    Which Alexa module is better, Awesome Alexa or Mirror Mirror on the Wall
    magic mirroralexaalexa voice servicemagicmirror2magicmirrorhelp me pleasehelpassistantgoogle assistantnotifications
    28 Posts 7 Posters 16.5k Views 7 Watching
      sdetweil @cq0q
      @cq0q what I said was, of the alexa modules for MagicMirror that WERE published, none of them are working completely… and no one has elected to take over the modules (this is all volunteer )
      @bugsounet says he has one for MagicMirror, but I haven’t seen it.
      I have developed one for a different platform, but it also doesn’t support interacting with the local system.
      as the current Amazon api is all in audio files, not text.
      • FoziF
        Fozi Project Sponsor @cq0q
        @cq0q I tried a few of the Alexa modules and unfortunally none really worked. Finally I found MMM-AlexaControl.
        I took a spare Echo Dot I had laying around, mounted it on the back of my mirror and plugged it into the USB port of the RPi for power supply. That is the easiest way to go:
        • Simple module setup and configuration
        • no hassle with microphones and speakers
        • Setup scenes and similar in the Alexa app to e.g. switch pages on the mirror
        • done.
          sdetweil @Fozi
          @fozi I also use Alexa control. I added the naming capability a year or so ago, as I have 5 different mirrors to control.
          easy. alexa turns off my lights at bedtime, and dims all the mirrors
          C D 2 Replies Last reply
            cq0q @sdetweil
            @sdetweil how you did that ? And can i do on for example Google Assistant module ?
              sdetweil @cq0q
              @cq0q did what? use alexaControl?
              u can attach notifications when the power on or off request comes from Alexa.
              Alexa control makes virtual WeMo outlets.
              don’t think it can be done for GH devices. they demand account linkage, but no account for these virtual devices.
              very cool implementation
              it uses real Amazon echo device
                DDE12 @sdetweil
                Is AlexaControl still working?
                  cyberphox
                  Put an Alexa dot behind your mirror…so much less headache!
                    sdetweil @DDE12
                    @DDE12 yes… with some echo devices
                    D 1 Reply Last reply
                      sdetweil @cyberphox
                      @cyberphox alexaControl allows a REAL echo to control funtions on MagicMirror
                      C 1 Reply Last reply
                        DDE12 @sdetweil
                        Thanks! I will work on setting it up.
                          cyberphox @sdetweil
                          @sdetweil said in Which Alexa module is better, Awesome Alexa or Mirror Mirror on the Wall:
                          alexaControl
                          wasn’t aware of this module - thanks for the info as always!
                            Seregeth @DDE12
                            @DDE12
                            I wanted to start this module, bit something seems to be wrong. To test it i set in the config:
                            module: ‘MMM-AlexaControl’,
                            position: ‘middle_center’,
                            config:{
                            image: true,
                            pm2ProcessName: “mm”,
                            vcgencmd: “vcgencmd”
                            like in the description. But there is always an error. Seems that something is missing? di i left somthing important to start the module?
                              sdetweil @Seregeth
                              @Seregeth what error?
                                Seregeth @sdetweil
                                This on the screen:
                                this after the check:
                                  sdetweil @Seregeth
                                  @Seregeth unexpected token
                                  ALMOST ALWAYS means you forgot a trailing comma on the line before the line reported in the error message, so line 91 in this case.
                                    Seregeth @sdetweil
                                    I don´t know what i have done other than bevore, but i insert the command lines bevor another module, now it starts without errors
