    MMM-Events : nothing to display on my Magic Mirror
    20 Posts 3 Posters 4.0k Views 3 Watching
      RIKKO14
      Hello,
      I just installed the MMM-Events module and no events are displayed on my MM it remains blocked with “upcoming Events”:
      I created an API key :
      here is my config.js:
      				module: 'MMM-Events',
      				position: 'top_left',
      				city: "Caen",	           // Your City
      				eventType: "music,movies_film,art", // One or more, seperated by commas. Choose from Events List below
      				when: "This Week",                 // "All", "Future", "Past", "Today", "Last Week", "This Week", "Next week", and months by name, e.g. "October"
      				mode: "noFrame",                   // "Frame" or "noFrame" (around picture)
      				apikey: "Pq4n9Vh5zbshSVfS",
      				rotateInterval: 5 * 60 * 1000,     // New Event Appears every 5 minutes
      				useHeader: true,	           // Set to true if you want a header
      				header: "Spectacle a proximité",
      				animationSpeed: 3000,              // Event fades in and out
      				picture: true,                     // true, false = no image
      after typing the commands pm2 restart mm a reboot of my raspberry and created a new API Key always nothing…
      Can you help me ?
      pi@raspberrypi:~ $ pm2 logs
      [TAILING] Tailing last 15 lines for [all] processes (change the value with --lines option)
      /home/pi/.pm2/pm2.log last 15 lines:
      PM2        | 2020-09-05T17:41:28: PM2 log: SIGTERM timeout      : 1600
      PM2        | 2020-09-05T17:41:28: PM2 log: ===============================================================================
      PM2        | 2020-09-05T17:41:28: PM2 log: App [mm:0] starting in -fork mode-
      PM2        | 2020-09-05T17:41:28: PM2 log: App [mm:0] online
      PM2        | 2020-09-05T17:48:17: PM2 log: Stopping app:mm id:0
      PM2        | 2020-09-05T17:48:18: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
      PM2        | 2020-09-05T17:48:18: PM2 log: pid=566 msg=process killed
      PM2        | 2020-09-05T17:48:18: PM2 log: App [mm:0] starting in -fork mode-
      PM2        | 2020-09-05T17:48:18: PM2 log: App [mm:0] online
      PM2        | 2020-09-05T17:55:58: PM2 log: Stopping app:mm id:0
      PM2        | 2020-09-05T17:55:58: PM2 log: pid=7550 msg=failed to kill - retrying in 100ms
      PM2        | 2020-09-05T17:55:58: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
      PM2        | 2020-09-05T17:55:58: PM2 log: pid=7550 msg=process killed
      PM2        | 2020-09-05T17:55:58: PM2 log: App [mm:0] starting in -fork mode-
      PM2        | 2020-09-05T17:55:59: PM2 log: App [mm:0] online
      /home/pi/.pm2/logs/mm-error.log last 15 lines:
      0|mm       | npm ERR! errno 1
      0|mm       | npm ERR! magicmirror@2.12.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      0|mm       | npm ERR! Exit status 1
      0|mm       | npm ERR!
      0|mm       | npm ERR! Failed at the magicmirror@2.12.0 start script.
      0|mm       | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      0|mm       |
      0|mm       | npm ERR! A complete log of this run can be found in:
      0|mm       | npm ERR!     /home/pi/.npm/_logs/2020-09-05T15_41_17_727Z-debug.log
      0|mm       | [2020-09-05 17:41:45.213] [ERROR]  (node:712) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
      0|mm       | [2020-09-05 17:41:45.215] [ERROR]  (node:712) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
      0|mm       | [2020-09-05 17:48:27.538] [ERROR]  (node:7571) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
      0|mm       | [2020-09-05 17:48:27.540] [ERROR]  (node:7571) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
      0|mm       | [2020-09-05 17:56:11.781] [ERROR]  (node:14911) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
      0|mm       | [2020-09-05 17:56:11.782] [ERROR]  (node:14911) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
      /home/pi/.pm2/logs/mm-out.log last 15 lines:
      0|mm       | [2020-09-05 17:56:17.441] [LOG]    [SNOWBOY] snowboy v1.6.2 Initialized...
      0|mm       | [2020-09-05 17:56:17.442] [LOG]    [@bugsounet] *************************
      0|mm       | [2020-09-05 17:56:17.443] [LOG]    [@bugsounet] Special note to @ktoanlba89 (https://github.com/ktoanlba89)
      0|mm       | [2020-09-05 17:56:17.444] [LOG]    [@bugsounet] Copying does not pay!
      0|mm       | [2020-09-05 17:56:17.444] [LOG]    [@bugsounet] Try to make your own before delete my username !
      0|mm       | [2020-09-05 17:56:17.445] [LOG]    [@bugsounet] Don't play with me guy !
      0|mm       | [2020-09-05 17:56:17.446] [LOG]    [@bugsounet] *************************
      0|mm       | [2020-09-05 17:56:17.459] [LOG]    [ASSISTANT] RECIPE_LOADED: with-MMM-TelegramBot.js
      0|mm       | [2020-09-05 17:56:17.468] [LOG]    [ASSISTANT] Assistant2Display Server Started
      0|mm       | [2020-09-05 17:56:17.475] [LOG]    [ASSISTANT] Use native program (mpg321) for audio response
      0|mm       | [2020-09-05 17:56:17.491] [LOG]    [SOUND] mpg321 Initialized
      0|mm       | [2020-09-05 17:56:17.509] [LOG]    [NPM] Initialized v0.9.6
      0|mm       | [2020-09-05 17:56:18.054] [LOG]    [ASSISTANT] Google Assistant is initialized.
      0|mm       | [2020-09-05 17:56:22.160] [LOG]    Requests available: 8
      0|mm       | [2020-09-05 17:56:32.245] [LOG]    Requests available: 6
      0|mm  | [2020-09-05 17:56:42.172] [LOG]
      0|mm  | Requests available: 4
      0|mm  | [2020-09-05 17:56:52.147] [LOG]
      0|mm  | Requests available: 2
      0|mm  | [2020-09-05 17:57:02.245] [LOG]
      0|mm  | Requests available: 0
      0|mm  | [2020-09-05 17:57:12.155] [LOG]
      0|mm  | An error occured while requesting the API for Data: Error: Request failed with status code 429
      0|mm  | [2020-09-05 17:57:12.155] [LOG]    URL: http://api.football-data.org/v2/competitions/FL1/matches
      0|mm  | [2020-09-05 17:57:12.156] [LOG]    429: API Request Quota of 10 calls per minute exceeded. Try selecting less leagues.
      0|mm  | [2020-09-05 17:57:12.194] [LOG]
      0|mm  | [2020-09-05 17:57:12.201] [LOG]
      0|mm  | URL: http://api.football-data.org/v2/competitions/FL1/standings
      0|mm  | [2020-09-05 17:57:12.207] [LOG]
      0|mm  | 429: API Request Quota of 10 calls per minute exceeded. Try selecting less leagues.
        RIKKO14
        by changing the city “Caen” (I live in Caen in Normandy) for “Paris”, it works, it is therefore my city which is not recognized.
        Any idea to solve the problem ?
          Mykle1 Project Sponsor Module Developer @RIKKO14
          @RIKKO14 said in MMM-Events : nothing to display on my Magic Mirror:
          If the api does not recognize your city then you will have to choose a city as close to you as possible that does work. This is not something that can be fixed by the module, sorry.
            RIKKO14
            however when I go to the website: https://eventful.com/caen/events
            I did have some results (I tried eventful Movies but nothing found even in Paris …).
            Maybe it’s a city precision problem? if MMM-Events could specify “city, country” (Caen, France), that might work, right?
              @RIKKO14
              In theory, yes, but it does not seem to accept Caen, France.
              From the api documentation:
              location string
              A location name to use in filtering the search results. Locations in the form “San Diego”, “San Diego, TX”, “London, United Kingdom”, and “Calgary, Alberta, Canada” are accepted, as are postal codes (“92122”) and venue IDs (“V0-001-000268633-5”). Common geocoordinate formats (“32.746682, -117.162741”) are also accepted, but the “within” parameter is required in order to set a search radius. (optional)
                RIKKO14
                @Mykle1
                and how to put the «within» parameter with the Common geocoordinate formats (“32.746682, -117.162741”) ? it’s more easier with this.
                (optional) = it’s a eventful option ? I’m not a developper so I can’t modify the module.
                Mykle1M 2 Replies Last reply Reply Quote 0
                  @RIKKO14
                  I will take a look at it when I have the time.
                    @RIKKO14
                    Ok, I’ve updated the module and tested it for your area. Run git pull in the MMM-Events directory. Things to mention:
                    1. Use the new config entry. I used the coordinates for Caen, France.
                    2. There are not many ‘hits’ for your area. Try using different eventType’s in the config.
                    3. Increase the radius for possibly more events. I set it to 100km.
                    4. There is a placeholder image for when the api does not provide an image for the event.
                      Mykle1 Project Sponsor Module Developer @Mykle1
                      @Mykle1
                      Regarding item #4 in my previous post. If you would rather use a placeholder image of your own (for when the api does not provide an image) you can make or find one and name it ‘go.jpg’. Put that in the modules ‘icons’ folder. However, I caution you to make the replacement image the same dimensions as the default image. Otherwise, the formatting of the module may get screwed up.
                        RIKKO14
                        I 've made a mistacke but I don’t know where :
                        As you said I run git pull
                        pi@raspberrypi:~/MagicMirror/modules/MMM-GoogleAssistant $ cd ~/MagicMirror/modules/MMM-Events
                        pi@raspberrypi:~/MagicMirror/modules/MMM-Events $ git pull
                        Mise à jour 2522a1a..384b255
                        Fast-forward
                         MMM-Events.js | 85 +++++++++++++++++++++++++++++++----------------------------
                         README.md     | 52 ++++++++++++++++++------------------
                         2 files changed, 71 insertions(+), 66 deletions(-)
                        pi@raspberrypi:~/MagicMirror/modules/MMM-Events $ pm restart mm
                        bash: pm : commande introuvable
                        pi@raspberrypi:~/MagicMirror/modules/MMM-Events $ pm2 restart mm
                        I change in my config.js :
                        city:"49.1811, -0.375565",
                        but I have this : it is not events for Caen :
                        [url=https://zupimages.net/viewer.php?id=20/37/65ps.png][img]https://zupimages.net/up/20/37/65ps.png[/img][/url]
                        if i change config.js :
                        city:"Caen, France", : it’s doesn’t work
                        and how to Increase the radius ?
                        Mykle1M S 3 Replies Last reply Reply Quote 0
                          @RIKKO14
                          Using your city:"49.1811, -0.375565", I get this:
                          If the api has no data (events) for Caen, that can not be helped.
                          When I use city:"Caen, France", I get this:
                          So, the module is working. I added the ability to use coordinates for you. If the api does not give back events for those coordinates it means the api does not have data in the free api for that location. I suggested you increase the radius and you asked, ‘and how to Increase the radius ?’ My answer to that is, Look at the new config in the readme. I mentioned that 2 posts above.
                          No, you haven’t. You showed me that the module is working. You’re just not seeing the results you expected
                            sdetweil @RIKKO14
                            @RIKKO14 from the code
                            city: "", // Your City or lat,long ex "40.123456,-74.123456",
                            radius: "", // search radius
                            radiusDistance:"",
                            so in config.js for this module in it config section
                            radius:???
                            radiusDistance: “km”, or “miles”
                              This post is deleted!
                                @RIKKO14
                                This is what you should have used. From the readme:
                                    position: 'top_right',
                                        city: "49.1829,0.3707", // "new york", or lat,long ex "40.123456,-74.123456",
                                        radius: "100", // search radius
                                        radiusDistance: "km", // mi or km
                                        eventType: "music,movies_film,art,sports", // Choose from Events List below
                                        apikey: "YOUR API KEY",
                                  RIKKO14
                                  this is my config.js :
                                  				disabled: false,
                                  					city: "caen, france", // "new york", or lat,long ex "40.123456,-74.123456",
                                  					radius: "50", // search radius
                                  					eventType: "music", // Choose from Events List below
                                  					rotateInterval: 15 * 1000,     // New Event Appears every 5 minutes
                                  					picture: false,                     // true, false = no image
                                  and the problem still here…
                                  when I use the gps coordinates of caen (49.1811, -0.3712) it’s the same …
                                  I uninstalled and reinstalled the module, + git pull and nmp install: still the same …
                                  I tried with the gps coordinates of several cities: Las Vegas, Baltimore, New york, Paris, Lyon, Toulouse it works, with Marseille (the 2nd city in France in population it does not work …), the same for Rouen a city 130 kms from Caen and larger that does not work …
                                  If I put 200 km of radius the module comes to look for concerts in Paris.
                                  However on the Eventful site there are many concerts of music displayed (even if there are not many posted concerning the largest concert hall compared to the concerts displayed on the concert hall’s website. ).
                                  it’s incomprehensible and crazy …
                                  There is indeed an error when you put “Caen, France” because on your photo posted above it says “Brussel Ouderenplatform” and Brussel is the capital of Belgium so nothing to do with demand …
                                  same, when you using : “49.1811, -0.375565” for Caen,
                                  the sainte thérèse basilica is in Lisieux (town 67 km from Caen) with a population of 20,771 inhabitants while CAEN has a population of over 100,000 inhabitants.
                                    @RIKKO14
                                    Copy and pasted from my earlier post.
                                      RIKKO14
                                      So if I understand correctly we can consult the various concerts (not exhaustive) in caen for free on the eventful site, but that this is not available with the free API. it would take a paid API to do it … Thank you for your feedback, I understand better even if I find it a little weird.
                                      thanks you.
                                        Not necessarily. Possible. I would inquire with them before paying anything.
                                        It IS weird but the module can only display the data that is given.
                                          RIKKO14
                                          Great, thank you for your approach. Please keep me posted when you get a response from them.
                                            Uhhhhhhhh
