    Calendar problem
    7 Posts 3 Posters 1.2k Views 3 Watching
    • C Offline
      chris47803
      Hello,
      I get my appointments from Outlook.
      I see normal appointments through to the end.
      Series appointments are hidden at the start time.
      Example:
      Series date annually on January 29th from 7 a.m. to 5 p.m.
      This appointment will be hidden from 7 a.m.
      For a one-off appointment from 7 a.m. to 5 p.m., for example, at 4 p.m. there is 1 + hour
      How can I adjust that?
      best regards
        sdetweil @chris47803
        @chris47803 not quite sure i understand.
        once a time has passed, (start or end) its not upcoming any more.
        before it will show start, once started it will show end.
        what is the extra hour? what is your system timezone and calendar event time zone?
        • C Offline
          chris47803
          Only be start
            Write your question in your native language and then use Google Translate to English? Might help.
            • C Offline
              chris47803
              @Mykle1 said in Calendar problem:
              Maybe write your quite in your native language and then use Google Translate? Might help.
              that’s exactly how I did it
              • C Offline
                chris47803
                New example
                Appointment annually on January 30th from 10 a.m. to 6 p.m.
                This date is only until January 30th. 10.00 a.m.
                Actually, this date should be visible until 6 p.m.
                • C Offline
                  chris47803
                  Hello
                  i finally made it.
                  I just needed someone to talk to. :)
                  in the calendar.js I changed these 3 values from false to true.
                  sliceMultiDayEvents: true,
                          broadcastPastEvents: true,
                          nextDaysRelative: true
