    Which Alexa module is better, Awesome Alexa or Mirror Mirror on the Wall
    magic mirroralexaalexa voice servicemagicmirror2magicmirrorhelp me pleasehelpassistantgoogle assistantnotifications
    28 Posts 7 Posters 16.5k Views 7 Watching
      cq0q @sdetweil
      @sdetweil how you did that ? And can i do on for example Google Assistant module ?
        sdetweil @cq0q
        @cq0q did what? use alexaControl?
        u can attach notifications when the power on or off request comes from Alexa.
        Alexa control makes virtual WeMo outlets.
        don’t think it can be done for GH devices. they demand account linkage, but no account for these virtual devices.
        very cool implementation
        it uses real Amazon echo device
          DDE12 @sdetweil
          Is AlexaControl still working?
            cyberphox
            Put an Alexa dot behind your mirror…so much less headache!
              sdetweil @DDE12
              @DDE12 yes… with some echo devices
              D 1 Reply Last reply
                sdetweil @cyberphox
                @cyberphox alexaControl allows a REAL echo to control funtions on MagicMirror
                C 1 Reply Last reply
                  DDE12 @sdetweil
                  Thanks! I will work on setting it up.
                    cyberphox @sdetweil
                    @sdetweil said in Which Alexa module is better, Awesome Alexa or Mirror Mirror on the Wall:
                    alexaControl
                    wasn’t aware of this module - thanks for the info as always!
                      Seregeth @DDE12
                      @DDE12
                      I wanted to start this module, bit something seems to be wrong. To test it i set in the config:
                      module: ‘MMM-AlexaControl’,
                      position: ‘middle_center’,
                      config:{
                      image: true,
                      pm2ProcessName: “mm”,
                      vcgencmd: “vcgencmd”
                      like in the description. But there is always an error. Seems that something is missing? di i left somthing important to start the module?
                        sdetweil @Seregeth
                        @Seregeth what error?
                          Seregeth @sdetweil
                          This on the screen:
                          this after the check:
                            sdetweil @Seregeth
                            @Seregeth unexpected token
                            ALMOST ALWAYS means you forgot a trailing comma on the line before the line reported in the error message, so line 91 in this case.
                              Seregeth @sdetweil
                              I don´t know what i have done other than bevore, but i insert the command lines bevor another module, now it starts without errors
