    Update auf 2.13.0
    65 Posts 4 Posters 24.3k Views 4 Watching
    • kusselinK Offline
      kusselin
      ui …ok. thats a house number…
      i will back then
      for you first thanks a lot :-)
      • kusselinK Offline
        kusselin
        look…can you say something about this installation now?
        pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubuserconten        t.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
        No LSB modules are available.
        doing test run = false
        update log will be in /home/pi/MagicMirror/installers/upgrade.log
        saving custom.css
        upgrading from version 2.9.0 to 2.13.0
        fetching latest revisions
        there are 2 local files that are different than the master repo
           modules/default/compliments/compliments.js
           package-lock.json
        any *-lock.json files do not need to be saved
        do you want to save these files for later   (Y/n)?Y
        updating MagicMirror runtime, please wait
        > console-stamp@0.2.9 postinstall /home/pi/MagicMirror/node_modules/console-stam        p
        > node ./msg.js
        Attention
            Console-stamp version 3.0.0 Release Candidate is out. Install by using the t        ag '@next'. NB: Breaking changes.
            For more details goto: https://www.npmjs.com/package/console-stamp/v/next
        > electron@6.1.12 postinstall /home/pi/MagicMirror/node_modules/electron
        > node install.js
        Downloading tmp-16303-1-SHASUMS256.txt-6.1.12
        [============================================>] 100.0% of 5.62 kB (5.62 kB/s)
        > magicmirror@2.13.0 install /home/pi/MagicMirror
        > echo "Installing vendor files ...
        " && cd vendor && npm install --loglevel=error
        added 3 packages from 3 contributors, removed 62 packages, updated 17 packages and audited 24 packages in 38.077s
        1 package is looking for funding
          run `npm fund` for details
        found 0 vulnerabilities
        > magicmirror@2.13.0 postinstall /home/pi/MagicMirror
        > npm run install-fonts && echo "MagicMirror installation finished successfully!
        > magicmirror@2.13.0 install-fonts /home/pi/MagicMirror
        > echo "Installing fonts ...
        " && cd fonts && npm install --loglevel=error
        updated 1 package and audited 1 package in 8.1s
        added 81 packages from 60 contributors, removed 340 packages, updated 119 packages and audited 1164 packages in 928.05s
        9 packages are looking for funding
        found 3 low severity vulnerabilities
          run `npm audit fix` to fix them, or `npm audit` for details
        processing dependency changes for active modules with package.json files
        processing for module MMM-Remote-Control please wait
        npm notice created a lockfile as package-lock.json. You should commit this file.
        added 30 packages from 24 contributors and audited 30 packages in 22.948s
        processing complete for module MMM-Remote-Control
        processing for module MMM-SoccerLiveScore please wait
        up to date in 2.55s
        processing complete for module MMM-SoccerLiveScore
        processing for module MMM-SmartWebDisplay please wait
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        added 93 packages from 86 contributors and audited 94 packages in 49.515s
        processing complete for module MMM-SmartWebDisplay
        processing for module MMM-ioBroker please wait
        added 41 packages from 465 contributors and audited 41 packages in 32.545s
        2 packages are looking for funding
        found 1 low severity vulnerability
        processing complete for module MMM-ioBroker
        processing for module MMM-FRITZ-Box-Callmonitor please wait
        added 11 packages from 64 contributors and audited 11 packages in 15.02s
        processing complete for module MMM-FRITZ-Box-Callmonitor
        processing for module MMM-Fuel please wait
        npm WARN deprecated browserslist@1.7.7: Browserslist 2 could fail on reading Browserslist >3.0 config used in other tools.
        npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
        npm WARN eslint-config-recommended@4.1.0 requires a peer of eslint@^6.0.0 but none is installed. You must install peer dependencies yourself.
        npm WARN eslint-config-esnext@4.1.0 requires a peer of eslint@^6.0.0 but none is installed. You must install peer dependencies yourself.
        npm WARN eslint-config-node@4.1.0 requires a peer of eslint@^6.0.0 but none is installed. You must install peer dependencies yourself.
        npm WARN eslint-config-react-native@4.1.0 requires a peer of eslint@^6.0.0 but none is installed. You must install peer dependencies yourself.
        added 584 packages from 375 contributors and audited 584 packages in 366.594s
        38 packages are looking for funding
        processing complete for module MMM-Fuel
        processing for module MMM-PublicTransportHafas please wait
        added 33 packages from 23 contributors and audited 33 packages in 25.836s
        processing complete for module MMM-PublicTransportHafas
        processing for module MMM-Tools please wait
        added 3 packages from 3 contributors and audited 3 packages in 8.165s
        processing complete for module MMM-Tools
        restoring custom.css
        we stashed a set of files that appear changed from the latest repo versions. you should review them
        see installers/stashed_files for the list
        you can use git checkout stash@{0} -- filename to extract one file from the stash
        or git stash pop to restore them all
        WARNING..
        WARNING.. either will overlay the file just installed by the update
        WARNING..
          sdetweil @kusselin
          @kusselin cool… looks good… now to run MM… and see if it all works…
          • kusselinK Offline
            kusselin
            no, nothing is good…sorry:
            i have a black screen :-(
            > magicmirror@2.13.0 start /home/pi/MagicMirror
            > ./run-start.sh $1
            [2020-11-15 18:39:25.557] [LOG]    Starting MagicMirror: v2.13.0
            [2020-11-15 18:39:25.648] [LOG]    Loading config ...
            [2020-11-15 18:39:25.691] [LOG]    Loading module helpers ...
            [2020-11-15 18:39:25.703] [LOG]    No helper found for module: alert.
            [2020-11-15 18:39:26.107] [LOG]    Initializing new module helper ...
            [2020-11-15 18:39:26.112] [LOG]    Module helper loaded: updatenotification
            [2020-11-15 18:39:26.117] [LOG]    No helper found for module: clock.
            [2020-11-15 18:39:30.439] [LOG]    Initializing new module helper ...
            [2020-11-15 18:39:30.444] [LOG]    Module helper loaded: calendar
            [2020-11-15 18:39:30.451] [LOG]    No helper found for module: MMM-OpenmapWeather.
            [2020-11-15 18:39:30.457] [LOG]    No helper found for module: weatherforecast.
            [2020-11-15 18:39:31.996] [LOG]    Initializing new module helper ...
            [2020-11-15 18:39:32.001] [LOG]    Module helper loaded: MMM-Remote-Control
            [2020-11-15 18:39:32.030] [LOG]    Initializing new module helper ...
            [2020-11-15 18:39:32.039] [LOG]    Module helper loaded: MMM-SoccerLiveScore
            [2020-11-15 18:39:32.059] [LOG]    Initializing new module helper ...
            [2020-11-15 18:39:32.062] [LOG]    Module helper loaded: MMM-Tankerkoenig
            [2020-11-15 18:39:32.069] [LOG]    No helper found for module: MMM-SmartWebDisplay.
            [2020-11-15 18:39:32.099] [LOG]    Initializing new module helper ...
            [2020-11-15 18:39:32.107] [LOG]    Module helper loaded: MMM-ioBroker
            [2020-11-15 18:39:33.022] [LOG]    Initializing new module helper ...
            [2020-11-15 18:39:33.024] [LOG]    Module helper loaded: MMM-FRITZ-Box-Callmonitor
            [2020-11-15 18:39:33.475] [LOG]    Initializing new module helper ...
            [2020-11-15 18:39:33.482] [LOG]    Module helper loaded: MMM-Fuel
            [2020-11-15 18:39:34.691] [LOG]    Initializing new module helper ...
            [2020-11-15 18:39:34.693] [LOG]    Module helper loaded: MMM-PublicTransportHafas
            [2020-11-15 18:39:34.696] [LOG]    No helper found for module: compliments.
            [2020-11-15 18:39:35.002] [LOG]    Initializing new module helper ...
            [2020-11-15 18:39:35.010] [LOG]    Module helper loaded: MMM-Tools
            [2020-11-15 18:39:35.216] [LOG]    Initializing new module helper ...
            [2020-11-15 18:39:35.222] [LOG]    Module helper loaded: newsfeed
            [2020-11-15 18:39:35.239] [LOG]    Initializing new module helper ...
            [2020-11-15 18:39:35.245] [LOG]    Module helper loaded: MMM-COVID19
            [2020-11-15 18:39:35.264] [LOG]    Initializing new module helper ...
            [2020-11-15 18:39:35.270] [LOG]    Module helper loaded: MMM-COVID19-AMPEL
            [2020-11-15 18:39:35.275] [LOG]    All module helpers loaded.
            [2020-11-15 18:39:36.247] [LOG]    Starting server on port 8080 ...
            [2020-11-15 18:39:36.295] [INFO]   You're using a full whitelist configuration to allow for all IPs
            [2020-11-15 18:39:36.338] [LOG]    Server started ...
            [2020-11-15 18:39:36.347] [LOG]    Connecting socket for: updatenotification
            [2020-11-15 18:39:36.355] [LOG]    Connecting socket for: calendar
            [2020-11-15 18:39:36.359] [LOG]    Starting node helper for: calendar
            [2020-11-15 18:39:36.363] [LOG]    Connecting socket for: MMM-Remote-Control
            [2020-11-15 18:39:36.370] [LOG]    Starting node helper for: MMM-Remote-Control
            [2020-11-15 18:39:36.418] [LOG]    Connecting socket for: MMM-SoccerLiveScore
            [2020-11-15 18:39:36.424] [LOG]    MMM-SoccerLiveScore helper started...
            [2020-11-15 18:39:36.427] [LOG]    Connecting socket for: MMM-Tankerkoenig
            [2020-11-15 18:39:36.430] [LOG]    Starting module helper: MMM-Tankerkoenig
            [2020-11-15 18:39:36.435] [LOG]    Connecting socket for: MMM-ioBroker
            [2020-11-15 18:39:36.441] [LOG]    Connecting socket for: MMM-FRITZ-Box-Callmonitor
            [2020-11-15 18:39:36.446] [LOG]    Starting module: MMM-FRITZ-Box-Callmonitor
            [2020-11-15 18:39:36.451] [LOG]    Connecting socket for: MMM-Fuel
            [2020-11-15 18:39:36.456] [LOG]    Starting module helper: MMM-Fuel
            [2020-11-15 18:39:36.459] [LOG]    Connecting socket for: MMM-PublicTransportHafas
            [2020-11-15 18:39:36.462] [LOG]    Connecting socket for: MMM-Tools
            [2020-11-15 18:39:36.468] [LOG]    [Tools] MMM-Tools Version: 2.0.3
            [2020-11-15 18:39:36.472] [LOG]    Connecting socket for: newsfeed
            [2020-11-15 18:39:36.476] [LOG]    Starting node helper for: newsfeed
            [2020-11-15 18:39:36.480] [LOG]    Connecting socket for: MMM-COVID19
            [2020-11-15 18:39:36.484] [LOG]    Starting node helper for: MMM-COVID19
            [2020-11-15 18:39:36.489] [LOG]    Connecting socket for: MMM-COVID19-AMPEL
            [2020-11-15 18:39:36.492] [LOG]    Starting node helper for: MMM-COVID19-AMPEL
            [2020-11-15 18:39:36.494] [LOG]    Sockets connected & modules started ...
            [2020-11-15 18:39:36.538] [ERROR]  Whoops! There was an uncaught exception...
            [2020-11-15 18:39:36.543] [ERROR]  Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                at Server.setupListenHandle [as _listen2] (net.js:1226:14)
                at listenInCluster (net.js:1274:12)
                at doListen (net.js:1413:7)
                at processTicksAndRejections (internal/process/task_queues.js:84:9) {
              code: 'EADDRINUSE',
              errno: 'EADDRINUSE',
              syscall: 'listen',
              address: '0.0.0.0',
              port: 8080
            [2020-11-15 18:39:36.573] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            [2020-11-15 18:39:36.576] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            [2020-11-15 18:39:38.359] [LOG]    Launching application.
            Username for 'https://github.com':
              sdetweil @kusselin
              @kusselin said in Update auf 2.13.0:
              mirror already running…
              can’t run two at the same time… (on the same port)
              • kusselinK Offline
                kusselin
                @sdetweil said in Update auf 2.13.0:
                o.k. and what can i do now…?
                Sorry for my questions but i´m not the expert as you
                  sdetweil @kusselin
                  @kusselin if you use pm2 to start a boot,
                  pm2 stop all
                  then npm start to test
                  • kusselinK Offline
                    kusselin
                    pi@raspberrypi:~ $ pm2 stop all
                    [PM2] Applying action stopProcessId on app [all](ids: 0)
                    [PM2] [MagicMirror](0) ✓
                    │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                    │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
                    pi@raspberrypi:~ $ npm start
                    npm ERR! code ENOENT
                    npm ERR! syscall open
                    npm ERR! path /home/pi/package.json
                    npm ERR! errno -2
                    npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                    npm ERR! enoent This is related to npm not being able to find a file.
                    npm ERR! enoent
                    npm ERR!     /home/pi/.npm/_logs/2020-11-15T18_01_08_239Z-debug.log
                      sdetweil @kusselin
                      @kusselin from the MagicMirror folder
                      • kusselinK Offline
                        kusselin
                        username for github.com?
                        what ist this?
                        • 6
                        • 7
                        • 4 / 7
