    disable NO signal message
    22 Posts 9 Posters 23.0k Views 8 Watching
      bibi
      My monitor is a philips and not so old but displays the message… so better not go for this brand.
      @broberg : that’s what i thought as well but was wondering if any solution may exist… thx for for reply.
        bibi
        small last question, is there a way to avoid all the boot up code scrolling when the Pi starts? 0_1483372291118_Capture d’écran 2017-01-02 à 16.48.01.png
        • bheplerB Offline
          bhepler Module Developer
          Yes, but it’s not recommended. Those messages are there in case there is a problem during boot.
          But if you really want it… Stack Exchange to the rescue. If that doesn’t do it for you, some quality time with Google and “Raspbery Pi silent boot” should get you there.
          Edit: It seems that someone on YouTube has also done this.
            bibi @bhepler
            @bhepler thx a lot for your reply/time :)
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @bibi
              @bibi the boot screen is replaced in the newest version if you are using the new raspbian version which is using PIXEL
                bibi @strawberry 3.141
                @strawberry-3.141 i am not using it yet but will def. check that :) thx
                can i have also your opinion regarding my 1st query pls?
                strawberry 3.141S lolobyteL 2 Replies Last reply Reply Quote 0
                  @bibi my monitor shows also no signal
                  • lolobyteL Offline
                    lolobyte @bibi
                    @bibi
                    You cam manage boot options in raspi-config if you don’t have install jessi light.
                    execute following command.
                    sudo raspi-config
                    chose menu point
                    3 Boot Options
                    3B Splash Screen
                    and activate it wit “YES”
                    save and reboot with
                    sudo reboot
                    Next topic:
                    My screen show me a message with no signal for approx. 5 sec.
                    After that, the screen is complete black and off.
                      bibi @lolobyte
                      @lolobyte many thx for this how to! :))
                        Deniz @broberg
                        @broberg thx for the reply.
                        Are you satisfied with the monitor you are using?
                        Could you tell me the model number?
                        lolobyteL 1 Reply Last reply Reply Quote 0
                        • 3 / 3
