    Which Alexa module is better, Awesome Alexa or Mirror Mirror on the Wall
    magic mirroralexaalexa voice servicemagicmirror2magicmirrorhelp me pleasehelpassistantgoogle assistantnotifications
    28 Posts 7 Posters 16.5k Views 7 Watching
    • bugsounetB
      bugsounet Banned @sdetweil
      @sdetweil You know that i don’t ads any release there :)
        sdetweil @bugsounet
        @bugsounet well, you just did for GA… … SO… i don’t follow your forums… i have enough to do
        bugsounetB 1 Reply Last reply
        • bugsounetB
          @sdetweil not released … just under-coding :)
          C 1 Reply Last reply
            cq0q @bugsounet
            @bugsounet when do you think you’re gonna release it ?
              sdetweil @cq0q
              @cq0q he has moved support and communications for his modules to his own forum space
              http://forum.bugsounet.fr
                cq0q @sdetweil
                @sdetweil so you’re saying i’m not gonna be able to use any of alexa modules ??
                  sdetweil @cq0q
                  @cq0q what I said was, of the alexa modules for MagicMirror that WERE published, none of them are working completely… and no one has elected to take over the modules (this is all volunteer )
                  @bugsounet says he has one for MagicMirror, but I haven’t seen it.
                  I have developed one for a different platform, but it also doesn’t support interacting with the local system.
                  as the current Amazon api is all in audio files, not text.
                  • FoziF
                    Fozi Project Sponsor @cq0q
                    @cq0q I tried a few of the Alexa modules and unfortunally none really worked. Finally I found MMM-AlexaControl.
                    I took a spare Echo Dot I had laying around, mounted it on the back of my mirror and plugged it into the USB port of the RPi for power supply. That is the easiest way to go:
                    • Simple module setup and configuration
                    • no hassle with microphones and speakers
                    • Setup scenes and similar in the Alexa app to e.g. switch pages on the mirror
                    • done.
                      sdetweil @Fozi
                      @fozi I also use Alexa control. I added the naming capability a year or so ago, as I have 5 different mirrors to control.
                      easy. alexa turns off my lights at bedtime, and dims all the mirrors
                      C D 2 Replies Last reply
                        cq0q @sdetweil
                        @sdetweil how you did that ? And can i do on for example Google Assistant module ?
                          sdetweil @cq0q
                          @cq0q did what? use alexaControl?
                          u can attach notifications when the power on or off request comes from Alexa.
                          Alexa control makes virtual WeMo outlets.
                          don’t think it can be done for GH devices. they demand account linkage, but no account for these virtual devices.
                          very cool implementation
                          it uses real Amazon echo device
                            DDE12 @sdetweil
                            Is AlexaControl still working?
                              cyberphox
                              Put an Alexa dot behind your mirror…so much less headache!
                                sdetweil @DDE12
                                @DDE12 yes… with some echo devices
                                D 1 Reply Last reply
                                  sdetweil @cyberphox
                                  @cyberphox alexaControl allows a REAL echo to control funtions on MagicMirror
                                    DDE12 @sdetweil
                                    Thanks! I will work on setting it up.
                                      cyberphox @sdetweil
                                      @sdetweil said in Which Alexa module is better, Awesome Alexa or Mirror Mirror on the Wall:
                                      alexaControl
                                      wasn’t aware of this module - thanks for the info as always!
                                        Seregeth @DDE12
                                        @DDE12
                                        I wanted to start this module, bit something seems to be wrong. To test it i set in the config:
                                        module: ‘MMM-AlexaControl’,
                                        position: ‘middle_center’,
                                        config:{
                                        image: true,
                                        pm2ProcessName: “mm”,
                                        vcgencmd: “vcgencmd”
                                        like in the description. But there is always an error. Seems that something is missing? di i left somthing important to start the module?
                                          sdetweil @Seregeth
                                          @Seregeth what error?
                                            Seregeth @sdetweil
                                            This on the screen:
                                            this after the check:
