    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 463.3k Views 31 Watching
      Dinschal @sdetweil
      @sdetweil hey sam there is a update for your module?
        sdetweil @Dinschal
        @dinschal yes… see my email…
          Dinschal @sdetweil
          @sdetweil a thanks… yes everything is working now…
            sdetweil @Dinschal
            @dinschal thanks for your help!!..
              Dinschal @sdetweil
              @sdetweil thanks for your patience ;)
              next step is to try the NewPIR with the PIRSensor ;) and then create a 10 min presentation for students 🤮🤮🤮🤮
                josh45631
                Is there any way you could break down the setup even more for dummies like myself? I can’t seem to access the configuration form in browser. Do I have to use a browser on the raspberry pi? Can it be a computer on my local network? When I try to access http://192.168.2.13:8300/modules/MMM-Config/review from my PC all I get is “Cannot GET /modules/MMM-Config/review”
                Same with
                http://localhost:8300/modules/MMM-Config/review
                from the pi itself
                What am I doing wrong?
                  sdetweil @josh45631
                  @josh45631 for access from a system other than the machine running mm, the mm config.js has to allow it
                  address:"0.0.0.0",
                  ipWhitelist:[],
                  by default the config is set to address:“localhost”
                  which means ONLY apps inside the same machine can connect
                  do you have showQR:true, in the module config section?
                  if so does the qr show on the mm screen?
                  can u show me the module entry from config.js
                  also when u start mm, the module puts out a couple messages at startup
                  so look at the messages where u start mm
                  either by npm start or pm2
                  if pm2, then the command
                  pm2 logs --lines=50
                  also the url to the form is
                  http://mm_address:mm_port/modules/MMM-Config/review
                  mm_port is 8080 by default not 8300
                    josh45631 @sdetweil
                    @sdetweil I did have showQR set to true in the module config, but the QR code wasn’s showing up.
                    After changing the address in the mm config from localhost to 0.0.0.0 the QR code is now appearing on the magic mirror.
                    Now when I try to access the form from my pc I get “This device is not allowed to access your mirror.
                    Please check your config.js or config.js.sample to change this.”
                    and the terminal on the pi says “Access denied to IP address: 192.168.2.5”
                    I tried to add it to the ipWhitelist, but I don’t think I have the proper format because it’s not working?
                    Module entry is:
                                           module:"MMM-Config",
                                           position:"top_right",  // the QR code (if requested) will appear here
                                           config:{
                                           module: "alert",
                                           module: "updatenotification",
                                           position: "top_bar"
                                           module: "clock",
                                           position: "top_left"
                                           header: "US Holidays",
        symbol: "calendar-check",
        url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
                    etc
                    This is how I tried to whitelist my computers ip
                        ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1","192.168.2.5"],    // Set [] to allow all IP addresses
                    I appreciate your help very much!
                      sdetweil @josh45631
                      @josh45631 said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                      ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”,“192.168.2.5”],
                      this means ONLY apps on THIS machine (127.0.0.1 = localhost) are allowed to connect, EVEN if address: is NOT localhost
                      1st thing to do is disable whitelist , set to [] (means no ip filtering)
                      fix it after u get things working
                      also u really want to add
                      showQR:true
                      in the MMM-Config
                      config section
                                             config:{
                                                    showQR:true
                        josh45631 @sdetweil
                        @sdetweil Ok here’s where I am. I think I’ve made the proper changes in the config file.
                        Changed address to 0.0.0.0
                        Changed ipWhitelist to []
                        Added showQR: “true”
                        * Magic Mirror Config Sample
                         * By Michael Teeuw https://michaelteeuw.nl
                         * MIT Licensed.
                         * see https://docs.magicmirror.builders/getting-started/configuration.html#general
                         * and https://docs.magicmirror.builders/modules/configuration.html
                        let config = {
                                address: "0.0.0.0",     // Address to listen on, can be:
                                port: 8080,
                                basePath: "/",  // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                                ipWhitelist: [],        // Set [] to allow all IP addresses
        // or add a specific IPv4 of 192.168>
        // ["127.0.0.1", "::ffff:127.0.0.1",>
        // or IPv4 range of 192.168.3.0 --> >
                                useHttps: false,                // Support HTTPS or not, default "false" will use HTTP
                                httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
                                httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
                                language: "en",
                                locale: "en-US",
                                timeFormat: 24,
                                units: "metric",
                                                config:{
                                                        showQR: "true"
                                                module: "alert",
                                                position: "top_bar"
                                                module: "clock",
                                                module: "compliments",
                                                position: "lower_third"
                                                module: "weather",
                                                        type: "current",
                                                        locationID: "", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                                        apiKey: "YOUR_OPENWEATHER_API_KEY"
                                                module: "weather",
                                                header: "Weather Forecast",
                                                        type: "forecast",
                                                        locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your ci>
                                                module: "newsfeed",
                                                position: "bottom_bar",
                                                        feeds: [
        title: "New York Times",
        url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                                                        showSourceTitle: true,
                                                        showPublishDate: true,
                                                        broadcastNewsFeeds: true,
                                                        broadcastNewsUpdates: true
                        The QR code is showing up in the top right of the magic mirror.
                        When I try to navigate to
                        http://192.168.2.13:8080/modules/MM-Config/review
                        all I get is “Cannot GET /modules/MM-Config/review”
                        If it helps, this is the terminal output at startup:
                        [27.11.2021 23:08.01.269] [LOG]   Starting MagicMirror: v2.17.1
                        [27.11.2021 23:08.01.283] [LOG]   Loading config ...
                        [27.11.2021 23:08.01.296] [LOG]   Loading module helpers ...
                        [27.11.2021 23:08.01.954] [LOG]   Initializing new module helper ...
                        [27.11.2021 23:08.01.956] [LOG]   Module helper loaded: MMM-Config
                        [27.11.2021 23:08.01.959] [LOG]   No helper found for module: alert.
                        [27.11.2021 23:08.01.968] [LOG]   Initializing new module helper ...
                        [27.11.2021 23:08.01.969] [LOG]   Module helper loaded: updatenotification
                        [27.11.2021 23:08.01.971] [LOG]   No helper found for module: clock.
                        [27.11.2021 23:08.02.295] [LOG]   Initializing new module helper ...
                        [27.11.2021 23:08.02.296] [LOG]   Module helper loaded: calendar
                        [27.11.2021 23:08.02.298] [LOG]   No helper found for module: compliments.
                        [27.11.2021 23:08.02.301] [LOG]   No helper found for module: weather.
                        [27.11.2021 23:08.02.348] [LOG]   Initializing new module helper ...
                        [27.11.2021 23:08.02.349] [LOG]   Module helper loaded: newsfeed
                        [27.11.2021 23:08.02.350] [LOG]   All module helpers loaded.
                        [27.11.2021 23:08.02.521] [LOG]   Starting server on port 8080 ...
                        [27.11.2021 23:08.02.532] [WARN]  You're using a full whitelist configuration to allow for all IPs
                        [27.11.2021 23:08.02.545] [LOG]   Server started ...
                        [27.11.2021 23:08.02.547] [LOG]   Connecting socket for: MMM-Config
                        [27.11.2021 23:08.02.548] [LOG]   Starting module helper: MMM-Config
                        [27.11.2021 23:08.02.550] [LOG]   Connecting socket for: updatenotification
                        [27.11.2021 23:08.02.552] [LOG]   Connecting socket for: calendar
                        [27.11.2021 23:08.02.553] [LOG]   Starting node helper for: calendar
                        [27.11.2021 23:08.02.554] [LOG]   Connecting socket for: newsfeed
                        [27.11.2021 23:08.02.556] [LOG]   Starting node helper for: newsfeed
                        [27.11.2021 23:08.02.557] [LOG]   Sockets connected & modules started ...
                        [27.11.2021 23:08.02.932] [LOG]   Launching application.
                        [27.11.2021 23:08.06.686] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                        [27.11.2021 23:08.07.027] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                        [27.11.2021 23:08.07.039] [LOG]   MMM-Config received a socket notification: CONFIG - Payload: [object Object]
                        [27.11.2021 23:08.07.042] [LOG]   command =/home/pi/MagicMirror/modules/MMM-Config/test_convert.sh override
                        [27.11.2021 23:08.07.044] [LOG]   Starting module helper:MMM-Config
                        [27.11.2021 23:08.07.045] [LOG]   execing /home/pi/MagicMirror/modules/MMM-Config/test_convert.sh override
                        [27.11.2021 23:08.07.340] [INFO]  Checking git for module: default
                        [27.11.2021 23:08.07.378] [INFO]  Checking git for module: MMM-Config
                        [27.11.2021 23:08.07.579] [LOG]    got port=8300
                        [27.11.2021 23:08.08.352] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                        [27.11.2021 23:08.09.037] [INFO]  Newsfeed-Fetcher: Broadcasting 55 items.
                        [27.11.2021 23:08.13.839] [LOG]   stdout: completed
                        I apologize if I’m being difficult. I was just getting very frustrated trying to manually configure modules, and when I stumbled across your module, I got excited! I feel like I’m overlooking something simple!:grimacing_face:
                        mumblebajM S 2 Replies Last reply Reply Quote 0
                        • mumblebajM Offline
                          mumblebaj Module Developer @josh45631
                          showQR: “true”
                          This should be showQR: true without the quotes. Not sure if it makes much of a difference.
                          The URL I used and which worked for me was:
                          http://localhost:8080/modules/MMM-Config/config.html?port=8300
                          @sdetweil Very cool module.
                            sdetweil @josh45631
                            @josh45631 I had a typo which I corrected
                            notice the module name is MMM-Config
                            3 M’s
                            the content says the module is running
                            if you use your phone on the qr does the page show?
                              sdetweil @mumblebaj
                              @mumblebaj don’t use the final url… use the review url as provided in the doc
                              as the module discovers a free port for communication between the form and the module.
                                josh45631 @sdetweil
                                @sdetweil said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                                3 M’s
                                :man_facepalming:
                                There it is. I knew it would come down to something simple! I still can’t get to the form page by scanning the QR code, but I’m ok with that for now because I can access it via browser!
                                Thank you so much!
                                  sdetweil @josh45631
                                  @josh45631 what are you using to scan the qr?
                                    mumblebaj Module Developer @sdetweil
                                    @sdetweil Which URL in the doc? From the screenshots? The review URL did not work for me. The one I posted above did. The QR code gave me a different URL which did not work for me but guess it is because of my install on my Windows laptop.
                                      mumblebaj Module Developer @mumblebaj
                                      @sdetweil I found the URL bit in the doc.
                                      http://machine_name:MM_Port/modules/MMM-Config/review
                                      Did not work for me when I tried it though.
                                        sdetweil @mumblebaj
                                        @mumblebaj u did change the symbolic names to actual, right?
                                        machine_name
                                        MM_port
                                        right?
                                          sdetweil @mumblebaj
                                          @mumblebaj windows should have worked
                                          can u tell me what the url was?
                                          when u configure mm for address:“0.0.0.0”
                                          it’s not something I can connect to
                                          so I get the machine hostname
                                          I guess I need to figure out an IP address…
                                            @sdetweil The QR code gave me machine name. But I figured that could not be correct. When I used the review URL earlier it did not work, When I started my Ubuntu Instance now and tried review with this URL:
                                            http://localhost:8080/modules/MMM-Config/review
                                            it worked fine and resolved to the following:
                                            which I guess is what you were referring to?
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 10 / 15
