    Update auf 2.13.0
    65 Posts 4 Posters 24.8k Views 4 Watching
    • kusselinK Offline
      kusselin
      sorry…its not going with:
      cd ~/MagicMirror
      git fetch origin develop:develop
      git checkout develop
      after a restart i see fast an white screen and the the black screen :-( and nothing happend
        sdetweil @kusselin
        @kusselin open the developers console, ctrl-shit-i on the mirror, or chrome from your pc if allowed,
        select the tab labeled ‘console’, and scroll up to see any errors…
        • kusselinK Offline
          kusselin
          i can´t see a mistake…you?
            sdetweil @kusselin
            @kusselin select the tab labeled ‘console’,
            • kusselinK Offline
              kusselin
              @sdetweil said in Update auf 2.13.0:
              i haven´t it
                sdetweil @kusselin
                @kusselin this is ON the mirror system right?
                or you did
                address: "0.0.0.0",
                ipWhitelist:[],
                or your pi, so you can open browser from pc
                • kusselinK Offline
                  kusselin
                  Initializing MagicMirror. main.js:487:8
                  Loading core translation file: translations/de.json translator.js:129:9
                  Loading core translation fallback file: translations/en.json translator.js:154:9
                  Load script: modules/default/alert//alert.js loader.js:176:9
                  Module registered: alert module.js:513:6
                  Bootstrapping module: alert loader.js:148:7
                  Load script: modules/default/alert/notificationFx.js loader.js:176:9
                  Scripts loaded for: alert loader.js:153:8
                  Load stylesheet: modules/default/alert/notificationFx.css loader.js:195:9
                  Load stylesheet: vendor/css/font-awesome.css loader.js:195:9
                  Styles loaded for: alert loader.js:155:9
                  alert - Load translation: translations/de.json translator.js:100:9
                  alert - Load translation fallback: translations/en.json translator.js:102:9
                  Translations loaded for: alert loader.js:157:10
                  Load script: modules/default/updatenotification//updatenotification.js loader.js:176:9
                  Module registered: updatenotification module.js:513:6
                  Bootstrapping module: updatenotification loader.js:148:7
                  Scripts loaded for: updatenotification loader.js:153:8
                  Styles loaded for: updatenotification loader.js:155:9
                  Translations loaded for: updatenotification loader.js:157:10
                  Load script: modules/default/clock//clock.js loader.js:176:9
                  Module registered: clock module.js:513:6
                  Bootstrapping module: clock loader.js:148:7
                  Load script: vendor/node_modules/moment/min/moment-with-locales.js loader.js:176:9
                  Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js loader.js:176:9
                  Load script: vendor/node_modules/suncalc/suncalc.js loader.js:176:9
                  Scripts loaded for: clock loader.js:153:8
                  Load stylesheet: modules/default/clock/clock_styles.css loader.js:195:9
                  Styles loaded for: clock loader.js:155:9
                  Translations loaded for: clock loader.js:157:10
                  Load script: modules/default/calendar//calendar.js loader.js:176:9
                  Module registered: calendar module.js:513:6
                  Bootstrapping module: calendar loader.js:148:7
                  File already loaded: moment.js loader.js:236:9
                  Scripts loaded for: calendar loader.js:153:8
                  Load stylesheet: modules/default/calendar/calendar.css loader.js:195:9
                  File already loaded: font-awesome.css loader.js:236:9
                  Styles loaded for: calendar loader.js:155:9
                  Translations loaded for: calendar loader.js:157:10
                  File already loaded: calendar.css loader.js:236:9
                  Load script: modules/MMM-OpenmapWeather//MMM-OpenmapWeather.js loader.js:176:9
                  Module registered: MMM-OpenmapWeather module.js:513:6
                  Bootstrapping module: MMM-OpenmapWeather loader.js:148:7
                  Scripts loaded for: MMM-OpenmapWeather loader.js:153:8
                  Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css loader.js:195:9
                  Load stylesheet: modules/MMM-OpenmapWeather/MMM-OpenmapWeather.css loader.js:195:9
                  Styles loaded for: MMM-OpenmapWeather loader.js:155:9
                  Translations loaded for: MMM-OpenmapWeather loader.js:157:10
                  Load script: modules/default/weatherforecast//weatherforecast.js loader.js:176:9
                  Module registered: weatherforecast module.js:513:6
                  Bootstrapping module: weatherforecast loader.js:148:7
                  Scripts loaded for: weatherforecast loader.js:153:8
                  File already loaded: weather-icons.css loader.js:236:9
                  Load stylesheet: modules/default/weatherforecast/weatherforecast.css loader.js:195:9
                  Styles loaded for: weatherforecast loader.js:155:9
                  Translations loaded for: weatherforecast loader.js:157:10
                  Load script: modules/MMM-Remote-Control//MMM-Remote-Control.js loader.js:176:9
                  Check MagicMirror version for module 'MMM-Remote-Control' - Minimum version:  2.4.0 - Current version: 2.13.0 module.js:505:7
                  Version is ok! module.js:507:8
                  Module registered: MMM-Remote-Control module.js:513:6
                  Bootstrapping module: MMM-Remote-Control loader.js:148:7
                  Scripts loaded for: MMM-Remote-Control loader.js:153:8
                  Load stylesheet: modules/MMM-Remote-Control/remote-control.css loader.js:195:9
                  Styles loaded for: MMM-Remote-Control loader.js:155:9
                  Translations loaded for: MMM-Remote-Control loader.js:157:10
                  Load script: modules/MMM-SoccerLiveScore//MMM-SoccerLiveScore.js loader.js:176:9
                  Module registered: MMM-SoccerLiveScore module.js:513:6
                  Bootstrapping module: MMM-SoccerLiveScore loader.js:148:7
                  Scripts loaded for: MMM-SoccerLiveScore loader.js:153:8
                  Load stylesheet: modules/MMM-SoccerLiveScore/MMM-SoccerLiveScore.css loader.js:195:9
                  Styles loaded for: MMM-SoccerLiveScore loader.js:155:9
                  Translations loaded for: MMM-SoccerLiveScore loader.js:157:10
                  Load script: modules/MMM-Tankerkoenig//MMM-Tankerkoenig.js loader.js:176:9
                  Check MagicMirror version for module 'MMM-Tankerkoenig' - Minimum version:  2.2.0 - Current version: 2.13.0 module.js:505:7
                  Module registered: MMM-Tankerkoenig module.js:513:6
                  Bootstrapping module: MMM-Tankerkoenig loader.js:148:7
                  Scripts loaded for: MMM-Tankerkoenig loader.js:153:8
                  Load stylesheet: modules/MMM-Tankerkoenig/MMM-Tankerkoenig.css loader.js:195:9
                  Styles loaded for: MMM-Tankerkoenig loader.js:155:9
                  MMM-Tankerkoenig - Load translation: i18n/de.json translator.js:100:9
                  MMM-Tankerkoenig - Load translation fallback: i18n/en.json translator.js:102:9
                  Translations loaded for: MMM-Tankerkoenig loader.js:157:10
                  Load script: modules/MMM-SmartWebDisplay//MMM-SmartWebDisplay.js loader.js:176:9
                  Module registered: MMM-SmartWebDisplay module.js:513:6
                  Bootstrapping module: MMM-SmartWebDisplay loader.js:148:7
                  Scripts loaded for: MMM-SmartWebDisplay loader.js:153:8
                  Load stylesheet: modules/MMM-SmartWebDisplay/MMM-SmartWebDisplay.css loader.js:195:9
                  Styles loaded for: MMM-SmartWebDisplay loader.js:155:9
                  Translations loaded for: MMM-SmartWebDisplay loader.js:157:10
                  Load script: modules/MMM-ioBroker//MMM-ioBroker.js loader.js:176:9
                  Module registered: MMM-ioBroker module.js:513:6
                  Bootstrapping module: MMM-ioBroker loader.js:148:7
                  Scripts loaded for: MMM-ioBroker loader.js:153:8
                  Load stylesheet: modules/MMM-ioBroker/MMM-ioBroker.css loader.js:195:9
                  Styles loaded for: MMM-ioBroker loader.js:155:9
                  Translations loaded for: MMM-ioBroker loader.js:157:10
                  Load script: modules/MMM-FRITZ-Box-Callmonitor//MMM-FRITZ-Box-Callmonitor.js loader.js:176:9
                  Check MagicMirror version for module 'MMM-FRITZ-Box-Callmonitor' - Minimum version:  2.0.0 - Current version: 2.13.0 module.js:505:7
                  Module registered: MMM-FRITZ-Box-Callmonitor module.js:513:6
                  Bootstrapping module: MMM-FRITZ-Box-Callmonitor loader.js:148:7
                  Scripts loaded for: MMM-FRITZ-Box-Callmonitor loader.js:153:8
                  Load stylesheet: modules/MMM-FRITZ-Box-Callmonitor/MMM-FRITZ-Box-Callmonitor.css loader.js:195:9
                  Styles loaded for: MMM-FRITZ-Box-Callmonitor loader.js:155:9
                  MMM-FRITZ-Box-Callmonitor - Load translation: translations/de.json translator.js:100:9
                  Uncaught SyntaxError: JSON.parse: expected double-quoted property name at line 5 column 3 of the JSON data
                      onreadystatechange http://192.168.200.151:8080/js/translator.js:22
                  translator.js:22:19
                    sdetweil @kusselin
                    @kusselin said in Update auf 2.13.0:
                    yes, this is the translation file error
                    edit the MMM-FRITZ-Box-Callmonitor/translations/de.json and remove the comment
                      // keep the error messages short
                    • kusselinK Offline
                      kusselin
                      Hi Sam,
                      this is the de.json in the translation folder of MM-Fritzbox Callmonitor:
                        "title": "Eingehender Anruf",
                        "noCall": "Keine kürzlichen Anrufe.",
                        "calllist_parse_error": "Anrufliste unlesbar.",
                        "phonebook_parse_error": "Telefonbuch unlesbar.",
                        "vcf_parse_error": "vCard unlesbar.",
                        "login_error": "Logindaten falsch?",
                        "network_error": "FRITZ!Box nicht erreichbar.",
                        "unknown_error": "Unbekannter Fehler."
                      and what musst i do now and edit? Sorry for my questions…and you thanks
                      • kusselinK Offline
                        kusselin
                        o.k…the newest stand. I have deinstalled the MM-Callmonitor an now i can see the MM on my screen.
                        Thanks a lot sdetweil.
                        • 6
                        • 7
                        • 6 / 7
