    Search module for livecam / stream
    28 Posts 4 Posters 4.3k Views 4 Watching
    • JerryPJ Offline
      JerryP @KamiSchami
      @KamiSchami You can use this.
      		module: "MMM-RTSPStream",
      		disabled: false, //false, true
      		position: "middle",
      			autoStart: true,
      			rotateStreams: false,
      			rotateStreamTimeout: 20,
      			moduleWidth: 468,
      			moduleHeight: 320,
      			localPlayer: "omxplayer", // "omxplayer" or "ffmpeg", or "vlc"
      			remotePlayer: 'none',
      			showSnapWhenPaused: false,
      			remoteSnaps: false,
      			  stream1: {
      			  url: 'https://cam01.binz-kabel.de/cam1.m3u8',
      			  protocol: "tcp",
      			  frameRate: 25,
      			  muted: true,
                                hwAccel: true,
                                width: 450,
                                height: 300,
      • JerryPJ Offline
        JerryP @JerryP
        @KamiSchami this part I meen
        			  stream1: {
        			  protocol: "tcp",
        			  frameRate: 25,
        			  muted: true,
                                  hwAccel: true,
                                  width: 450,
                                  height: 300,
        • KamiSchamiK Offline
          KamiSchami
          Thanks, it was late yesterday. The camera was gray and night mode and my buttons are also gray, I have to check if it is brighter.
          Real programmers never work 9 to 5. If they are around at 9 AM, it's because they were up all night.
            KamiSchami
            hi, it’s still over the button when i enlarge the module 🙈
              drx1984 @KamiSchami
              @KamiSchami what am I doing wrong?
              for me MM starts but the whole screen remains black
              Can someone help me please?
              Is the MMM-RTSPStream module up to date? still works?
              • JerryPJ Offline
                JerryP
                @drx1984
                This one is working fine.
                De URL was wrong.
                position: "middle",
                	autoStart: true,
                	moduleWidth: 468,
                	moduleHeight: 320,
                	remoteSnaps: false,
                	stream1: {
                	url: 'rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov',
                			  protocol: "tcp",
                			  frameRate: 25,
                			  muted: true,
                                          hwAccel: true,
                                          width:  450,
                                          height: 300,
                  drx1984 @JerryP
                  @JerryP unfortunately it still doesn’t work.
                  Magic mirror starts but it just remains black and the terminal says that the module is not available?
                  I have already copied the module into the modules folder with the command “git clone”.
                  JerryPJ 1 Reply Last reply Reply Quote 0
                  • JerryPJ Offline
                    JerryP @drx1984
                    @drx1984
                    Goodmorning,
                    I think the module is not install correctly
                    have you follow the instructions https://github.com/shbatm/MMM-RTSPStream
                    You can also
                    go into terminal.
                    cd ~/MagicMirror/modules/MMM-RTSPStream
                    git pull
                    npm install
                    If that i’s not working I can only suggest that you delete your current installation of the module and re-install it.
