    Ideas Needed
    17 Posts 5 Posters 4.2k Views 5 Watching
      sdetweil @MilkShake
      @MilkShake the actions run locally on the mirror, they are TRIGGERED from the module… not as callbacks I don’t think
      (i haven’t done that myself, but it seemed logical before) the old recipe stuff
      you just create a little script in maybe the new A2D but old assistant had it to to trigger events…
      here is fiddling with the radio on the mirror
      https://github.com/bugsounet/MMM-Assistant2Display/wiki/Radio_help
      • BKeyportB Offline
        BKeyport Module Developer
        How I do URL calls in python is through urllib.request - import that library then:
        urllib.request.urlopen("http://pi.hole:60001/remote?action=MONITORTOGGLE")
        Depends on how far outside you wanna go outside the MM ecosystem.
        edit: reminds me, I gotta re-write that for the new config, pi-hole and the mirror being two different units now.
          sdetweil @BKeyport
          @BKeyport but u have to use a helper to launch the python code…
          way overhead for a fetch or post
          • BKeyportB Offline
            @sdetweil True, if you’re staying in the MM ecosystem - in my case, I couldn’t get the modules I wanted to work the way I wanted, so I wrote up a python script to cover it, and it runs independently of MM
            He wanted a python method, so I gave him options.
            • ? Offline
              A Former User
              maybe by using traits (google actions)
              example of recipes there
              this doc can help to make it
                MilkShake
                I went the way of dataplicity.io/wormhole, NGINX, IFTTT and MMM-NotificationTrigger. That way I should be able to use a webhook to execute the python script.
                  MilkShake @Guest
                  @Bugsounet Thanks Bugs! I will look into that when I have time for it.
