    How to set Font in Alarm Clock
    13 Posts 4 Posters 8.6k Views 3 Watching
    • N Offline
      nobita
      In alarm clock module in Title and Message in alarms config I would like to know how to adjust Bigger Font size and Color Font
      Thanks for all helps
      • brobergB Offline
        broberg Project Sponsor
        if it is the MMM-AlarmClock that you are referring to then in custom.css add
        .MMM-AlarmClock .small {
          font-color: #59F;
          font-size: 10px;
        N 2 Replies Last reply Reply Quote 0
        • N Offline
          nobita @broberg
          @broberg Thanks for your hint , I will try later
          • N Offline
            nobita @broberg
            @broberg Sorry your hints is font header of AlarmClock . but I mean When alarmclock is working like photo post
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @nobita
              @nobita the alarm clock sends a notification to the alert module which displays this, so you have to change the css for the alert module:
              custom.css
              .alert span.light {
                //Here you can change the title
              .alert span.thin {
                //Here you can change the message
              N 1 Reply Last reply Reply Quote 1
              • N Offline
                nobita @strawberry 3.141
                @strawberry-3.141 not work, thanks
                  @nobita ok it doesnt render in the module itself try .ns-box-inner span.light
                  • brobergB Offline
                    broberg Project Sponsor @strawberry 3.141
                    @strawberry-3.141 said in How to set Font in Alarm Clock:
                    I installed the module just to test it, I also noticed the .ns-box-inner
                    but, something is overwriting font-size, font-color
                    I’ve managed to change the color by using .ns-box-inner span.light {color: #00F;}
                    but changing that to font-color will go back to the original colors.
                    morozgrafixM 1 Reply Last reply Reply Quote 0
                    • morozgrafixM Offline
                      morozgrafix Moderator @broberg
                      @strawberry-3.141 & @broberg I believe that default alert module has inline styles for alerts and notifications that would override any CSS that is set outside of it.
                      For example take a look at https://github.com/MichMich/MagicMirror/blob/master/modules/default/alert/alert.js#L39
                      		if (message.title) {
                      			msg += "<span class='thin' style='line-height: 35px; font-size:24px' color='#4A4A4A'>" + message.title + "</span>";
                      		if (message.message){
                      			if (msg != ""){
                      				msg+= "<br />";
                      			msg += "<span class='light' style='font-size:28px;line-height: 30px;'>" + message.message + "</span>";
                      and https://github.com/MichMich/MagicMirror/blob/master/modules/default/alert/alert.js#L81
                      		if (params.title) {
                      			message += "<span class='light' style='line-height: 35px; font-size:30px' color='#4A4A4A'>" + params.title + "</span>"
                      		if (params.message) {
                      			if (message != ""){
                      				message += "<br />";
                      			message += "<span class='thin' style='font-size:22px;line-height: 30px;'>" + params.message + "</span>";
                      I believe that most elegant way of fixing it is to move those styles into CSS file and have ability to override it in custom.css or other file.
                      strawberry 3.141S brobergB 2 Replies Last reply Reply Quote 2
                        strawberry 3.141 Project Sponsor Module Developer @morozgrafix
                        @morozgrafix thats correct, another possibility could be !important
                        • brobergB Offline
                          broberg Project Sponsor @morozgrafix
                          @morozgrafix I actually tried changing the font-size in the .js file, but no go, still the size is unaffected,
                          adding !important to font-size works
                          Edit, it works when you change the correct line. sorry my mistake, so we can conclude that it is as morozgrafix says, the inline style overwrites the css files.
                          So a quick fix would be to just use !important in the css
                          And Then someone can make a pull request on the default module to remove the inline styles and add it to the css file instead
                          morozgrafixM 1 Reply Last reply Reply Quote 1
                          • brobergB Offline
                            @morozgrafix was totally right, edited my post above
                              @broberg I agree with you and think that getting rid of those inline styles is the best long term solution
