    npm ERR! missing script: start
    5 Posts 3 Posters 2.7k Views 3 Watching
    • PerlchampP Offline
      Perlchamp
      as the heading says, i have a problem starting my module. npm start causes the following error:
      here is my package.json file:
        "name": "emetalcharts",
        "version": "1.0.0",
        "description": "charting commodity prices",
        "main": "emetalcharts.js",
        "private": "true",
        "scripts": {
          "test": "echo \"Error: no test specified\" && exit 1"
        "repository": {
          "type": "git",
          "url": "git+https://github.com/sdetweil/SampleModule.git"
        "author": "",
        "license": "MIT",
        "bugs": {
          "url": "https://github.com/sdetweil/SampleModule/issues"
        "homepage": "https://github.com/sdetweil/SampleModule#readme",
        "dependencies": {
          "chart.js": "^2.5.0",
          "sqlite3": "^4.2.0"
      the following is recommended on many websites:
        "scripts": {
          "test": "echo \"Error: no test specified\" && exit 1",
          "start" : "node ."
      this then causes the following error message :
      Module.register("emetalcharts", {
      ReferenceError: Module is not defined
      I’m done. Who can help me ?
      could it also be a version conflict?
      my versions:
       $ node --version
      v10.20.1
      $ npm --version
      6.14.5
      Thanks in advance
      so long
      • bheplerB Offline
        bhepler Module Developer @Perlchamp
        @Perlchamp - Did you run npm install inside the module folder?
          Perlchamp
          yes, of course. thank you
          this did install the node_module folder in my module folder
          • lavolp3L Offline
            lavolp3 Module Developer @Perlchamp
            @Perlchamp Are you running npm start inside the module folder?
            I’m not an expert on this, but I think Module is a class that belongs to the MagicMirror environment. Your module as a standalone does not know what to do with it.
            If you run npm start in the MagicMirror folder, it would recognize the code.
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
              Perlchamp
              yes, of course. thank you.
