    MMM-GoogleAssistant not running
    55 Posts 5 Posters 24.0k Views 5 Watching
      A Former User
      Tu va etre connu !!! ton nickname est sur le Readme ! ;)
      W 1 Reply Last reply
        A Former User
        @wirdman : c’est good ?
        • W
          wirdman
          j ai essayé de voir un peut mais l’assistant fonctionne très bien mais il est incapable de lancer une video youtube ou de contrôler Spotify
          en revanche on peut caster sans problème
          Merci d’avance pour tout le travail que tu fais
          quand je lance une requete :
           transcription: { transcription: 'joue les beattles sur youtube', done: true },
            continue: false,
            volume: null,
            lastQuery: {
              type: 'MIC',
              key: null,
              lang: 'fr-FR',
              useScreenOutput: true,
              useAudioOutput: true,
              status: 'standby',
              chime: true
          • W
            wirdman @Guest
            @Bugsounet hahahaha incroyable pour le readme😁
            • blake_northrupB
              blake_northrup
              This morning I noticed that my MMM-GoogleAssistant needed an update, so I updated the module, and now get the black electron screen instead of the Magic Mirror screen. If I removed the module from the config, the Mirror comes up correctly, but when I add my config back, it goes black again. I have tried everything, from removing, then reinstalling, npm rebuild, electron rebuild, and nada. Was working fine until then. Any help would be greatly appreciated. See errors below:
              Module helper loaded: MMM-NowPlayingOnSpotify
              [2020-07-17 13:07:48.310] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
              Expected directory: electron-v6.1-linux-arm-glibc
              Found: [node-v72-linux-arm-glibc]
              This problem can often be fixed by running “npm rebuild” on the current system
              Original error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/node/extension_binary/electron-v6.1-linux-arm-glibc/grpc_node.node’
              Require stack:
              • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/grpc_extension.js
              • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/client_interceptors.js
              • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/client.js
              • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/index.js
              • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/google-assistant/components/assistant.js
              • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/google-assistant/index.js
              • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/components/assistant.js
              • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_helper.js
              • /home/pi/MagicMirror/js/app.js
              • /home/pi/MagicMirror/js/electron.js
              • /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
              [2020-07-17 13:07:48.311] [LOG] Loading module helpers …
              [2020-07-17 13:07:48.313] [LOG] No helper found for module: alert.
              [2020-07-17 13:07:48.314] [LOG] Initializing new module helper …
              [2020-07-17 13:07:48.314] [LOG] Module helper loaded: updatenotification
              [2020-07-17 13:07:48.315] [LOG] No helper found for module: clock.
              [2020-07-17 13:07:48.316] [LOG] Initializing new module helper …
              [2020-07-17 13:07:48.317] [LOG] Module helper loaded: calendar
              [2020-07-17 13:07:48.318] [LOG] No helper found for module: MMM-Rainbow.
              [2020-07-17 13:07:48.319] [LOG] No helper found for module: compliments.
              [2020-07-17 13:07:48.320] [LOG] Initializing new module helper …
              [2020-07-17 13:07:48.320] [LOG] Module helper loaded: MMM-SystemStats
              [2020-07-17 13:07:48.321] [LOG] Initializing new module helper …
              [2020-07-17 13:07:48.322] [LOG] Module helper loaded: MMM-Remote-Control
              [2020-07-17 13:07:48.323] [LOG] No helper found for module: currentweather.
              [2020-07-17 13:07:48.324] [LOG] No helper found for module: weatherforecast.
              [2020-07-17 13:07:48.325] [LOG] No helper found for module: MMM-EyeCandy.
              [2020-07-17 13:07:48.327] [LOG] Initializing new module helper …
              [2020-07-17 13:07:48.327] [LOG] Module helper loaded: MMM-NowPlayingOnSpotify
              [2020-07-17 13:07:48.352] [ERROR] App threw an error during load
              [2020-07-17 13:07:48.354] [ERROR] Error: Failed to load gRPC binary module because it was not installed for the current system
              Require stack:
              • at Object. (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/grpc_extension.js:53:17)
                at Module._compile (internal/modules/cjs/loader.js:786:30)
                at Object.Module._extensions…js (internal/modules/cjs/loader.js:798:10)
                at Module.load (internal/modules/cjs/loader.js:645:32)
                at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                at Module.require (internal/modules/cjs/loader.js:685:19)
                at require (internal/modules/cjs/helpers.js:16:16)
                at Object. (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/client_interceptors.js:144:12)
                [2020-07-17 13:07:48.356] [ERROR] Whoops! There was an uncaught exception…
                [2020-07-17 13:07:48.357] [ERROR] Error: Failed to load gRPC binary module because it was not installed for the current system
                Require stack:
                at Object.Module._extensions…js (internal/modules/cjs/loader.js:798:10) {
                code: ‘MODULE_NOT_FOUND’
                [2020-07-17 13:07:48.371] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                [2020-07-17 13:07:48.372] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                [2020-07-17 13:07:48.539] [LOG] Launching application.
              • W
                wirdman @blake_northrup
                @blake_northrup said in MMM-GoogleAssistant not running:
                do you have run
                npm run update
                in google assistant folder and Assistant2Display folder ?
                have it too but you can
                at you mmm-GoogleAssistant folder run
                npm install
                or
                npm rebuild
                blake_northrupB 1 Reply Last reply
                Reply Quote 1
                • blake_northrupB
                  blake_northrup @wirdman
                  @wirdman You are the man sir! Much appreciated wirdman!
                  • W
                    @blake_northrup did it work ?
                    • blake_northrupB
                      @wirdman Yep, all good. I just needed to do npm rebuild in the MMM-GoogleAssistant folder. I was doing it in the MagicMirror folder. Thanks again!
                      • W
                        wirdman
                        pleasure
                        Reply Quote 1
                        • W
                          @blake_northrup is it possible for you now his installed to ask him to go on youtube or control your spotify ?
                          • W
                            wirdman @Guest
                            This post is deleted!
                            • blake_northrupB
                              @wirdman Hey, sorry, been a very busy couple of days. I can use it to change lighting, turning off devices in smart home, but when I ask to play Spotify, it just gives me info about a video, but doesn’t play.
                              • W
                                @blake_northrup no problem.
                                okay but about youtube ?
                                • blake_northrupB
                                  @wirdman It doesn’t play videos either. It just gives a snippet of what I ask for, but no video.
                                  • W
                                    wirdman
                                    @Bugsounet @blake_northrup okay because for me now everything work welle but i cannot ask to my google to play something on spotify
                                    blake_northrupB S 2 Replies Last reply
                                    • blake_northrupB
                                      @wirdman Yeah, I will dig around a bit to see what I can come up with. At least mine is controlling my smart devices, so that works for now. Please let me know if you figure it out, and I will do the same.
                                        sdetweil @wirdman
                                        @wirdman can u use the windows Spotify connect to play Spotify on your mirror pi? ( I can)
                                        you have to install one of the Spotify system extensions to make play on pi work.
                                        I thought bugsounet said he updated the MMM-Spotify module to do that recently.
                                        • W
                                          wirdman @sdetweil
                                          this part ? cause i have mmm-spotify
                                            sdetweil @wirdman
                                            @wirdman no. the raspotify system extension
                                            https://pimylifeup.com/raspberry-pi-spotify/
                                            it is outside mm
                                            it is required to play Spotify on pi. with or without mm
                                            • 2 / 3
