    pm2 doesnt work with crontab
    45 Posts 8 Posters 13.4k Views 6 Watching
      sdetweil @plainbroke
      @plainbroke no, without sudo is best
      Maybe pm2 isn’t in the path when crontab fires
      Check the syslog for crontab errors
      32 bit is about to be trouble.
      The latest nodejs version, 24, has dropped builds for 32 bit
      plainbrokeP 1 Reply Last reply Reply Quote 0
      • plainbrokeP Offline
        plainbroke @sdetweil
        Thanks for the info I almost pulled down 32 bit.
        It has been interesting to say the least going to trixie.
        Turns out my problem was a failed NVMe drive.
        I thought those things where supposed to last for a LONG long time…
        I did get crontab -e to work with trixie and MM 2.33 not a fun ride, but entertaining. I finally learned how to use bash to make batch style files…
        So not a complete loss of time…
          @plainbroke technology is SOOOO much fun! Simple, til it’s not!
          Thanks for the feedback. Others will ask, I’m sure they could use your help!
            Ok crontab -e worked last night to shutdown MM. So the pm2 stop all worked.
            BUT this morning the pm2 restart mm did nothing.
            I used find to get these:
            /home/pi/MagicMirror/node_modules/.bin/pm2
            /home/pi/MagicMirror/node_modules/pm2
            /home/pi/MagicMirror/node_modules/pm2/bin/pm2
            /home/pi/MagicMirror/node_modules/pm2/lib/templates/logrotate.d/pm2
            /home/pi/MagicMirror/node_modules/pm2/pm2
            /usr/local/bin/pm2
            /usr/local/lib/node_modules/pm2
            /usr/local/lib/node_modules/pm2/bin/pm2
            /usr/local/lib/node_modules/pm2/lib/templates/logrotate.d/pm2
            /usr/local/lib/node_modules/pm2/pm2
            ANY idea on which one would work better.?
            Here is my current crontab -e
            # Turn off display at 9pm
            00 21 * * 0-6 /usr/local/bin/pm2 stop all >/dev/null >2&1
            # Turn on screen Monday - Friday at 6:45 am
            45 06 * * 1-5 /usr/local/bin/pm2 start mm >/dev/null >2&1
            # Turn on screen Saturday - Sunday at 7:30 am
            30 07 * * 6,0 /usr/local/bin/pm2 start mm >/dev/null >2&1
            S mumblebajM 3 Replies Last reply Reply Quote 0
              @plainbroke which one, if any , are in the path
              Are they all executable?
              ls -laF
              Will give you the permissions mask
              Are any of them links to another?
              What changed?
              /usr/local/bin/pm2
              Should be the one
                @plainbroke also look in /var/log/syslog
                To find the logging of the execute at the time it should fire
                  Weird, I do not have /var/log/syslog.
                  Even did a find for it nothing, popped up…
                  pi@Pixie:~ $ ls -laF
                  total 348
                  drwx------ 15 pi   pi     4096 Nov 10 15:36 ./
                  drwxr-xr-x  3 root root   4096 Sep 30 19:18 ../
                  -rw-------  1 pi   pi     9080 Nov 10 13:17 .bash_history
                  -rw-r--r--  1 pi   pi      220 Sep 30 19:06 .bash_logout
                  -rw-r--r--  1 pi   pi     3523 Sep 30 19:06 .bashrc
                  drwx------ 13 pi   pi     4096 Nov  7 18:22 .cache/
                  drwx------ 22 pi   pi     4096 Nov  8 12:57 .config/
                  drwx------  3 pi   pi     4096 Nov  7 17:49 .dbus/
                  drwxrwxr-x  2 pi   pi     4096 Sep 30 19:17 Desktop/
                  drwx------  2 pi   pi     4096 Nov  7 23:11 Documents/
                  -rw-rw-r--  1 pi   pi        0 Nov  7 20:00 .gitconfig
                  -rw-rw-r--  1 pi   pi       81 Nov  7 18:24 .gtkrc-2.0
                  -rw-rw-r--  1 pi   pi   222126 Oct 27 18:52 install.log
                  drwx------  4 pi   pi     4096 Sep 30 19:18 .local/
                  drwxrwxr-x 16 pi   pi     4096 Nov  8 12:54 MagicMirror/
                  -rwxrwxrwx  1 pi   pi      320 Jun 12  2022 mm.json*
                  -rwxrwxrwx  1 pi   pi       38 Jul 16  2023 mm.sh*
                  drwx------  4 pi   pi     4096 Nov  6 21:05 .mozilla/
                  drwxrwxr-x  4 pi   pi     4096 Oct 27 18:30 .npm/
                  drwx------  3 pi   pi     4096 Oct 27 18:52 .pki/
                  drwxrwxr-x  5 pi   pi     4096 Nov  9 17:24 .pm2/
                  -rw-r--r--  1 pi   pi      807 Sep 30 19:06 .profile
                  -rw-rw-r--  1 pi   pi       66 Oct 27 19:22 .selected_editor
                  drwxrwxr-x  4 pi   pi     4096 Nov 10 15:43 shared/
                  -rw-r--r--  1 pi   pi        0 Sep 30 19:18 .sudo_as_admin_successful
                  drwx------  3 pi   pi     4096 Nov  5 17:30 .vnc/
                  -rw-------  1 pi   pi       50 Nov  9 17:24 .Xauthority
                  -rw-------  1 pi   pi     8238 Nov  9 19:32 .xsession-errors
                  -rw-------  1 pi   pi     7945 Nov  9 17:24 .xsession-errors.old
                  • mumblebajM Offline
                    mumblebaj Module Developer @plainbroke
                    @plainbroke Instead of piping the output to a blackhole, maybe pipe it to a logfile which you can interrogate to see why the pm2 start is not working?
                    evroomE 1 Reply Last reply Reply Quote 0
                    • evroomE Online
                      evroom @mumblebaj
                      About /var/log/syslog.
                      Debian does not use that anymore, already since a while.
                      As far as I understand it, you will need to get familiar with journalctl.
                      For cron jobs try this:
                      $ journalctl --since "1 hour ago" --unit cron.service
                      $ journalctl -f -u cron.service
                      Happy hunting.
                      MagicMirror version: 2.33.0
                      Test environment:
                      MagicMirror version: v2.33.0
                        plainbroke @evroom
                        @evroom,
                        I get that nothing is found, when I run either of your suggestions.
                        @mumblebaj
                        Explain piping, Please…
                        S evroomE mumblebajM 3 Replies Last reply Reply Quote 0
                        • 4 / 5
