    MMM-MercedesMe
    53 Posts 10 Posters 28.2k Views 9 Watching
      ashishtank Module Developer @kar1507
      @kar1507 This module is for both electric and other type of cars if supported by MercedesMe Api. did you set the correct vehicle type and correct scope ? as indicated here ? https://github.com/ashishtank/MMM-MercedesMe/blob/main/README.md
      for non electric vehicle set the correct vehicle type and scope should be mb:vehicle:mbdata:vehiclestatus offline_access also instead of elecrtic vehicle you need to subscribe to vehicle status in mercedes portal
      • K Offline
        kar1507
        @JerryP
        Our car has 4G in it. I can switch on the parking heater in the Mercedes mobile phone app.
        Open and close doors and control windows remotely.
        I changed the config to petrol. I also used the API for non-electrics.
        • K Offline
          kar1507
          @ashishtank
          I have adjusted both data (vehicle type and scope) in node_helper.js
          Unfortunately I have a bug somewhere. Unfortunately it shows nothing.
            @kar1507 do you have logs in console or from dev tools ?
            • K Offline
              kar1507 @ashishtank
              @ashishtank
              Hello.
              I set up my Magic Mirror again.
              I’ve been working on the project for 2 weeks.
              So I honestly don’t know where to find the exact logs.
              I also have the debug mode on but first have to see where I can find the log.
              Sorry, just start with the matter.
                sdetweil @kar1507
                @kar1507 if you start your mirror with pm2
                do pm2 status
                then pm2 logs --lines=100
                will show 100 lines of the logged info…
                same stuff that is displayed after npm start
                pm2 flush to clear the logs
                • K Offline
                  kar1507
                  Good Morning
                  Thank You sdetweil
                  Here my log:
                  /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
                  0|MagicMir | npm ERR! code ELIFECYCLE
                  0|MagicMir | npm ERR! errno 1
                  0|MagicMir | npm ERR! magicmirror@2.14.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                  0|MagicMir | npm ERR! Exit status 1
                  0|MagicMir | npm ERR! Failed at the magicmirror@2.14.0 start script.
                  0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                  0|MagicMir |
                  0|MagicMir | npm ERR! A complete log of this run can be found in:
                  0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2021-02-11T08_58_44_432Z-debug.log
                  0|MagicMir | [11.02.2021 09:59.18.142] [WARN]  You're using a full whitelist configuration to allow for all IPs
                  0|MagicMir | [11.02.2021 09:59.20.163] [WARN]  (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently "false".  It will change to be "true" in Electron 9.  For more information please check https://github.com/electron/electron/issues/18397
                  0|MagicMir | [11.02.2021 09:59.18.193] [LOG]   Connecting socket for: MMM-MercedesMe
                  0|MagicMir | [11.02.2021 09:59.18.195] [LOG]   Starting node_helper for Mercedes Me
                  0|MagicMir | [11.02.2021 09:59.38.750] [LOG]   Init token from file./modules/MMM-MercedesMe/tokens.json
                  0|MagicMir | [11.02.2021 09:59.38.764] [LOG]   Client id 2051c078-7e58-4758-a508-cabafe8d1317
                  0|MagicMir | [11.02.2021 09:59.38.772] [LOG]   Current token is expired or does not exists
                  0|MagicMir | [11.02.2021 09:59.38.945] [INFO]  Checking git for module: MMM-MercedesMe
                  0|MagicMirror  | [11.02.2021 10:01.33.024] [LOG]
                  0|MagicMirror  | Handle OAuth request
                  0|MagicMirror  | [11.02.2021 10:01.33.036] [LOG]   https://id.mercedes-benz.com/as/authorization.oauth2?response_type=code&client_id=2051c078-7e58-4758-a508-cabafe8d1317&&redirect_uri=http://localhost:8080/MMM-MercedesMe/callback&scope=mb:vehicle:mbdata:fuelstatus&state=0ec4726f-662b-40d5-bb07-ad649bd085ec
                  0|MagicMirror  | [11.02.2021 10:01.47.680] [LOG]
                  0|MagicMirror  | Vehicle data url https://api.mercedes-benz.com/vehicledata/v2/vehicles/WDD247047/containers/fuelstatus
                  0|MagicMirror  | [11.02.2021 10:01.47.685] [LOG]
                  0|MagicMirror  | [11.02.2021 10:01.47.715] [LOG]
                  0|MagicMirror  | [11.02.2021 10:01.47.719] [LOG]   Vehicle data url https://api.mercedes-benz.com/vehicledata/v2/vehicles/WDD247047/containers/fuelstatus
                  0|MagicMirror  | [11.02.2021 10:02.07.183] [LOG]
                  0|MagicMirror  | [11.02.2021 10:02.07.198] [LOG]
                  0|MagicMirror  | [11.02.2021 10:02.07.233] [LOG]
                  0|MagicMirror  | [11.02.2021 10:02.07.241] [LOG]   Vehicle data url https://api.mercedes-benz.com/vehicledata/v2/vehicles/WDD247047/containers/fuelstatus
                  • K Offline
                    kar1507
                    Hello.
                    Thank you @ashishtank @sdetweil @JerryP
                    It works now and the data is displayed.
                    A JerryPJ 2 Replies Last reply Reply Quote 1
                      @kar1507 Good to know that issues is solved, may be it was temporary issue from Mercedes Api, they have some downtime every now and then. Also I noticed that you have not included offline_access scope in config ? if you do not include that then refresh token will not be generated and thus you will need to re login again and again once the access token is expirers.
                      • JerryPJ Offline
                        JerryP @kar1507
                        @kar1507
                        cen you post a picture of the screen???
                        • 6
                        • 2 / 6
