    Which Alexa module is better, Awesome Alexa or Mirror Mirror on the Wall
    magic mirroralexaalexa voice servicemagicmirror2magicmirrorhelp me pleasehelpassistantgoogle assistantnotifications
    28 Posts 7 Posters 14.1k Views 7 Watching
      sdetweil @cyberphox
      @cyberphox alexaControl allows a REAL echo to control funtions on MagicMirror
        DDE12 @sdetweil
        Thanks! I will work on setting it up.
        • C Offline
          cyberphox @sdetweil
          @sdetweil said in Which Alexa module is better, Awesome Alexa or Mirror Mirror on the Wall:
          alexaControl
          wasn’t aware of this module - thanks for the info as always!
            Seregeth @DDE12
            @DDE12
            I wanted to start this module, bit something seems to be wrong. To test it i set in the config:
            module: ‘MMM-AlexaControl’,
            position: ‘middle_center’,
            config:{
            image: true,
            pm2ProcessName: “mm”,
            vcgencmd: “vcgencmd”
            like in the description. But there is always an error. Seems that something is missing? di i left somthing important to start the module?
              sdetweil @Seregeth
              @Seregeth what error?
                Seregeth @sdetweil
                This on the screen:
                this after the check:
                  sdetweil @Seregeth
                  @Seregeth unexpected token
                  ALMOST ALWAYS means you forgot a trailing comma on the line before the line reported in the error message, so line 91 in this case.
                    Seregeth @sdetweil
                    I don´t know what i have done other than bevore, but i insert the command lines bevor another module, now it starts without errors
