    Ideas Needed
    17 Posts 5 Posters 4.6k Views 5 Watching
      retroflex Project Sponsor Module Developer @MilkShake
      @MilkShake Isn’t the mirror on the same LAN? In that case you don’t have to do any port forwards.
        sdetweil @MilkShake
        @MilkShake right, but now you gotta figure out how to execute it and u can’t do that from the browser, so now you need a node_helper and all that communication, and launching the ting in the background, etc,etc,etc)
          MilkShake @sdetweil
          @sdetweil I’m not following your point. I get it that I could do the GET from javascript instead of running a script, but the rest you might elaborate a bit more on :)
            sdetweil @MilkShake
            @MilkShake show me your script that is called when the action occurs
              MilkShake @sdetweil
              @sdetweil my whole point is, since the action happens on the google assistant I would need to do port forwards in my firewall to be able to call a LAN URL with a GET method. I guess it would be possible to catch the event locally on the mirror and then call the python script or do the GET method in some other manner, but I don’t know how to do that.
              One option would be to just add a physical button to the raspberry pi and when pressed it runs the GET method. It just annoys me that you can make the assistant understand a command, but not utilize it locally on LAN.
                MilkShake @retroflex
                @retroflex The mirror and the gate are on the same LAN. The assistant understands the “Open Gate” command and replies with “Ok, Opening the gate”, but if I were to use a Google Action to do the GET, it would come from the internet.
                I don’t know how to catch the event locally on the mirror. If I did, I would just call the python script and the gate would open.
                  sdetweil @MilkShake
                  @MilkShake the actions run locally on the mirror, they are TRIGGERED from the module… not as callbacks I don’t think
                  (i haven’t done that myself, but it seemed logical before) the old recipe stuff
                  you just create a little script in maybe the new A2D but old assistant had it to to trigger events…
                  here is fiddling with the radio on the mirror
                  https://github.com/bugsounet/MMM-Assistant2Display/wiki/Radio_help
                  • BKeyportB Offline
                    BKeyport Module Developer
                    How I do URL calls in python is through urllib.request - import that library then:
                    urllib.request.urlopen("http://pi.hole:60001/remote?action=MONITORTOGGLE")
                    Depends on how far outside you wanna go outside the MM ecosystem.
                    edit: reminds me, I gotta re-write that for the new config, pi-hole and the mirror being two different units now.
                      sdetweil @BKeyport
                      @BKeyport but u have to use a helper to launch the python code…
                      way overhead for a fetch or post
                      • BKeyportB Offline
                        @sdetweil True, if you’re staying in the MM ecosystem - in my case, I couldn’t get the modules I wanted to work the way I wanted, so I wrote up a python script to cover it, and it runs independently of MM
                        He wanted a python method, so I gave him options.
