    MMM-BMW-OW
    7 Posts 3 Posters 2.0k Views 3 Watching
      snikolaidis
      Just sits at OpenWeather data … I know my key works because the default weather apps work
      MMM-BMW-CC works just fine though
      Id like to keep the same info set because CC shows different data
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @snikolaidis
        @snikolaidis
        1. Please start MM using npm start dev and check the console for errors related to MMM-BMW-OW.
        2. Before quitting MM bring your terminal to the front and check that for errors as well.
        3. Report any errors you find
        4. Post your config entry for MMM-BMW-OW in a code block so I can look at it.
        The module is working as expected here.
        • Mykle1M
          Re: MMM-BMW-OW
          Several users posted the same issue. It was a mistake on my part when writing up the readMe. In error, I had apiKey: "", in the config sample when it should be api: "",. My apologies. I have corrected the readme. To those that posted an issue, my thanks for bringing the problem to my attention.
          • R
            Ron.kamstra
            question about the config of the module: how do i get the globe above the weather?
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @Ron.kamstra
              @Ron-kamstra
              I think you mean MMM-EARTH which is another module. You simply have to add it to your MM.
              https://github.com/mykle1/MMM-EARTH
              R 1 Reply Last reply
              • R
                Ron.kamstra @Mykle1
                @Mykle1 said in MMM-BMW-OW:
                MMM-EARTH
                Thanks that worked for me.
                • Mykle1M
                  @Ron-kamstra
                  :thumbsup:
