    MMM-MercedesMe
    53 Posts 10 Posters 28.2k Views 9 Watching
    • P Offline
      pyrophoenix @ashishtank
      @ashishtank Thanks for the reply!
      I have erased token and reboot it with Diesel…Still the same issue but this time it goes to the correct URL
      [08.04.2021 13:38.22.939] [LOG]   Handle OAuth request
      [08.04.2021 13:38.22.946] [LOG]   https://id.mercedes-benz.com/as/authorization.oauth2?response_type=code&client_id=c****************4a&&redirect_uri=http://localhost:8080/MMM-MercedesMe/callback&scope=mb:vehicle:mbdata:vehiclestatus offline_access&state=d*************************e
      [08.04.2021 13:38.25.124] [INFO]  Newsfeed-Fetcher: Broadcasting 66 items.
      [08.04.2021 13:38.26.049] [LOG]   Handle OAuth callback
      [08.04.2021 13:38.26.982] [LOG]   OAuth callback Success
      [08.04.2021 13:38.34.388] [LOG]   Vehicle data url https://api.mercedes-benz.com/vehicledata/v2/vehicles/W1****************9/containers/fuelstatus
      [08.04.2021 13:38.35.647] [LOG]   403 - Forbidden
      It is still saying error 403
        ashishtank Module Developer @pyrophoenix
        @pyrophoenix did you followed the step 3 correctly ? did you linked fuel status scope with app ? as shown in image below you should see
        Fuel Status BYOCAR
        • P Offline
          pyrophoenix
          Thanks! Great that YOU point it out! I cheated a bit and directly put the “fuel” on the URL as so
          https://developer.mercedes-benz.com/products/fuel_status/get_access?pm=free
          I just added it and I’ll try now.
          • P Offline
            pyrophoenix
            Not working…But it seems that the Bearer is not generated properly. If I try the test curl provided by the Mercedes Dev, it does work…
              @pyrophoenix Can you delete the app in Mercedes dev portal and create new one with correct scope ? also delete tokens.json file and restart the mirror. I think it is some caching issue.
              • P Offline
                @ashishtank Remove and did a brand new app on console. Removed tokens.json and reboot…Same problem
                There is one thing that is on your step (Right from step 1) saying:
                AUTH CALLBACK URL: http://localhost
                Where that needs to be introduced?
                • P Offline
                  pyrophoenix
                  Details.PNG image url)
                  A 2 Replies Last reply Reply Quote 0
                    @pyrophoenix things looks correct, http://localhost:8080/MMM_MercedesMe/callback is important other localhost urls in callback are optional. I have sent you PM what we can do next.
                      @pyrophoenix Let me know if changing the scope solves the issue. I will update the documentation accordingly.
                      • P Offline
                        @ashishtank Hi! Unfortunatly it didn’t :/ Mercedes are looking at this matter and they will get back to me normally on Monday.
                        Thanks again for your help and I’ll keep you informed!
                        • 6
                        • 4 / 6
