    MMM-Remote-Control after upd MM to 2.1.0
    14 Posts 6 Posters 10.8k Views 6 Watching
      AAPS
      Why is this necessary? Do I only need to do it for the “helloworld” module?
      lolobyteL 1 Reply Last reply Reply Quote 0
      • lolobyteL Offline
        lolobyte @AAPS
        @AAPS
        Hello,
        No, it’s surly only a example for one Module.
        It was my intention with the command
        disabled: true,
        to quick disable a module in the config.js and not to comment out all single module step.
        The problem with the remote module is, the modules aren’t really disabled, they running in the background an slow down the system.!
          Jopyth Moderator
          Does anyone know, what causes the problem? How do I reproduce the issue? Just a random config with one module disabled? If someone has a working small example (config), please post here or in the github issue.
          I will see if I can fix it on the weekend.
          Helpful sticky: How to troubleshoot
          • lolobyteL Offline
            lolobyte @Jopyth
            @Jopyth
            This system doesen’t let me upload some file for you.
            The this way.
            Here is the sample config with issues.
            /* Magic Mirror Config Sample
            • By Michael Teeuw http://michaelteeuw.nl
            • MIT Licensed.
            var config = {
            port: 8080,
            ipWhitelist: [
            “127.0.0.1”,
            “::ffff:127.0.0.1”,
            “::1”,
            “::ffff:192.168.1.1/24”,
            language: ‘de’,
            timeFormat: 24,
            units: ‘metric’,
            		module: 'alert',
            		classes: 'small bright', // Add your own styling. Optional.
            		disabled: false,
            		module: "updatenotification",
            		position: "top_center",
            		disabled: false,
            		module: 'MMM-Advent',
            		position: 'bottom_center',
            		disabled: true,
            			updateInterval: 10 * 60 * 1000,
            			marks: 0, //default is 24
            			height: 300,
            			showFlameBeforeStart: false,
            //			start: ["2016-11-27 00:00:01", "2016-12-11 00:00:01", "2016-12-18 00:00:01", "2016-12-04 00:00:01"],
            //			end: ["2016-12-24 23:59:59", "2016-12-24 23:59:59", "2016-12-24 23:59:59", "2016-12-24 23:59:59"],
            			start: "2016-01-01 00:00:01", //Geburtstag Anfang
            			end: "2016-01-01 23:59:59", //Geburtstag Ende
            //			start: "2016-12-01 00:00:01", //Eine Kerze; default is "2016-12-01 08:00:00"
            //			end: "2016-12-24 23:59:59", //Eine Kerze; default is "2016-12-24 22:00:00"
            			enableAnimation: true,
            			fontColor: "#000000", //default is #000000 (black)
            			candleColor: "#FFFFFF", //default is #FFFFFF (white)
            		module: 'helloworld',
            		position: 'bottom_bar',
            		disabled: true,
            			text: 'Alles Gute!',
            		module: 'clock',
            		position: 'top_left',
            		disabled: false,
            			displaySeconds: true,
            			clockBold: false,
            			showDate: true,
            			displayType: 'digital', // Possible values: digital, analog, or both
            			analogSize: '190px',
            			analogFace: 'face-012', // 'simple' border, none, or face-### (value between 001 and 012)
            			analogPlacement: 'right', // top, right, bottom, or left
            			analogShowDate: 'top', // false, top or bottom
            			secondsColor: '#888888', // any HTML RGB Color
            	//		timezone: 'Etc/GMT+10', // America/New_York, America/Santiago, Etc/GMT+10
            		module: 'MMM-Remote-Control',
            		disabled: false,
            	//	uncomment the following line to show the URL of the remote control on the mirror
            		position: 'top_center'
            	//	you can hide this module afterwards from the remote control itself
            if (typeof module !== ‘undefined’) {module.exports = config;}
            and this one wich is running.
            • MIT Licensed.
            var config = {
            port: 8080,
            ipWhitelist: [
            “127.0.0.1”,
            “::ffff:127.0.0.1”,
            “::1”,
            language: ‘de’,
            timeFormat: 24,
            units: ‘metric’,
            		module: 'alert',
            		disabled: false,
            		disabled: false,
            	//	disabled: true, // verursacht Fehler in MMM-Remote-Control Modul
            			height: 300,
            		module: 'clock',
            		disabled: false,
            			clockBold: false,
            			showDate: true,
            		disabled: false,
            [0_1483538699038_config.js.bak-abgespeckt_01](Uploading 100%)
            [0_1483538731854_config.js.bak_abgespeckt_02](Uploading 100%)
