    GPIO help
    6 Posts 4 Posters 1.7k Views 4 Watching
    • P
      PHAGE.GOV
      Hello,
      I was trying to run the
      sudo usermod -a -G gpio pi
      step on the MMM-PIR-sensor module and for some reason it wont let me run it. I.e. it wont let me open up the mirror after i completed the steps and there is no system dialogue while running the command, as in it just skips to the next bar without any response to the user. it is also the same with the next command,
      sudo chmod u+s /opt/vc/bin/tvservice && sudo chmod u+s /bin/chvt
      thanks!
        sdetweil @PHAGE.GOV
        @PHAGE-GOV sorry, I don’t understand what you said
        Skips to the next bar?
        Can’t open mirror?
        Those commands don’t have a response.
        • P
          PHAGE.GOV
          so like when i type those commands in the terminal nothing will apear, is that normal?
          • BKeyportB
            BKeyport Module Developer @PHAGE.GOV
            @PHAGE-GOV yes.
            • cowboysdudeC
              cowboysdude Module Developer
              Depends on which pi and version of Raspbian you are running.
              • BKeyportB
                that first command is calling the WiringPi library, right? The one that’s no longer supported and don’t cover the last couple of Pi hardware releases?
