    All image based modules only show tiny icon instead of image.
    4 Posts 2 Posters 883 Views 2 Watching
    • N
      nibov33070
      Hi. I’ve just installed MagicMirror on a Pi4. I’ve tried MMM-ImagesPhotos, MMM-BackgroundSlideshow & MMM-ImageSlideshow and all 3 modules when run only show a small icon instead of images. I’ve tried pointing MMM-ImageSlideshow at the example images folder & it does the same thing. Does anyone have any ideas? Thanks.
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @nibov33070
        @nibov33070
        This applies to MMM-ImageSlideshow:
        My guess is this:
        1. The example config entry doesn’t show a closing comma after the last curly bracket.
        2. The imagePaths config option (in the example) is faulty (somewhat) . The array should read ['modules/MMM-ImageSlideshow/exampleImages'] in order for the module to work when cloned. You can verify this by looking at the repo for the module. A valid, but not complete, config entry follows. See the readme in the repo for all options:
        module: 'MMM-ImageSlideshow',
        position: 'middle center',
            imagePaths: ['modules/MMM-ImageSlideshow/exampleImages'],
            slideshowSpeed: 6000,
            fixedImageWidth: 250,
            fixedImageHeight: 250,
            randomizeImageOrder: true,
        N 1 Reply Last reply
        • N
          nibov33070 @Mykle1
          @Mykle1 I’ve got it working now. I checked the syntax & compared it to your example, but I also originally had the imagePath connected to mnt/images. I changed the share to …/MMM-ImageSlideshow/Images and now it works fine. Thanks again.
          • Mykle1M
            @nibov33070
            There you go! Have fun.
