    how to disable screensaver?
    10 Posts 6 Posters 20.4k Views 6 Watching
      sgtwtf
      Got my MM all configured how I want it. Now im just doing cleanup. The only remaining issues I have are #1 the screensaver still turns screen black after 30 min. I have done both methods found ins this wiki. http://www.etcwiki.org/wiki/Disable_screensaver_and_screen_blanking_Raspberry_Pi
      The 2nd issue is the cursor still shows. I have unclutter working but the mouse has to move once before it takes effect.
      Any ideas or other methods.
      L 1 Reply Last reply
      • I
        in_a_days @sgtwtf
        @sgtwtf
        My solution was to install xscreensaver and use the desktop control panel to disable the screensaver.
        sudo apt-get install xscreensaver
        sudo reboot
        On reboot open the desktop start menu (via the GUI, not the terminal) and I think it’s Preferences > Screensaver Settings. There’s an option to set (and disable) the screensaver. It worked for me. :)
        What ship would bear me ever back across so wide a Sea?
        S K 2 Replies Last reply
        Reply Quote 5
        • L
          lolobyte @sgtwtf
          @sgtwtf
          try
          sudo apt-get remove xscreensaver
          cowboysdudeC S 2 Replies Last reply
          Reply Quote 1
          • cowboysdudeC
            cowboysdude Module Developer @lolobyte
            @lolobyte said in how to disable screensaver?:
            @sgtwtf
            try
            Was going to be my suggestion as well!
            Install xscreensaver then disable screen saver … it works. It’s a HUGE time saver and no modifying files are needed only to be frustrated because it didn’t work :)
              sgtwtf @lolobyte
              @lolobyte
              I tried this after I got home today and the package xscreensaver is not installed so this command failed.
              Reply Quote 1
              • L
                lolobyte @sgtwtf
                @sgtwtf
                follow this install guide, you will find this entry’s: https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide
                Disable the screensaver
                Go to LXDE-autostart config:
                sudo nano /etc/xdg/lxsession/LXDE/autostart
                add the following lines:
                @xset s noblank
                @xset s off
                @xset -dpms
                Save and close, using the commands CTRL-O and CTRL-X.
                Go to lightdm.conf:
                sudo nano /etc/lightdm/lightdm.conf
                xserver-command=X -s 0 -dpms
                Reboot the raspberry pi:
                sudo reboot
                Reply Quote 2
                  sgtwtf
                  The commands were already added to those files. I installed xscreensaver and uninstalled and rebooted and no change.
                  I 1 Reply Last reply
                  • I
                    in_a_days @sgtwtf
                    @sgtwtf
                    sudo reboot
                    Reply Quote 5
                      sgtwtf @in_a_days
                      @in_a_days
                      Thank you that worked like a charm!
                      • K
                        kurt @in_a_days
                        @in_a_days
                        Thanks for that easy solution, and as I havn’t installed Jessie-Lite, I tried your way to disable the screensaver.
                        I do agree with @sgtwtf, it works like a charm :relaxed:
                        Thank you !
                        • R
                          ruralguru
                          To add an update that resolved this for me without installing another package.
                          https://pimylifeup.com/raspberry-pi-disable-screen-blanking/
                          this worked for me on bullseye 64 bit.
