    MMM-NewPIR v3
    67 Posts 18 Posters 40.3k Views 20 Watching
    • P
      philmavedzenge @DJBOOB66
      @djboob66 said in MMM-NewPIR v3:
      sudo npm install -g npm@6.14.15
      thank you guys very much, this worked for me
      • P
        philmavedzenge @Fozi
        @fozi i had used that script to update, i don’t know why it didn’t update the other components. Thanks a lot for your help
          sdetweil @philmavedzenge
          @philmavedzenge it doesn’t upgrade mode/npm
          install checks, upgrade does not (usually didn’t need to)
          • P
            philmavedzenge @sdetweil
            @sdetweil said in MMM-NewPIR v3:
            I see now. Thanks a lot for the help
            • uros76U
              uros76
              Hi. Does anyone know of a way to format “LastPresence” output? Default is a full date and time in one line however I would like to change the format of the output. Don’t see any config option to format it…
              My magicmirror projects: https://forum.magicmirror.builders/post/79889, https://forum.magicmirror.builders/post/93241 and https://forum.magicmirror.builders/post/94586
              • cowboysdudeC
                cowboysdude Module Developer @uros76
                @uros76 said in MMM-NewPIR v3:
                How would you like it formatted?
                uros76U 1 Reply Last reply Reply Quote 1
                • uros76U
                  uros76 @cowboysdude
                  @cowboysdude ideally I would like to specify the date/time format, like on a stock MM Clock module.
                  • 4 / 4
