    Update auf 2.13.0
    65 Posts 4 Posters 24.8k Views 4 Watching
    • kusselinK Offline
      kusselin
      @sdetweil said in Update auf 2.13.0:
      git remote prune origin
      pi@raspberrypi:~ $ cd MagicMirror
      pi@raspberrypi:~/MagicMirror $ git gc --prune=now
      fatal: bad object refs/tags/v2.12.0
      fatal: failed to run repack
      pi@raspberrypi:~/MagicMirror $ git remote prune origin
      pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
      No LSB modules are available.
      doing test run = true, NO updates will be applied!
      update log will be in /home/pi/MagicMirror/installers/upgrade.log
      saving custom.css
      upgrading from version 2.9.0 to 2.13.0
      fetching latest revisions
      error: cannot lock ref 'refs/tags/v2.12.0': unable to resolve reference 'refs/tags/v2.12.0': reference broken
      From https://github.com/MichMich/MagicMirror
       ! [new tag]           v2.12.0    -> v2.12.0  (unable to update local ref)
      MagicMirror git fetch failed
      restoring custom.css
        sdetweil
        ok, another try
        git remote set-head origin --auto
        git gc --prune=now
        • kusselinK Offline
          kusselin
          saving custom.css
          Wo ist das Problem…ist klar…bei mir läuft nie was auf Anhieb :-(
          der Pi ist auf aktuellem Stand mit update && upgrade
            sdetweil
            something has happened to the git repo, it has lost a reference
            we are trying to clean it up
            one more time (note there is a dot in front of git/)
            mv .git/refs/remotes/origin/HEAD /tmp
            git gc --prune=now
            • kusselinK Offline
              kusselin
              the same :-(
              pi@raspberrypi:~/MagicMirror $ mv .git/refs/remotes/origin/HEAD /tmp
              saving custom.css
                sdetweil @kusselin
                @kusselin ok… show me results of
                git branch
                git remote -v
                I’m not a git guru, so struggling to find solution
                • kusselinK Offline
                  kusselin
                  You are the best!!!
                  pi@raspberrypi:~/MagicMirror $ git branch
                  * master
                  pi@raspberrypi:~/MagicMirror $ git remote -v
                  origin  https://github.com/MichMich/MagicMirror.git (fetch)
                  origin  https://github.com/MichMich/MagicMirror.git (push)
                    sdetweil @kusselin
                    @kusselin ok, ONE more try
                    git update-ref -d 'refs/remotes/origin/HEAD'
                    git prune
                    git gc
                    then try again
                    • kusselinK Offline
                      kusselin
                      git gc
                      pi@raspberrypi:~/MagicMirror $ git update-ref -d 'refs/remotes/origin/HEAD'
                      pi@raspberrypi:~/MagicMirror $ git prune
                      fatal: Konnte Objekt 'refs/tags/v2.12.0' nicht parsen.
                      saving custom.css
                        sdetweil @kusselin
                        @kusselin said in Update auf 2.13.0:
                        refs/tags/v2.12.0
                        man, what a challenge
                        rm -rf .git/refs/tags/v2.12.0
                        git prune
                        git gc
                        then try again
                        • 6
                        • 7
                        • 2 / 7
