    MMM-MercedesMe
    53 Posts 10 Posters 29.1k Views 9 Watching
      Andreas Heins
      When i press “Authenticate” i only get “Handle OAuth callback” in the Log and nothing more.
      Any Ideas?
      Mit freundlichen Grüßen
      Andreas
        ashishtank Module Developer @Andreas Heins
        @andreas-heins Is your configuration correct ? if you have already logged in then it will not display login screen and will directly get token. Did you check if tokens.json file is created and updated after authentication ?
          Andreas Heins
          @ashishtank i checkend my configuration and now i have another error „ 400 - Invalid redirect_uri“.
            @andreas-heins looks like you are missing Step 7 from https://github.com/ashishtank/MMM-MercedesMe documentation. Please check, also which version of Magic Mirror are you using ? there are breaking changes in v2.15 in MM core and issue i have not fixed for my module yet.
              rogers0072002 @ashishtank
              @ashishtank hello i folow all steps and i had initial auth form
              i install oauth module ( explain by sdetweil in gitlab issues).
              My was created correctly but i receive no data.
              My version of MM is 2.15
              in mm log i found this
              0|MagicMirror | [28.06.2021 22:13.20.726] [ERROR]
              0|MagicMirror | Failed to fetch git data for MMM-homeassistant-sensors: Error: block timeout reached
              0|MagicMirror | [28.06.2021 22:13.21.674] [LOG]
              0|MagicMirror | 403 - Forbidden
              0|MagicMirror | [28.06.2021 22:13.21.678] [LOG]
              0|MagicMirror | [28.06.2021 22:13.21.866] [LOG]
              thk in advance
                rogers0072002 @rogers0072002
                @rogers0072002 sorry is not good log
                0|MagicMirror | Vehicle data url https://api.mercedes-benz.com/vehicledata/v2/vehicles/WDCXXXXXXXXXXXXXX/containers/fuelstatus
                0|MagicMirror | [28.06.2021 22:35.42.737] [LOG]
                0|MagicMirror | [28.06.2021 22:38.15.691] [LOG]
                0|MagicMirror | [28.06.2021 22:38.16.209] [LOG]
                0|MagicMirror | [28.06.2021 22:38.21.119] [INFO]
                  ashishtank Module Developer @rogers0072002
                  @rogers0072002 As per logs it looks like you have not added scope or token is not valid can you delete the tokens.json file and try login again ? make sure you have linked right scope (electric or fuel) in the Mercedes app.
                    matt216
                    Hello.
                    Lovely looking module. Having some trouble with mine. The single dial displays, but doesn’t seem to have pulled any data from Mercedes. I did not ever get an authenticate option after installing…
                    Did pm2 restart mm and then watched pm2 logs… only thing relevant I could see was:
                    0|mm  | [24.11.2021 13:58.46.575] [ERROR]
                    0|mm  | Whoops! There was an uncaught exception...
                    0|mm  | [24.11.2021 13:58.46.583] [ERROR]
                    0|mm  | TypeError: Cannot read property 'toLowerCase' of undefined
                    0|mm  |     at Class.getVehicleDataUrl (/home/pi/MagicMirror/modules/MMM-MercedesMe/node_helper.js:146:32)
                    0|mm  |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-MercedesMe/node_helper.js:106:25)
                    0|mm  |     at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:112:11)
                    0|mm  |     at Socket.emit (events.js:210:5)
                    0|mm  |     at Socket.onevent (/home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:253:20)
                    0|mm  |     at Socket.socket.onevent (/home/pi/MagicMirror/js/node_helper.js:105:13)
                    0|mm  |     at Socket._onpacket (/home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:216:22)
                    0|mm  |     at /home/pi/MagicMirror/node_modules/socket.io/dist/client.js:205:28
                    0|mm  |     at processTicksAndRejections (internal/process/task_queues.js:75:11)
                    0|mm  | [24.11.2021 13:58.46.588] [ERROR]
                    0|mm  | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    0|mm  | [24.11.2021 13:58.46.593] [ERROR]
                    0|mm  | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    I cannot see a tokens.json in the ~/MagicMirror/modules/MMM-MercedesMe folder to try that option.
                    I have the following products enabled in developer portal:
                    Appreciate any tips, thanks.
                    Matt
                      ashishtank Module Developer @matt216
                      @matt216 Can you check if request package is installed ? you can do so with below command
                      npm install request --save
                        matt216 @ashishtank
                        @ashishtank ran command (added 47 packages), reloaded MM, same issue :(
                        Appreciate the help
                        • 6
                        • 5 / 6
