MMM-remote-control api key
hi,
after the latest update of remote control some kind of api key is required. Can anybody tell me where I can get one? I tryed two evenings to solve this issue and didnt get it… pls help me…
@lampi why do you think an api key is required?
@sdetweil cause i have to change the config file and the guide says so
@lampi from the api/readme
Providing an API key is recommended; however, remains optional.
its for apps connecting to mirror… force THEM to have the api key…
additionally
If you ran the installer.sh script when you installed the module, a non-canoical UUID is generated for you to use; you can use this unique code,
or use any string you wish.
so, YOU make up the key string
the API key is for security - you don’t need it if you’re not needing that extra layer of security for remote control.
@sdetweil thank you! It worked :) I just had to delet the config line
hi sry me again. It worked for maybe three hours and now it says just loading… can you help me with this issue too?Lukas
