    Ideas Needed
    17 Posts 5 Posters 4.6k Views 5 Watching
      MilkShake
      So I build a magic mirror with MMM-AssistantMk2 and it works pretty good. I have the assistant/mirror integrated with the following:
      Roborock vacuumers (1 on each floor)
      Siemens EQ9 automatic coffeemachine
      Hue Lighting
      Video feed from the gate camera (doorbird 101D)
      So, I got the assistant to recognize the open gate “Open Gate” command and respond with “Ok, Opening the front gate”. However, in order to actually open the front gate, a HTTP GET needs to be sent to the gate camera. I can do that with a python script on the Raspberry PI, however in order to get the assistant to call that script I would need to do port forwards in my firewall, which I would rather not.
      I need some way to interact with the mirror, so it calls the python script. It could be a physical button but I am looking for alternatives.
      Does anyone have any ideas?
      Best
      MilkShake
        sdetweil @MilkShake
        @MilkShake why do you need a python script to issue a get?
        in javascript in a browser, use the builtin fetch function
        fetch(url).then((info){})
        as u have the javascript to issue a message. its a one liner, maybe 5… i don’t know what the python needs to do
        https://developer.mozilla.org/en-US/docs/Web/API/Fetch_API/Using_Fetch
          MilkShake
          It doesn’t really matter how I do it. The point is that it has to be done from LAN, so I need a way to interact with the mirror and get it to fire the script.
            MilkShake @sdetweil
            @sdetweil this is two lines:
            import requests
            x = requests.get('http://USERNAME:PASSWORD@192.168.1.XXX/bha-api/open-door.cgi')
            print(x.status_code)
              retroflex Project Sponsor Module Developer @MilkShake
              @MilkShake Isn’t the mirror on the same LAN? In that case you don’t have to do any port forwards.
                sdetweil @MilkShake
                @MilkShake right, but now you gotta figure out how to execute it and u can’t do that from the browser, so now you need a node_helper and all that communication, and launching the ting in the background, etc,etc,etc)
                  MilkShake @sdetweil
                  @sdetweil I’m not following your point. I get it that I could do the GET from javascript instead of running a script, but the rest you might elaborate a bit more on :)
                    sdetweil @MilkShake
                    @MilkShake show me your script that is called when the action occurs
                      MilkShake @sdetweil
                      @sdetweil my whole point is, since the action happens on the google assistant I would need to do port forwards in my firewall to be able to call a LAN URL with a GET method. I guess it would be possible to catch the event locally on the mirror and then call the python script or do the GET method in some other manner, but I don’t know how to do that.
                      One option would be to just add a physical button to the raspberry pi and when pressed it runs the GET method. It just annoys me that you can make the assistant understand a command, but not utilize it locally on LAN.
                        MilkShake @retroflex
                        @retroflex The mirror and the gate are on the same LAN. The assistant understands the “Open Gate” command and replies with “Ok, Opening the gate”, but if I were to use a Google Action to do the GET, it would come from the internet.
                        I don’t know how to catch the event locally on the mirror. If I did, I would just call the python script and the gate would open.
