    Which Alexa module is better, Awesome Alexa or Mirror Mirror on the Wall
    magic mirroralexaalexa voice servicemagicmirror2magicmirrorhelp me pleasehelpassistantgoogle assistantnotifications
    28 Posts 7 Posters 16.1k Views 7 Watching
      sdetweil @bugsounet
      @bugsounet i have not seen announcement of yours… only future possibility
      bugsounetB 1 Reply Last reply Reply Quote 0
        cq0q @sdetweil
        @sdetweil so what should i do ? Like just stop from building magic mirror and leave it or what ?
        Please i need a solution …
          sdetweil @cq0q
          @cq0q if @bugounet has a solution, you should try that… otherwise all the other Alexa modules are broken.
          • bugsounetB
            bugsounet Banned @sdetweil
            @sdetweil You know that i don’t ads any release there :)
              sdetweil @bugsounet
              @bugsounet well, you just did for GA… … SO… i don’t follow your forums… i have enough to do
              • bugsounetB
                @sdetweil not released … just under-coding :)
                  cq0q @bugsounet
                  @bugsounet when do you think you’re gonna release it ?
                    sdetweil @cq0q
                    @cq0q he has moved support and communications for his modules to his own forum space
                    http://forum.bugsounet.fr
                      cq0q @sdetweil
                      @sdetweil so you’re saying i’m not gonna be able to use any of alexa modules ??
                        sdetweil @cq0q
                        @cq0q what I said was, of the alexa modules for MagicMirror that WERE published, none of them are working completely… and no one has elected to take over the modules (this is all volunteer )
                        @bugsounet says he has one for MagicMirror, but I haven’t seen it.
                        I have developed one for a different platform, but it also doesn’t support interacting with the local system.
                        as the current Amazon api is all in audio files, not text.
                        • FoziF
                          Fozi Project Sponsor @cq0q
                          @cq0q I tried a few of the Alexa modules and unfortunally none really worked. Finally I found MMM-AlexaControl.
                          I took a spare Echo Dot I had laying around, mounted it on the back of my mirror and plugged it into the USB port of the RPi for power supply. That is the easiest way to go:
                          • Simple module setup and configuration
                          • no hassle with microphones and speakers
                          • Setup scenes and similar in the Alexa app to e.g. switch pages on the mirror
                          • done.
                            sdetweil @Fozi
                            @fozi I also use Alexa control. I added the naming capability a year or so ago, as I have 5 different mirrors to control.
                            easy. alexa turns off my lights at bedtime, and dims all the mirrors
                            C D 2 Replies Last reply Reply Quote 0
                              cq0q @sdetweil
                              @sdetweil how you did that ? And can i do on for example Google Assistant module ?
                                sdetweil @cq0q
                                @cq0q did what? use alexaControl?
                                u can attach notifications when the power on or off request comes from Alexa.
                                Alexa control makes virtual WeMo outlets.
                                don’t think it can be done for GH devices. they demand account linkage, but no account for these virtual devices.
                                very cool implementation
                                it uses real Amazon echo device
                                  DDE12 @sdetweil
                                  Is AlexaControl still working?
                                    cyberphox
                                    Put an Alexa dot behind your mirror…so much less headache!
                                      sdetweil @DDE12
                                      @DDE12 yes… with some echo devices
                                        sdetweil @cyberphox
                                        @cyberphox alexaControl allows a REAL echo to control funtions on MagicMirror
                                          DDE12 @sdetweil
                                          Thanks! I will work on setting it up.
                                            cyberphox @sdetweil
                                            @sdetweil said in Which Alexa module is better, Awesome Alexa or Mirror Mirror on the Wall:
                                            alexaControl
                                            wasn’t aware of this module - thanks for the info as always!
