    Third Party modules not working
    8 Posts 4 Posters 1.8k Views 4 Watching
    • delta 1D Offline
      delta 1
      hey, guys, I’ve installed Alexa, screencast, and some others, and doesn’t matter what I try non of them work can anybody help me with this.
        DJBOOB66
        fix your config
            module: "MMM-awesome-alexa",
            position: "bottom_bar",
                wakeWord: "Alexa",
                clientId: "YOUR_CLIENT_ID",
                clientSecret: "YOUR_CLIENT_SECRET",
                deviceId: "YOUR_DEVICE_ID",
                refreshToken: "YOUR_REFRESH_TOKEN",
                lite: false,
                isSpeechVisualizationEnabled: false
        delta 1D 2 Replies Last reply Reply Quote 0
        • delta 1D Offline
          delta 1 @DJBOOB66
          @djboob66 said in Third Party modules not working: thanks for the response yea, is it in the correct order now ?
          • delta 1D Offline
            delta 1 @DJBOOB66
            @djboob66 tried that and still doesn’t work
              DJBOOB66
              @delta-1 said in Third Party modules not working:
              Alexa
              your config must line up
              		module: 'MMM-Screencast',
              		position: 'bottom_right',
              			position: 'bottomRight',
              			height: 300,
              			width: 500,
                          wakeWord: "Alexa",
                          lite: false,
                DJBOOB66
                Im not a alexa guy i use Google assistant V3 myself but below need fixing.
                cowboysdudeC S 2 Replies Last reply Reply Quote 0
                • cowboysdudeC Offline
                  cowboysdude Module Developer @DJBOOB66
                  Have to be careful if you’re cutting and pasting … for instance if you install a module and you go to the programmers page and copy and paste the config example the quotes will not translate. You will get errors.
                    sdetweil @DJBOOB66
                    @djboob66 there is nothing functionally wrong with his text…
                    sure the braces aren’t lined up and the sections aren’t indented like I personally would like and do… but MagicMirror doesn’t care.
