    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 489.8k Views 31 Watching
      sdetweil @uros76
      @uros76 ok, can u send me config.js and the defaults.js from the MMM-Config folder…
      have to rename them to .txt to add as attachments
      via email…to my same userid at gmail…
      uros76U 1 Reply Last reply
      • uros76U
        uros76 @sdetweil
        @sdetweil yes the module shows on screen in form of QR code. That part works.
        My basics from config file:
        address: "0.0.0.0",
        useHttps: false,
        port: 8080,
        ipWhitelist: [],
        My magicmirror projects: https://forum.magicmirror.builders/post/79889, https://forum.magicmirror.builders/post/93241 and https://forum.magicmirror.builders/post/94586
        • uros76U
          uros76 @sdetweil
          @sdetweil ok will send you now…
            sdetweil @uros76
            @uros76 thanks… there was probably an error reported in the console where u do npm start (or pm2 logs if using pm2)
              sdetweil @uros76
              @uros76 posted a fix, sent email back
              Reply Quote 1
              • uros76U
                uros76 @sdetweil
                @sdetweil it works! Mega quick assistance. Tnx
                • F
                  Fonzi03
                  i too am getting the blank homescreen which only shows
                  “configure magic mirror and modules”
                  it wont let me upload the jsconfig or default config here how can i send them?
                  S 2 Replies Last reply
                    sdetweil @Fonzi03
                    @fonzi03 send to my same userid at gmail. have to rename them to .txt instead of .js to attach to email
                    Reply Quote 1
                      sdetweil @Fonzi03
                      @fonzi03 i sent email back
                      • D
                        Dinschal
                        I’m not able to pull your module from github. I got this error.
                        Greetings
                          sdetweil @Dinschal
                          @dinschal hm… I don’t see that
                          rename the module folder and and git clone again
                          then delete the old folder
                          • D
                            Dinschal
                            There is no module folder…
                            Okay everything fine… i have to go to bed :D my fault sry :D
                            Change pull to clone and it works ;) too much code today.
                            I’m really sorry :(
                              sdetweil @Dinschal
                              @dinschal huh?
                              ah, I see… to get the 1ST copy you use
                              git clone
                              to UPDATE later you do
                              git pull
                              with no extra parms…
                              see the two topics in my signature… I didn’t write em, but they are helpful
                              D 1 Reply Last reply
                              Reply Quote 1
                              • D
                                Dinschal @sdetweil
                                @sdetweil thanks a lot… sometimes this is the best time to go to bed :D
                                my brain isnt working much longer today :D
                                  sdetweil @Dinschal
                                  @dinschal I’ve been there… get some rest
                                  • D
                                    Dinschal @sdetweil
                                    first of all… my english is very bad :D
                                    today my goal is that your module is working… i have configure it cause i have the mm with localhost and use bitvise for ssh.
                                    So i have to change the localhost in my config :D
                                    I tired to read the error message but its to tiny :D the only thing i can read is localhost :D
                                      sdetweil @Dinschal
                                      @dinschal said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                                      I tired to read the error message but its to tiny the only thing i can read is localhost
                                      what error message?
                                      u mean the module output when address:“localhost” is set??
                                      localhost means ONLY apps running inside the SAME system can access
                                      so a phone (use the qr code) , or another computer (use the url) cannot…
                                      • D
                                        Dinschal @sdetweil
                                        @sdetweil yeah this one ;) i want to change it cause the mirror is a gift for my parents and if i had to change something i only have my phone.
                                        I changed it to 0.0.0.0 so i get the qr but know my device is not allowed to access my mirror :D
                                          sdetweil @Dinschal
                                          @dinschal also have to edit the ipWhitelist.
                                          I set it to []
                                          ipWhitelist:[],
                                          • D
                                            Dinschal @sdetweil
                                            @sdetweil i did it let me check ;)
                                            okay i got it… but now i only have the "configuration window without the possibility to configure,
                                            i tryed it with a new pull and an new installation of your module :(
                                            • 6
                                            • 7
                                            • 14
                                            • 15
                                            • 5 / 15
