    Ideas Needed
    17 Posts 5 Posters 5.9k Views 5 Watching
      sdetweil @MilkShake
      @MilkShake show me your script that is called when the action occurs
      M 1 Reply Last reply
        MilkShake @sdetweil
        @sdetweil my whole point is, since the action happens on the google assistant I would need to do port forwards in my firewall to be able to call a LAN URL with a GET method. I guess it would be possible to catch the event locally on the mirror and then call the python script or do the GET method in some other manner, but I don’t know how to do that.
        One option would be to just add a physical button to the raspberry pi and when pressed it runs the GET method. It just annoys me that you can make the assistant understand a command, but not utilize it locally on LAN.
          MilkShake @retroflex
          @retroflex The mirror and the gate are on the same LAN. The assistant understands the “Open Gate” command and replies with “Ok, Opening the gate”, but if I were to use a Google Action to do the GET, it would come from the internet.
          I don’t know how to catch the event locally on the mirror. If I did, I would just call the python script and the gate would open.
            sdetweil @MilkShake
            @MilkShake the actions run locally on the mirror, they are TRIGGERED from the module… not as callbacks I don’t think
            (i haven’t done that myself, but it seemed logical before) the old recipe stuff
            you just create a little script in maybe the new A2D but old assistant had it to to trigger events…
            here is fiddling with the radio on the mirror
            https://github.com/bugsounet/MMM-Assistant2Display/wiki/Radio_help
            • BKeyportB
              BKeyport Module Developer
              How I do URL calls in python is through urllib.request - import that library then:
              urllib.request.urlopen("http://pi.hole:60001/remote?action=MONITORTOGGLE")
              Depends on how far outside you wanna go outside the MM ecosystem.
              edit: reminds me, I gotta re-write that for the new config, pi-hole and the mirror being two different units now.
                sdetweil @BKeyport
                @BKeyport but u have to use a helper to launch the python code…
                way overhead for a fetch or post
                BKeyportB 1 Reply Last reply
                • BKeyportB
                  @sdetweil True, if you’re staying in the MM ecosystem - in my case, I couldn’t get the modules I wanted to work the way I wanted, so I wrote up a python script to cover it, and it runs independently of MM
                  He wanted a python method, so I gave him options.
                    A Former User
                    maybe by using traits (google actions)
                    example of recipes there
                    this doc can help to make it
                      MilkShake
                      I went the way of dataplicity.io/wormhole, NGINX, IFTTT and MMM-NotificationTrigger. That way I should be able to use a webhook to execute the python script.
                        MilkShake @Guest
                        @Bugsounet Thanks Bugs! I will look into that when I have time for it.
