    Ideas Needed
    17 Posts 5 Posters 5.9k Views 5 Watching
      MilkShake
      So I build a magic mirror with MMM-AssistantMk2 and it works pretty good. I have the assistant/mirror integrated with the following:
      Roborock vacuumers (1 on each floor)
      Siemens EQ9 automatic coffeemachine
      Hue Lighting
      Video feed from the gate camera (doorbird 101D)
      So, I got the assistant to recognize the open gate “Open Gate” command and respond with “Ok, Opening the front gate”. However, in order to actually open the front gate, a HTTP GET needs to be sent to the gate camera. I can do that with a python script on the Raspberry PI, however in order to get the assistant to call that script I would need to do port forwards in my firewall, which I would rather not.
      I need some way to interact with the mirror, so it calls the python script. It could be a physical button but I am looking for alternatives.
      Does anyone have any ideas?
      Best
      MilkShake
        sdetweil @MilkShake
        @MilkShake why do you need a python script to issue a get?
        in javascript in a browser, use the builtin fetch function
        fetch(url).then((info){})
        as u have the javascript to issue a message. its a one liner, maybe 5… i don’t know what the python needs to do
        https://developer.mozilla.org/en-US/docs/Web/API/Fetch_API/Using_Fetch
        M 1 Reply Last reply
          MilkShake
          It doesn’t really matter how I do it. The point is that it has to be done from LAN, so I need a way to interact with the mirror and get it to fire the script.
          R 1 Reply Last reply
            MilkShake @sdetweil
            @sdetweil this is two lines:
            import requests
            x = requests.get('http://USERNAME:PASSWORD@192.168.1.XXX/bha-api/open-door.cgi')
            print(x.status_code)
              retroflex Project Sponsor Module Developer @MilkShake
              @MilkShake Isn’t the mirror on the same LAN? In that case you don’t have to do any port forwards.
                sdetweil @MilkShake
                @MilkShake right, but now you gotta figure out how to execute it and u can’t do that from the browser, so now you need a node_helper and all that communication, and launching the ting in the background, etc,etc,etc)
                  MilkShake @sdetweil
                  @sdetweil I’m not following your point. I get it that I could do the GET from javascript instead of running a script, but the rest you might elaborate a bit more on :)
                    sdetweil @MilkShake
                    @MilkShake show me your script that is called when the action occurs
                      MilkShake @sdetweil
                      @sdetweil my whole point is, since the action happens on the google assistant I would need to do port forwards in my firewall to be able to call a LAN URL with a GET method. I guess it would be possible to catch the event locally on the mirror and then call the python script or do the GET method in some other manner, but I don’t know how to do that.
                      One option would be to just add a physical button to the raspberry pi and when pressed it runs the GET method. It just annoys me that you can make the assistant understand a command, but not utilize it locally on LAN.
                        MilkShake @retroflex
                        @retroflex The mirror and the gate are on the same LAN. The assistant understands the “Open Gate” command and replies with “Ok, Opening the gate”, but if I were to use a Google Action to do the GET, it would come from the internet.
                        I don’t know how to catch the event locally on the mirror. If I did, I would just call the python script and the gate would open.
                          sdetweil @MilkShake
                          @MilkShake the actions run locally on the mirror, they are TRIGGERED from the module… not as callbacks I don’t think
                          (i haven’t done that myself, but it seemed logical before) the old recipe stuff
                          you just create a little script in maybe the new A2D but old assistant had it to to trigger events…
                          here is fiddling with the radio on the mirror
                          https://github.com/bugsounet/MMM-Assistant2Display/wiki/Radio_help
                          • BKeyportB
                            BKeyport Module Developer
                            How I do URL calls in python is through urllib.request - import that library then:
                            urllib.request.urlopen("http://pi.hole:60001/remote?action=MONITORTOGGLE")
                            Depends on how far outside you wanna go outside the MM ecosystem.
                            edit: reminds me, I gotta re-write that for the new config, pi-hole and the mirror being two different units now.
                              sdetweil @BKeyport
                              @BKeyport but u have to use a helper to launch the python code…
                              way overhead for a fetch or post
                              BKeyportB 1 Reply Last reply
                              • BKeyportB
                                @sdetweil True, if you’re staying in the MM ecosystem - in my case, I couldn’t get the modules I wanted to work the way I wanted, so I wrote up a python script to cover it, and it runs independently of MM
                                He wanted a python method, so I gave him options.
                                  A Former User
                                  maybe by using traits (google actions)
                                  example of recipes there
                                  this doc can help to make it
                                    MilkShake
                                    I went the way of dataplicity.io/wormhole, NGINX, IFTTT and MMM-NotificationTrigger. That way I should be able to use a webhook to execute the python script.
                                      MilkShake @Guest
                                      @Bugsounet Thanks Bugs! I will look into that when I have time for it.
