    Update auf 2.13.0
    65 Posts 4 Posters 24.8k Views 4 Watching
      sdetweil @kusselin
      @kusselin the updateNotification module if u don’t use it, u can disable it.
      add
      module:"updatenotification",
      disabled: true,       // < this line
      • kusselinK Offline
        kusselin
        the screen is always black :-(
        i ihink i have to save the config and i have to install magic mirror new…
        what do you think?
        • kusselinK Offline
          kusselin
          after a new installation…can i also copie the save config and all is good?
            sdetweil @kusselin
            @kusselin upgrade didn’t touch the config, it should be the same as before
              sdetweil @kusselin
              @kusselin if a NEW install, then u would have to reinstall all the modules and update the config
              • kusselinK Offline
                kusselin
                @sdetweil said in Update auf 2.13.0:
                o.k i musst have to install all the modules again and then i can copie the config in the config folder…right?
                And please can you send me a link how i can install about the console the ltest magic mirror please…
                • kusselinK Offline
                  kusselin
                  can you tell me why the screen is now black?
                    sdetweil @kusselin
                    @kusselin install is the same place u got the upgrade script
                    why are u trying to install again??
                    black screen
                    probably one of the lang files with comments
                    switch to the develop branch
                    git checkout develop
                    • kusselinK Offline
                      kusselin
                      o.k. can you help me once again please that i have a picture…
                      pi@raspberrypi:~ $ cd MagicMirror
                      pi@raspberrypi:~/MagicMirror $ git checkout develop
                      error: Pfadspezifikation 'develop' stimmt mit keinen git-bekannten Dateien überein.
                        sdetweil @kusselin
                        @kusselin see here
                        https://forum.magicmirror.builders/topic/13774/2-13-back-screen-translation-file-error-fix/2
                        • 6
                        • 7
                        • 5 / 7
