    What are your MM/Pi statistics?
    7 Posts 3 Posters 1.9k Views 3 Watching
    • K Offline
      keineAhnung123
      Hello,
      My MM is hanging in my bathroom since 3 days and im trying to optimize it right now.
      I had CPU problems but found out that MMM-DarkSkyForecast causes them so i disabled it.
      My Modules are updating rarely (API calls > 30 min) and dont have any big animations (only things like newsfeed article fading…) so CPU is no problem anymore.
      My stats are:
      • CPU: 0-5 %
      • Temperature: 40-45 °C (heatsinks installed and no closed case)
      • free RAM: 5-15 %
      with:
      Raspberry Pi 3b+
      MM 2.14.0
      pi@raspberrypi:~/MagicMirror $ npm ls | grep electron
      ├─┬ electron@8.5.3
      │ ├─┬ @electron/get@1.12.2
      │ ├─┬ electron-chromedriver@8.0.0
      │ │ ├─┬ electron-download@4.1.1
      │ │ │ ├── electron-to-chromium@1.3.606
      and MMM-NewPIR with ecoMode enabled (hides modules when no activity)
      I read the well known thread electron cpu usage and my question is:
      Are my stats normal? CPU an temperature are fine but the free RAM is a little bit concerning, isnt it? Are the 7 electron processes normal? Which electron version do you use (the electron cpu usage- thread is 3 years old)?
      Thank you :)
      • mumblebajM Offline
        mumblebaj Module Developer @keineAhnung123
        @keineahnung123 I have been having the same issue. When RAM drops between 15 - 20% my mirror hangs so I have been disabling new modules I have added recently to see which ones are using up RAM. I have narrowed mine down to a few and have disabled them. I don’t know of a way to monitor the modules to see which ones use the most RAM. I usually hard boot, pull the plug, to get my mirror going again but I fear that may eventually damage my sd card.
          sdetweil @mumblebaj
          @mumblebaj decent memory leak chasing doc.
          mm does a lot all the time, so its harder to focus…
          https://marmelab.com/blog/2018/04/03/how-to-track-and-fix-memory-leak-with-nodejs.html
            mumblebaj Module Developer @sdetweil
            @sdetweil Thanks Sam. I will have a read through. I only started having memory issues when using modules from a certain developer. After removing those, my memory issues have gone away.
              sdetweil @mumblebaj
              @mumblebaj i understand. i chased a ‘hang’ for over a year. all kinds of debugging. only when one.of my modules loaded. so its my fault…
              i went thru the code hundreds of times.
              finally got a good log, and it wasnt a hang, it was out of memory… back thru the code…
              sure enough, i saved a pointer to an image, then never freed it… and i had changed the code, so didnt even need it to begin with…
                @sdetweil I am looking at rewriting the one module that I know is hogging my memory.
                Hope you are getting better and hopefully heading home soon so you can get to your laptop again. All the best and good health.
                  sdetweil @mumblebaj
                  @mumblebaj thanks. makin progress…
