicality @sdetweil
              @sdetweil according tot he config it looks like I’m supposed to input all kinds of GPS coordinates for the edges of the map as well as the link to the picture of the map… I think I’m just confused.
                @whimsicality he’s telling the api the size and shape of the map to draw… because thats what they do…
                I do the same thing with chartjs… I tell it the size and shape and all the points in the data, and what kind of chart to draw, and it generates the graphics.
                • W
                  @sdetweil I think I was making it unnecessarily complicated, I understand it now. thanks!
                  • W
                    whimsicality
                    hi! love this app but am struggling. I’ve tried the CSS mentioned here to change the opacity as well as just changing it under “config” but I can’t get teh opacity of the map to change. is there any other option to attempt?
                    • W
                      whimsicality
                      Hi am definitely loving this module but honestly struggling to get the rain map to go away when rain is not predicted. I see the instructions for how to make it work with the weather module, but what piece of code do I need to have present in MMM-OpenWeatherForecast in order to trigger MMM-RAIN-MAP to hide itself? Sorry if it’s obvious…
                      • JalibuJ
                        Jalibu Module Developer @whimsicality
                        @whimsicality you don’t need additional code in your weather module.
                        It is only important to have one of the supported (weather, MMM-OpenWeatherForecast) running together with MMM-RAIN-MAP on your mirror.
                        If you use OpenWeatherForecast, all you need to do is to set the displayHoursBeforeRain option in your MMM-RAIN-MAP settings.
                        For example, if you want to let the rain map appear one hour before rain starts, your rain map config should look like that:
                        	module: "MMM-RAIN-MAP",
                        		// all your other config
                        		displayHoursBeforeRain: 1,
                        • W
                          whimsicality @Jalibu
                          @Jalibu Unfortunately it doesn’t work, could it be an interference from the scenes module I am using?
                          • M
                            mdiorio
                            Hi!
                            Great module - wondering if we can adjust the transparency of the rain layer? It’s very much in your face, especially with a dark theme in a dark kitchen.
                            Thanks!
                            KristjanESPERANTOK 1 Reply Last reply
                            Reply Quote 1
                            • KristjanESPERANTOK
                              KristjanESPERANTO Module Developer @mdiorio
                              With the new v3.1.0 release, MMM-RAIN-MAP gets two new features:
                              • You can now choose LibreWXR (https://librewxr.net/) as an alternative provider, which can be useful in regions with limited RainViewer coverage. You can even host it yourself :)
                              • A new opacity option makes it possible to adjust the radar layer, especially when using a dark map theme. @mdiorio Thanks for the suggestion!
                              Reply Quote 4
                              • 6
                              • 7
                              • 8
                              • 9
                              • 10
                              • 10 / 10
