    Update auf 2.13.0
    65 Posts 4 Posters 27.6k Views 4 Watching
      sdetweil @kusselin
      @kusselin the updateNotification module if u don’t use it, u can disable it.
      add
      module:"updatenotification",
      disabled: true,       // < this line
      • kusselinK Offline
        kusselin
        the screen is always black :-(
        i ihink i have to save the config and i have to install magic mirror new…
        what do you think?
        • kusselinK Offline
          kusselin
          after a new installation…can i also copie the save config and all is good?
            sdetweil @kusselin
            @kusselin upgrade didn’t touch the config, it should be the same as before
              sdetweil @kusselin
              @kusselin if a NEW install, then u would have to reinstall all the modules and update the config
              • kusselinK Offline
                kusselin
                @sdetweil said in Update auf 2.13.0:
                o.k i musst have to install all the modules again and then i can copie the config in the config folder…right?
                And please can you send me a link how i can install about the console the ltest magic mirror please…
                • kusselinK Offline
                  kusselin
                  can you tell me why the screen is now black?
                    sdetweil @kusselin
                    @kusselin install is the same place u got the upgrade script
                    why are u trying to install again??
                    black screen
                    probably one of the lang files with comments
                    switch to the develop branch
                    git checkout develop
                    • kusselinK Offline
                      kusselin
                      o.k. can you help me once again please that i have a picture…
                      pi@raspberrypi:~ $ cd MagicMirror
                      pi@raspberrypi:~/MagicMirror $ git checkout develop
                      error: Pfadspezifikation 'develop' stimmt mit keinen git-bekannten Dateien überein.
                        sdetweil @kusselin
                        @kusselin see here
                        https://forum.magicmirror.builders/topic/13774/2-13-back-screen-translation-file-error-fix/2
                        • kusselinK Offline
                          kusselin
                          sorry…its not going with:
                          cd ~/MagicMirror
                          git fetch origin develop:develop
                          after a restart i see fast an white screen and the the black screen :-( and nothing happend
                            sdetweil @kusselin
                            @kusselin open the developers console, ctrl-shit-i on the mirror, or chrome from your pc if allowed,
                            select the tab labeled ‘console’, and scroll up to see any errors…
                            • kusselinK Offline
                              kusselin
                              i can´t see a mistake…you?
                                sdetweil @kusselin
                                @kusselin select the tab labeled ‘console’,
                                • kusselinK Offline
                                  kusselin
                                  i haven´t it
                                    sdetweil @kusselin
                                    @kusselin this is ON the mirror system right?
                                    or you did
                                    address: "0.0.0.0",
                                    ipWhitelist:[],
                                    or your pi, so you can open browser from pc
                                    • kusselinK Offline
                                      kusselin
                                      Initializing MagicMirror. main.js:487:8
                                      Loading core translation file: translations/de.json translator.js:129:9
                                      Loading core translation fallback file: translations/en.json translator.js:154:9
                                      Load script: modules/default/alert//alert.js loader.js:176:9
                                      Module registered: alert module.js:513:6
                                      Bootstrapping module: alert loader.js:148:7
                                      Load script: modules/default/alert/notificationFx.js loader.js:176:9
                                      Scripts loaded for: alert loader.js:153:8
                                      Load stylesheet: modules/default/alert/notificationFx.css loader.js:195:9
                                      Load stylesheet: vendor/css/font-awesome.css loader.js:195:9
                                      Styles loaded for: alert loader.js:155:9
                                      alert - Load translation: translations/de.json translator.js:100:9
                                      alert - Load translation fallback: translations/en.json translator.js:102:9
                                      Translations loaded for: alert loader.js:157:10
                                      Load script: modules/default/updatenotification//updatenotification.js loader.js:176:9
                                      Module registered: updatenotification module.js:513:6
                                      Bootstrapping module: updatenotification loader.js:148:7
                                      Scripts loaded for: updatenotification loader.js:153:8
                                      Styles loaded for: updatenotification loader.js:155:9
                                      Translations loaded for: updatenotification loader.js:157:10
                                      Load script: modules/default/clock//clock.js loader.js:176:9
                                      Module registered: clock module.js:513:6
                                      Bootstrapping module: clock loader.js:148:7
                                      Load script: vendor/node_modules/moment/min/moment-with-locales.js loader.js:176:9
                                      Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js loader.js:176:9
                                      Load script: vendor/node_modules/suncalc/suncalc.js loader.js:176:9
                                      Scripts loaded for: clock loader.js:153:8
                                      Load stylesheet: modules/default/clock/clock_styles.css loader.js:195:9
                                      Styles loaded for: clock loader.js:155:9
                                      Translations loaded for: clock loader.js:157:10
                                      Load script: modules/default/calendar//calendar.js loader.js:176:9
                                      Module registered: calendar module.js:513:6
                                      Bootstrapping module: calendar loader.js:148:7
                                      File already loaded: moment.js loader.js:236:9
                                      Scripts loaded for: calendar loader.js:153:8
                                      Load stylesheet: modules/default/calendar/calendar.css loader.js:195:9
                                      File already loaded: font-awesome.css loader.js:236:9
                                      Styles loaded for: calendar loader.js:155:9
                                      Translations loaded for: calendar loader.js:157:10
                                      File already loaded: calendar.css loader.js:236:9
                                      Load script: modules/MMM-OpenmapWeather//MMM-OpenmapWeather.js loader.js:176:9
                                      Module registered: MMM-OpenmapWeather module.js:513:6
                                      Bootstrapping module: MMM-OpenmapWeather loader.js:148:7
                                      Scripts loaded for: MMM-OpenmapWeather loader.js:153:8
                                      Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css loader.js:195:9
                                      Load stylesheet: modules/MMM-OpenmapWeather/MMM-OpenmapWeather.css loader.js:195:9
                                      Styles loaded for: MMM-OpenmapWeather loader.js:155:9
                                      Translations loaded for: MMM-OpenmapWeather loader.js:157:10
                                      Load script: modules/default/weatherforecast//weatherforecast.js loader.js:176:9
                                      Module registered: weatherforecast module.js:513:6
                                      Bootstrapping module: weatherforecast loader.js:148:7
                                      Scripts loaded for: weatherforecast loader.js:153:8
                                      File already loaded: weather-icons.css loader.js:236:9
                                      Load stylesheet: modules/default/weatherforecast/weatherforecast.css loader.js:195:9
                                      Styles loaded for: weatherforecast loader.js:155:9
                                      Translations loaded for: weatherforecast loader.js:157:10
                                      Load script: modules/MMM-Remote-Control//MMM-Remote-Control.js loader.js:176:9
                                      Check MagicMirror version for module 'MMM-Remote-Control' - Minimum version:  2.4.0 - Current version: 2.13.0 module.js:505:7
                                      Version is ok! module.js:507:8
                                      Module registered: MMM-Remote-Control module.js:513:6
                                      Bootstrapping module: MMM-Remote-Control loader.js:148:7
                                      Scripts loaded for: MMM-Remote-Control loader.js:153:8
                                      Load stylesheet: modules/MMM-Remote-Control/remote-control.css loader.js:195:9
                                      Styles loaded for: MMM-Remote-Control loader.js:155:9
                                      Translations loaded for: MMM-Remote-Control loader.js:157:10
                                      Load script: modules/MMM-SoccerLiveScore//MMM-SoccerLiveScore.js loader.js:176:9
                                      Module registered: MMM-SoccerLiveScore module.js:513:6
                                      Bootstrapping module: MMM-SoccerLiveScore loader.js:148:7
                                      Scripts loaded for: MMM-SoccerLiveScore loader.js:153:8
                                      Load stylesheet: modules/MMM-SoccerLiveScore/MMM-SoccerLiveScore.css loader.js:195:9
                                      Styles loaded for: MMM-SoccerLiveScore loader.js:155:9
                                      Translations loaded for: MMM-SoccerLiveScore loader.js:157:10
                                      Load script: modules/MMM-Tankerkoenig//MMM-Tankerkoenig.js loader.js:176:9
                                      Check MagicMirror version for module 'MMM-Tankerkoenig' - Minimum version:  2.2.0 - Current version: 2.13.0 module.js:505:7
                                      Module registered: MMM-Tankerkoenig module.js:513:6
                                      Bootstrapping module: MMM-Tankerkoenig loader.js:148:7
                                      Scripts loaded for: MMM-Tankerkoenig loader.js:153:8
                                      Load stylesheet: modules/MMM-Tankerkoenig/MMM-Tankerkoenig.css loader.js:195:9
                                      Styles loaded for: MMM-Tankerkoenig loader.js:155:9
                                      MMM-Tankerkoenig - Load translation: i18n/de.json translator.js:100:9
                                      MMM-Tankerkoenig - Load translation fallback: i18n/en.json translator.js:102:9
                                      Translations loaded for: MMM-Tankerkoenig loader.js:157:10
                                      Load script: modules/MMM-SmartWebDisplay//MMM-SmartWebDisplay.js loader.js:176:9
                                      Module registered: MMM-SmartWebDisplay module.js:513:6
                                      Bootstrapping module: MMM-SmartWebDisplay loader.js:148:7
                                      Scripts loaded for: MMM-SmartWebDisplay loader.js:153:8
                                      Load stylesheet: modules/MMM-SmartWebDisplay/MMM-SmartWebDisplay.css loader.js:195:9
                                      Styles loaded for: MMM-SmartWebDisplay loader.js:155:9
                                      Translations loaded for: MMM-SmartWebDisplay loader.js:157:10
                                      Load script: modules/MMM-ioBroker//MMM-ioBroker.js loader.js:176:9
                                      Module registered: MMM-ioBroker module.js:513:6
                                      Bootstrapping module: MMM-ioBroker loader.js:148:7
                                      Scripts loaded for: MMM-ioBroker loader.js:153:8
                                      Load stylesheet: modules/MMM-ioBroker/MMM-ioBroker.css loader.js:195:9
                                      Styles loaded for: MMM-ioBroker loader.js:155:9
                                      Translations loaded for: MMM-ioBroker loader.js:157:10
                                      Load script: modules/MMM-FRITZ-Box-Callmonitor//MMM-FRITZ-Box-Callmonitor.js loader.js:176:9
                                      Check MagicMirror version for module 'MMM-FRITZ-Box-Callmonitor' - Minimum version:  2.0.0 - Current version: 2.13.0 module.js:505:7
                                      Module registered: MMM-FRITZ-Box-Callmonitor module.js:513:6
                                      Bootstrapping module: MMM-FRITZ-Box-Callmonitor loader.js:148:7
                                      Scripts loaded for: MMM-FRITZ-Box-Callmonitor loader.js:153:8
                                      Load stylesheet: modules/MMM-FRITZ-Box-Callmonitor/MMM-FRITZ-Box-Callmonitor.css loader.js:195:9
                                      Styles loaded for: MMM-FRITZ-Box-Callmonitor loader.js:155:9
                                      MMM-FRITZ-Box-Callmonitor - Load translation: translations/de.json translator.js:100:9
                                      Uncaught SyntaxError: JSON.parse: expected double-quoted property name at line 5 column 3 of the JSON data
                                          onreadystatechange http://192.168.200.151:8080/js/translator.js:22
                                      translator.js:22:19
                                        sdetweil @kusselin
                                        @kusselin said in Update auf 2.13.0:
                                        yes, this is the translation file error
                                        edit the MMM-FRITZ-Box-Callmonitor/translations/de.json and remove the comment
                                          // keep the error messages short
                                        • kusselinK Offline
                                          kusselin
                                          Hi Sam,
                                          this is the de.json in the translation folder of MM-Fritzbox Callmonitor:
                                            "title": "Eingehender Anruf",
                                            "noCall": "Keine kürzlichen Anrufe.",
                                            "calllist_parse_error": "Anrufliste unlesbar.",
                                            "phonebook_parse_error": "Telefonbuch unlesbar.",
                                            "vcf_parse_error": "vCard unlesbar.",
                                            "login_error": "Logindaten falsch?",
                                            "network_error": "FRITZ!Box nicht erreichbar.",
                                            "unknown_error": "Unbekannter Fehler."
                                          and what musst i do now and edit? Sorry for my questions…and you thanks
                                          • kusselinK Offline
                                            kusselin
                                            o.k…the newest stand. I have deinstalled the MM-Callmonitor an now i can see the MM on my screen.
                                            Thanks a lot sdetweil.
                                            • 3 / 4
