    MMM-Admin-Interface
    29 Posts 12 Posters 36.4k Views 12 Watching
    • M
      mochman Module Developer
      You might also have to add "::ffff:192.168.X.Y" as well. You could also just add "192.168.X.1/24 , ::ffff:192.168.X.1/24" to whitelist all of the IPs in your network (assuming you are using 192.168.X.1-254).
      • R
        rubenlaureys
        I love your module!
        I use it to modify my MagicMirror.
        But, is there a way to choose a module from a list, instead of entering the name myself?
        I want a dropdown list, just like the list of positions.
        Is this possible?
        Thank you.
        Have a great day,
        Ruben
        I 1 Reply Last reply
        • I
          ItayXD @rubenlaureys
          @rubenlaureys
          I’m not sure what you mean, there should be a tab list with the modules names on the left like in this photo:
          is this not the case?
            shimue
            This post is deleted!
            strawberry 3.141S 1 Reply Last reply
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @shimue
              @shimue search for ip whitelist on the forum, there plenty of threads
                shimue
                Reply Quote -3
                • Sandy2503S
                  Sandy2503
                  @shimue - na dann hast DU das hier ja auch in deiner config.js stehen:
                  address:"0.0.0.0",
                  und achte mal auf deinen Ton …
                  Sandy2503
                  Reply Quote 1
                  • R
                    rockcitiman
                    Are you still developing this module? I followed all of the instructions but I get nothing.
                    A 1 Reply Last reply
                    • A
                      Arkitct @rockcitiman
                      @rockcitiman I had to modify the address: line above the ipWhitelist: entry as @Sandy2503 alluded. My line became:
                      address: ["localhost", "0.0.0.0"],
                      the localhost may be redundant with the 0.0.0.0, but it works nonetheless (the interface). But … the writing of the config file is in a format that bunged up my mm so it fails to display anything.
