    Face Recognition with inferred light
    52 Posts 5 Posters 57.6k Views 4 Watching
    • F Offline
      feuerball
      Is it possible to train the TrainingFile in the dark? I got some IR-Lights @ the mirror, but while i was trying he couldnt find a face.
      The second problem is, that he loggs me in but doesnt show the calendar & travel module, when im logged in.
      In my the config of the Module stands users: ['Marvin'].
      I added classes: 'default for_all' to the standard modules and classes: 'Marvin' to my specific modules; but he doesnt show my modules when im logged in.
      Note from admin: Please use the Markdown code feature instead of quotes for code snippets, looks a lot better! :)
      • P Offline
        paviro @feuerball
        @feuerball to the IR-thing: No idea, never tried openCV with IR. How does the image of your face look like on IR? Could you post an example?
        Does the module show a message, when you are recognized?
        – The Doctor
        • F Offline
          feuerball
          @paviro
          yes he shows me
          User Marvin with confidence 48.63… logged in and after 15 secs User Marvin logged out.
          This was recorded in completely Darkness, only IR Light. The mirror will be positioned in a tiny corridor, so the lightment is enough. Otherwise i could raise the recording time or going into night mode.
          • P Offline
            paviro
            Only the console or the US as well? The image could be a bit too dark for openCV to recognize a face :(
            – The Doctor
            • K Offline
              KirAsh4 Moderator
              MOAR IR LIGHT! :)
              • F Offline
                feuerball
                hm? :D
                no only the console says logged in.
                • K Offline
                  KirAsh4 Moderator @feuerball
                  @feuerball, I meant, add more IR lights for the camera to “see” better at night.
                  • F Offline
                    feuerball @KirAsh4
                    @KirAsh4
                    ay, that might be a point, so i will have a Terminator on my wall :D
                    • K Offline
                      KirAsh4 Moderator
                      A series of them along the top frame won’t look too bad. Or, depending on where/how the camera is, you might be able to add a ring of IR LEDs around it too.
                      • F Offline
                        feuerball @KirAsh4
                        @KirAsh4
                        this is the ir light.
                        http://www.amazon.de/Infrarot-Leuchter-Board-Plate-Sicherheitskamera/dp/B0057DPXI4?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o04_s00
                        First i placed the cam in the middle of it; the problem is, that the IR reflects @ the mirror, so the camera was blind.
                        A wall of IR lights might be a way to do it
                        • K Offline
                          KirAsh4 Moderator
                          Yeah, if that didn’t work around the camera, then you’ll need to add them to the frame (or in front of the mirror essentially.)
                          • K Offline
                            KirAsh4 Moderator
                            Maybe something like this embedded in the frame?
                            http://amzn.com/B019QTDDH2
                            • F Offline
                              feuerball
                              Saw this too :)
                              I think i will create a new frame with a larger monitor and a real mirror glas anyway so i gonna try to get more IR-Light into this.
                              The only doubt i got is the power consumption… Tons of IR-Lights = Tons of W/h :D
                              • K Offline
                                KirAsh4 Moderator
                                Problem solved! 80-100 METERS of illumination!
                                • F Offline
                                  feuerball
                                  :D a bit too strong for a 4x1.5m corridor :D
                                  • K Offline
                                    KirAsh4 Moderator
                                    This might work though, if you’re using either an rPi camera, or something similar. If you’re going to put the camera in the frame, you’ll be drilling a hole. Why not two more for the IR lights as well. And at 3W each, that’s mighty bright. http://amzn.com/B00ZEFIU6C
                                    • F Offline
                                      feuerball
                                      hmmmm. thanks sounds like a plan.
                                      I think i have to drill one larger hole, otherwise the photodiode cant see wether its dark or not hm?
                                      • K Offline
                                        KirAsh4 Moderator
                                        A small hole next to the large one, enough for light to go through, should work. Usually it’s a tiny pinhole, but that’s also assuming the sensor is literally right up against the pinhole.
                                        • F Offline
                                          feuerball
                                          so still the problem with not logging in correctly :(
                                          • P Offline
                                            paviro
                                            Is there any log in the Web inspector?
                                            – The Doctor
                                            • 1 / 3
