    MM cant boot, wont boot!
    40 Posts 5 Posters 20.3k Views 5 Watching
    • N Offline
      nicoz
      Complete noob here so please word your responses for 10 year olds :-)
      Recently my MagicMirror has been booting to a black sceen. A literal black screen, and the only way to remove it is to minimize the window.
      I think the problem started when i tried to update the program. I have tried since to update and think i have succeeded however now it seems not not boot at all. Even manually via SSH
      My pi just boots to the standard UI.
      Any Ideas???
        sdetweil @nicoz
        @nicoz if u updated, (git pull) did u npm install after?
        also, sometimes existing modules need to have their stuff refreshed after the base refreshes
        (all leading to black screen)
        I have a script for future updates that figures this all out…
        in the short term, make sure you did
        cd ~/MagicMirror
        npm install
        then check each module folder, and if there is an package.json file, also do the
        npm install
        for each such folder
        then restart mm
        • BKeyportB Online
          BKeyport Module Developer
          One other thing you can do is run “npm run config:check” in the magicmirror root directory (~/MagicMirror) - it’ll run through and see if there’s anything that’s slightly out of wack to blank the mirror but not out of wack enough to throw an error. It’s saved me lots of headaches several times.
          C 1 Reply Last reply Reply Quote 1
          • N Offline
            nicoz
            npm install seemed to work in that i dont get a black screen anymore.
            npm start will start the mirror but for some reason it wont stay open. i come back to the mirror and i am back at the Rasbian Home screen?
            i also tried config:check but i dont really know what im looking at
              sdetweil @nicoz
              @nicoz when u do npm start is shows messages to the screen…
              can you do
              npm start > somefile 2>&1
              and when it ends, look at somefile
              • C Offline
                Cyric @BKeyport
                @BKeyport said in MM cant boot, wont boot!:
                I am having this same issue. I ran the update and everything was fine except my calendar and the 2 day weather thing, which looks like a known bug. I rebooted and am only getting a black screen with the mouse cursor. I did some digging and ran the npm install on the main magic mirror directory, and the directories for the modules i’m using, and it’s still not working. I tried to do the npm run config:check and it came back with an error saying " > magicmirror@2.11.0 config:check /home/pi/MagicMirror
                node tests/configs/check_config.js
                internal/modules/cjs/loader.js:638
                throw err;
                Error: Cannot find module ‘/home/pi/MagicMirror/tests/configs/check_config.js’
                at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                at startup (internal/bootstrap/node.js:283:19)
                at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                npm ERR! code ELIFECYCLE
                npm ERR! errno 1
                npm ERR! magicmirror@2.11.0 config:check: node tests/configs/check_config.js
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the magicmirror@2.11.0 config:check script.
                npm ERR! /home/pi/.npm/_logs/2020-07-02T20_48_03_566Z-debug.log"
                  sdetweil @Cyric
                  @Cyric u ran the update? how?
                  S C 2 Replies Last reply Reply Quote 0
                    @sdetweil can u open the developers window, ctrl-shift-i, select the tab labeled console, and scroll up to see any errors
                    • C Offline
                      Cyric @sdetweil
                      @sdetweil I did git pull in the ~/MagicMirror parent directory. That gave me a few errors about changes, so i just did git pull --hard. Then I did npm install. For the other modules, i just did git pull and npm install.
                      • C Offline
                        Cyric
                        @sdetweil Im sorry, where do i do this at?
                          sdetweil @Cyric
                          @Cyric on the mirror black screen
                          • C Offline
                            Cyric @sdetweil
                            @sdetweil when I go into the developer console, it says " devtools was disconnected from the page. Once the page is reloaded, devtools will automatically reconnect."
                            If I x out of that and go to console, it’s empty.
                            • C Offline
                              Cyric
                              More troubleshooting: I deleted the config.js and it loaded and said I needed to load a config.js file. I loaded the sample one, and it went back ot being a black screen.
                                sdetweil @Cyric
                                @Cyric ok, where do u start mm? pm2 or nom start manually
                                if pm2 do
                                pm2 logs --lines=100
                                if nom start, the console output is right there.
                                let us know what u find
                                • C Offline
                                  Cyric @sdetweil
                                  @sdetweil Here is what it gave me when i tried npm start:
                                  "magicmirror@2.11.0 start /home/pi/MagicMirror
                                  DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                                  [2020-07-02 21:33:26.029] [LOG] Starting MagicMirror: v2.11.0
                                  [2020-07-02 21:33:26.054] [LOG] Loading config …
                                  [2020-07-02 21:33:26.071] [LOG] Loading module helpers …
                                  [2020-07-02 21:33:26.079] [LOG] No helper found for module: alert.
                                  [2020-07-02 21:33:26.249] [LOG] Initializing new module helper …
                                  [2020-07-02 21:33:26.251] [LOG] Module helper loaded: updatenotification
                                  [2020-07-02 21:33:26.253] [LOG] No helper found for module: clock.
                                  [2020-07-02 21:33:26.279] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘ical’
                                  Require stack:
                                  • /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js
                                  • /home/pi/MagicMirror/modules/default/calendar/node_helper.js
                                  • /home/pi/MagicMirror/js/app.js
                                  • /home/pi/MagicMirror/js/electron.js
                                  • /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                                  [2020-07-02 21:33:26.282] [LOG] Loading module helpers …
                                  [2020-07-02 21:33:26.284] [LOG] No helper found for module: alert.
                                  [2020-07-02 21:33:26.286] [LOG] Initializing new module helper …
                                  [2020-07-02 21:33:26.287] [LOG] Module helper loaded: updatenotification
                                  [2020-07-02 21:33:26.289] [LOG] No helper found for module: clock.
                                  [2020-07-02 21:33:26.300] [ERROR] App threw an error during load
                                  [2020-07-02 21:33:26.303] [ERROR] Error: Cannot find module ‘ical’
                                  Require stack:
                                  • at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                                    at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                                    at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                    at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                                    at Module.require (internal/modules/cjs/loader.js:685:19)
                                    at require (internal/modules/cjs/helpers.js:16:16)
                                    at Object. (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:8:14)
                                    at Module._compile (internal/modules/cjs/loader.js:786:30)
                                    at Object.Module._extensions…js (internal/modules/cjs/loader.js:798:10)
                                    at Module.load (internal/modules/cjs/loader.js:645:32)
                                    [2020-07-02 21:33:26.308] [ERROR] Whoops! There was an uncaught exception…
                                    [2020-07-02 21:33:26.310] [ERROR] Error: Cannot find module ‘ical’
                                    Require stack:
                                    at Module.load (internal/modules/cjs/loader.js:645:32) {
                                    code: ‘MODULE_NOT_FOUND’,
                                    requireStack: [
                                    ‘/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js’,
                                    ‘/home/pi/MagicMirror/modules/default/calendar/node_helper.js’,
                                    ‘/home/pi/MagicMirror/js/app.js’,
                                    ‘/home/pi/MagicMirror/js/electron.js’,
                                    ‘/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,
                                    undefined
                                    [2020-07-02 21:33:26.337] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                    [2020-07-02 21:33:26.338] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues"
                                    sdetweil @Cyric
                                    @Cyric >Cannot find module ‘ical’
                                    hm…
                                    the calendar reader module is not found
                                    can you do
                                    cd ~/MagicMirror
                                    rm package-lock.json
                                    rm -rf node_ modules
                                    npm install
                                    • C Offline
                                      Cyric
                                      I ran that, then did npm start again. It told me: "> magicmirror@2.11.0 start /home/pi/MagicMirror
                                      [2020-07-03 07:35:17.160] [ERROR] App threw an error during load
                                      [2020-07-03 07:35:17.189] [ERROR] Error: Cannot find module ‘/home/pi/MagicMirror/js/…/modules/default/defaultmodules.js’
                                      Require stack:
                                        at Object. (/home/pi/MagicMirror/js/app.js:12:22)
                                        at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                                        A JavaScript error occurred in the main process
                                        Uncaught Exception:
                                        Require stack:
                                        at Function.Module._load (internal/modules/cjs/loader.js:560:12)"
                                      Now it won’t load the black screen. I have not rebooted yet.
                                        sdetweil @Cyric
                                        @Cyric weird
                                        do
                                        cd ~/MagicMirror
                                        git checkout modules/default/defaultmodules.js
                                        then try npm start again
                                        • C Offline
                                          Cyric @sdetweil
                                          This post is deleted!
                                          • C Offline
                                            Cyric @sdetweil
                                            @sdetweil ok, progress. It started magic mirror with a black screen and no mouse. Before it was a black screen with the mouse, and it said electron instead of magic mirror 2. I rebooted and tried to reload my config.js, but it didn’t help.
