    • Search
    MagicMirror² v2.20.0 is available! For more information about this release, check out this topic.
    MMM-FHEM no Fhem statusdisplay
    Troubleshooting
    4454
    • W
      Woody last edited by
      hi folks,
      I’ve tried to install and activate the MMM-FHEM module but with not to much success. There was actually no problem neither with the installation nor the configuration but I can’t get it running. It doesn’t matter if I use Http or Https, I tried also differed Devices and Readings but no luck. This is my config and maybe someone can point me out something wrong or give me any idea in debugging this.
          			module: 'MMM-FHEM',
         			 position: 'bottom_bar',
            			host: '192.168.0.50',
            			port: '8083',
            			https: 'true',
            			devices: [
                        			{ deviceName: 'Lichtfenster',
                          			  deviceReadings: [
                                            			{ name: 'state', suffix: 'test1' },
      any help will be appreciated. Thx in advance… Woody
      strawberry 3.141 1 Reply Last reply Reply Quote 0
      • N
        Nonamexp last edited by
        Hello, you have deactivate The Passwort in fhem?!
        • strawberry 3.141
          strawberry 3.141 Project Sponsor Module Developer @Woody last edited by
          @Woody I don’t have experience with this specific module, but I can tell you the way you defined the boolean https was always true.
          In Javascript a string is always true no matter what the content is "hello" -> true, "true" -> true, "false" -> true.
          If you remove the quotes and try again https: false, then you will really use http instead of https.
          • W
            Thanks Folks,
            it seem I was completely stumped. Sometimes I overlook the simplest things.
            The password was the problem but, at least I think this is not a good solution to access Fhem without authorization. Anyway, problem solved - thanks a lot.
            Rgs. Woody
            • D
              dominic @Woody last edited by
              @Woody said in MMM-FHEM no Fhem statusdisplay:
              Thanks Folks,
              Rgs. Woody
              Hi Woody,
              how can i deactivate the passwort? I think my problem is the same.
              • W
                in fhem you have to disable “basicAuth” in fhem.cfg like this…
                #attr allowed_WEB basicAuth shjedIOhbn6BHFJjGH
                • D
                  Hi Woody, thanky you for your answer. Can you explain it?
                  I have defined WEB and than ? Sorry i am very new in FHEM what means " shjedIOhbn6BHFJjGH"?
                  • D
                    @Woody
                    So i now there is this entrie in the config.cfg “define allowed_WEB allowed
                    #attr allowed_WEB basicAuth xxxxxxxxxxxxxxx
                    #attr allowed_WEB validFor WEB”
                    and my config.js looks like this
                        module: 'MMM-FHEM',
                        position: 'top_right',
                          host: 'localhost',
                          port: '8083',
                          https: false,
                    	        devices: [
                                      { deviceName: 'ESPEasy_ESP_Test_DHT',
                                        deviceReadings: [
                                                          { name: 'Temperatur', icon: 'wi wi-thermometer', suffix: '°' },
                                                          { name: 'Humidity', icon: 'wi wi-humidity', suffix: '%' },
                                      { deviceName: '',
                                        deviceReadings: [
                                                          { name: 'Humidity', icon: 'fa fa-battery-half', suffix: '' },
                    And this is in FHEM…
                    where is the mistake?
                    • W
                      @dominic said in MMM-FHEM no Fhem statusdisplay:
                      shjedIOhbn6BHFJjGH is your base64 encoded string of user:password in your fhem.cfg.
                      In your forelast post it seems to be out commented with a # as i recommended in my last post. For me this means that you’ve no authentication in place and your original problem seems not to be an authorization issue.
                      • D
                        @Woody Thank you, yes i think my originlproblem is not the authorization.
                        Do you have any idea., what it could be ?
