    Current weather missing
    10 Posts 3 Posters 991 Views 3 Watching
      jeaniouso
      Hi All!
      I just installed a transit module last night after feverishly trying to get it to work for hours so, after success with that thanks to two members, I now have another problem. The current weather portion of my MM no longer shows up. I tried disabling the new module however that doesn’t help. I also tried an entire different API and with that variable it’s still the same… Please help… Thanks…```
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 12,
      	units: "imperial",
      			     // false, default for all  NON-armv6l devices
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "US Holidays",
      						symbol: "calendar-check",
      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
          module: 'MMM-nyc-transit',
          position: "top_bar",
          header: "Next Train",
            apiKey: '632718b7d31a32ec745fd296c6d824a0',
            displayType: 'list',
            mtaType: 'train',
            stations: [
                stationId: 604,
                walkingTime: 5,
                dir: {
                    upTown: true,
                    downTown: false
                stationId: 604,
                walkingTime: 5,
                dir: {
                  upTown: false,
                  downTown: true
            updateInterval: 300000
      			module: "compliments",
      			position: "lower_third"
      			module: "currentweather",
      				locationID: "5133268 ", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				appid: ""
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				appid: "884eb65b89072dea57b1be818275ceca"
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
      S Mykle1M 3 Replies Last reply Reply Quote 0
      • S Away
        sdetweil @jeaniouso
        @jeaniouso said in Current weather missing:
          		appid: ""
        did u put in an appid? you must
          jeaniouso @sdetweil
          @sdetweil I did , I just removed it for privacy reasons.
          • S Away
            sdetweil @jeaniouso
            @jeaniouso ok, we typically look to see **** in the field rather than empty… “” may be the default, “****”
            is never the default… saves us and u one question cycle
            • S Away
              @sdetweil did u open the developers window, console tab, and also look at the terminal window or pm2 logs for any error messages
                Mykle1 Project Sponsor Module Developer @jeaniouso
                You have a space after the locationID in the currentweather entry, just before the closed quote. Remove the space. It should look like this locationID: "5133268",
                  @jeaniouso
                  Also, you have 2 different locationID’s. Just thought I would mention that.
                  J 2 Replies Last reply Reply Quote 0
                    jeaniouso @sdetweil
                    @sdetweil Got it … I’m learning i’m learning lol
                      jeaniouso @Mykle1
                      @Mykle1 Hi There! yes I wanted to get a near accurate location of the same area or at least the immediate surrounding area versus just having the general NYC temp… I kinda wanted to at least get a neighborhood close to weather the temperature might be … Let me fix that… Thanks as ALWAYS
                        jeaniouso @Mykle1
                        @Mykle1 That DID THE TRICK!!!
